| 0010698 | ParaView | Feature | public | 2010-05-10 10:42 | 2010-05-18 18:50 | ||||
| Status | closed | Resolution | won't fix | ||||||
| Product Version | |||||||||
| Target Version | 4.0 | Fixed in Version | |||||||
| Summary | 0010698: 3D widgets should have transform matching the input's transform | ||||||||
| Description | * Create Sphere * Change Scale to (5, 5, 1) on the display tab. * Create Slice (the 3D widget is not scaled) * Apply slice (the result is scaled correctly) Would be nice if the 3D widget would show up with the correct scale as well. Ref from mailing-list: http://www.paraview.org/pipermail/paraview/2010-May/017382.html [^] | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0020767) Utkarsh Ayachit (administrator) 2010-05-17 16:46 |
Ken's response on the mailing list: "Uh, hang on a second. I’m not sure bounding the clip filter by the bounds after the actor transform is a good idea. The problem is that the data will be clipped in the data’s original coordinates, not the coordinates after the transform. In the attached above, I z-scaled a wavelet image in the display panel and then applied the clip filter at some orientation. Notice that the actual clip does not match the plane at all." |
(0020789) Alan Scott (manager) 2010-05-18 18:50 |
We are not planning on implementing the fix for this bug, since the fix doesn't make sense in context. |
| Notes |
| Issue History | |||
| 2010-05-10 10:42 | Utkarsh Ayachit | New Issue | |
| 2010-05-17 16:46 | Utkarsh Ayachit | Note Added: 0020767 | |
| 2010-05-17 16:46 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2010-05-17 16:46 | Utkarsh Ayachit | Resolution | open => won't fix |
| 2010-05-17 16:46 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2010-05-18 18:50 | Alan Scott | Note Added: 0020789 | |
| 2010-05-18 18:50 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| Issue History |
