0010697ParaViewBugpublic2010-05-10 10:272016-08-12 09:58
ReporterMathieu Malaterre
Assigned ToUtkarsh Ayachit
PrioritynormalSeveritymajorReproducibilityalways
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0010697: Locale-dependent number format in .pvd files
DescriptionI have a .pvd file with entries like
<DataSet timestep="9.62917e-10" group="" part="0" name="" file="./s0001:fdtd-00001.pvtu"/>
If a german locale (LANG=de_DE.UTF-8) is in effect, paraview reads the
timestep as the integer "9" without any diagnostic. If I replace the decimal
seperator in the data file with the german ",", like this:
<DataSet timestep="9,62917e-10" group="" part="0" name="" file="./s0001:fdtd-00001.pvtu"/>
then paraview reads the timestep correctly. If I leave the decimal seperator
in the data file as ".", but start paraview with LC_ALL=C, the timestep is
also read correctly. An example dataset is attached.
Note that the Calculator filter suffers from a similiar problem; any number
containing a decimal point is accepted, but anything after the point is
silently ignored.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0020694)
Mathieu Malaterre (reporter)
2010-05-10 10:29
This bug was forwarded from:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=567727 [^]
(0037825)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
 Issue History
2010-05-10 10:27 Mathieu Malaterre New Issue
2010-05-10 10:29 Mathieu Malaterre Note Added: 0020694
2011-09-07 04:04 Mathieu Malaterre Assigned To => Utkarsh Ayachit
2016-08-12 09:58 Kitware Robot Note Added: 0037825
2016-08-12 09:58 Kitware Robot Status expired => closed
2016-08-12 09:58 Kitware Robot Resolution open => moved
