0010685 | ParaView | Bug | public | 2010-05-06 15:49 | 2010-08-30 15:09 | ||||
Reporter | Eric Monson | ||||||||
Platform | Mac | OS | OS X | OS Version | |||||
Target Version | Fixed in Version | 3.8.1 | |||||||
Summary | 0010685: PV build errors on OS X with VTK_USE_RPATH: OFF | ||||||||
Description | Mike Jackson described the problem (http://www.mail-archive.com/paraview@paraview.org/msg07520.html [^]) when trying to build PV on OS X when VTK_USE_RPATH = OFF: Checkout/updated from CVS this afternoon and a fresh configure and compile I get the following error on OS X 10.5.8: [ 23%] Generating vtkSocketCommunicatorHash.h dyld: Library not loaded: libvtksys.pv3.8.dylib Referenced from: /Users/Shared/Kitware-CVS/ParaView3/Build/VTK/Parallel/../../bin/vtkHashSource Reason: image not found /bin/sh: line 1: 19254 Trace/BPT trap ../../bin/vtkHashSource /Users/Shared/Kitware-CVS/ParaView3/VTK/Parallel/vtkSocketCommunicator.cxx vtkSocketCommunicatorHash vtkSocketCommunicatorHash.h make[2]: *** [VTK/Parallel/vtkSocketCommunicatorHash.h] Error 133 make[1]: *** [VTK/Parallel/CMakeFiles/vtkParallel.dir/all] Error 2 make: *** [all] Error 2 The issue is that the libraries do not have a full install_name on them which forces me to remember to "export DYLD_LIBRARY_PATH=`pwd`/bin" from the build folder. Can this be added to the CMake custom command for OS X? I seem to hit this error every time I do a fresh configure. | ||||||||
Additional Information | Mike proposed this change to VTK\Parallel\CMakeLists.txt that works for me, too: # Generate "vtkSocketCommunicatorHash.h". if (APPLE AND NOT VTK_USE_RPATH) file(WRITE ${ParaView_BINARY_DIR}/bin/vtkHashSource.sh "#!/bin/sh\n" ) file(APPEND ${ParaView_BINARY_DIR}/bin/vtkHashSource.sh "export DYLD_LIBRARY_PATH=${ParaView_BINARY_DIR}/bin\n" ) file(APPEND ${ParaView_BINARY_DIR}/bin/vtkHashSource.sh "cd ${ParaView_BINARY_DIR}/bin\n" ) file(APPEND ${ParaView_BINARY_DIR}/bin/vtkHashSource.sh "./vtkHashSource ${VTK_SOURCE_DIR}/Parallel/vtkSocketCommunicator.cxx vtkSocketCommunicatorHash ${VTK_BINARY_DIR}/Parallel/vtkSocketCommunicatorHash.h\n") ADD_CUSTOM_COMMAND( OUTPUT ${VTK_BINARY_DIR}/Parallel/vtkSocketCommunicatorHash.h DEPENDS ${ParaView_BINARY_DIR}/bin/vtkHashSource.sh ${VTK_SOURCE_DIR}/Parallel/vtkSocketCommunicator.cxx vtkHashSource COMMAND /bin/chmod ugo+rx ${ParaView_BINARY_DIR}/bin/vtkHashSource.sh COMMAND ${ParaView_BINARY_DIR}/bin/vtkHashSource.sh) else() ADD_CUSTOM_COMMAND( OUTPUT ${VTK_BINARY_DIR}/Parallel/vtkSocketCommunicatorHash.h DEPENDS ${VTK_SOURCE_DIR}/Parallel/vtkSocketCommunicator.cxx vtkHashSource COMMAND vtkHashSource ${VTK_SOURCE_DIR}/Parallel/vtkSocketCommunicator.cxx vtkSocketCommunicatorHash vtkSocketCommunicatorHash.h ) endif() | ||||||||
(0021667) Utkarsh Ayachit (administrator) 2010-08-05 13:38 |
Not an issue anymore. With ParaView 3.8.1 turning VTK_USE_RPATH OFF has been totally removed. "make install" as well as "cpack" ensure that the rpaths are stripped off correctly so we don't need to turn rpath OFF during building at all. |
(0022005) Alan Scott (manager) 2010-08-30 15:09 |
Closed as per Utkarsh's comment. |
2010-05-06 15:49 | Eric Monson | New Issue | |
2010-05-06 15:53 | David Partyka | Status | backlog => tabled |
2010-05-06 15:53 | David Partyka | Assigned To | => David Partyka |
2010-08-05 13:38 | Utkarsh Ayachit | Note Added: 0021667 | |
2010-08-05 13:38 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-08-05 13:38 | Utkarsh Ayachit | Fixed in Version | => 3.8.1 |
2010-08-05 13:38 | Utkarsh Ayachit | Resolution | open => won't fix |
2010-08-30 15:09 | Alan Scott | Note Added: 0022005 | |
2010-08-30 15:09 | Alan Scott | Status | @80@ => closed |
