0010808 | ParaView | (No Category) | public | 2010-06-09 12:17 | 2016-08-12 09:58 | ||||
Reporter | Robert Maynard | ||||||||
Assigned To | Robert Maynard | ||||||||
Platform | OS | Windows 7 | OS Version | ||||||
Summary | 0010808: configuration of projects incorrect for non administrator accounts. | ||||||||
Description | When CMake is run without administrator privileges it incorrectly configures paraview. The symptoms include HAVE_FCNTL not being found, which is incorrect since if you run CMake as administrator it is found at: C:/Program Files (x86)/Microsoft Visual Studio 10.0/VC/include | ||||||||
(0020988) David Cole (viewer) 2010-06-11 09:24 |
Using this CMakeLists.txt file... =============================================================== cmake_minimum_required(VERSION 2.6) project(issue10808-simple-repro) include(CheckIncludeFiles) check_include_files(fcntl.h HAVE_FCNTL_H) message(STATUS "HAVE_FCNTL_H='${HAVE_FCNTL_H}'") =============================================================== ...works just fine as a non-admin user on Windows 7, with all combinations of Visual Studio 2008 or 2010, and CMake 2.6.4 or 2.8.1... Therefore: this bug only occurs with the more complex ParaView project for some reason. I will investigate what is happening specifically in a ParaView build tree and report back later. |
(0020990) David Cole (viewer) 2010-06-11 10:23 |
Running a findstr/grep on fcntl on the ParaView CMakeCache.txt yields this: C:\Users\blah\pvb1>findstr /I fcntl CMakeCache.txt ICE_HAVE_FCNTL:PATH=ICE_HAVE_FCNTL-NOTFOUND XDMF_HAVE_FCNTL:PATH=XDMF_HAVE_FCNTL-NOTFOUND //Have include HAVE_FCNTL_H HAVE_FCNTL_H:INTERNAL=1 //ADVANCED property for variable: ICE_HAVE_FCNTL ICE_HAVE_FCNTL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_FCNTL XDMF_HAVE_FCNTL-ADVANCED:INTERNAL=1 As you can see, HAVE_FCNTL_H is properly found: its value is 1. It is ICE_HAVE_FCNTL and XDMF_HAVE_FCNTL that appear to be "NOTFOUND"... I will dig into the Ice and Xdmf CMakeLists files next... |
(0020992) David Cole (viewer) 2010-06-11 11:39 |
I get identical results when running as an admin user... This is a "false alarm" report in terms of it being a CMake bug... C:\Users\davidcole\Dashboards\My Tests\pvb1>findstr /I fcntl CMakeCache.txt ICE_HAVE_FCNTL:PATH=ICE_HAVE_FCNTL-NOTFOUND XDMF_HAVE_FCNTL:PATH=XDMF_HAVE_FCNTL-NOTFOUND //Have include HAVE_FCNTL_H HAVE_FCNTL_H:INTERNAL=1 //ADVANCED property for variable: ICE_HAVE_FCNTL ICE_HAVE_FCNTL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_FCNTL XDMF_HAVE_FCNTL-ADVANCED:INTERNAL=1 The real culprit here is a ParaView (IceT/Xdmf2) bug. The CMake code in "ParaView\Utilities\Xdmf2\Ice\CMakeLists.txt" looks like this: Line 81: FIND_PATH(ICE_HAVE_FCNTL fcntl.h /usr/include /usr/include/sys) And in "ParaView\Utilities\Xdmf2\libsrc\CMakeLists.txt" like this: Line 353: FIND_PATH(XDMF_HAVE_FCNTL fcntl.h /usr/include /usr/include/sys) This is clearly *not* the cross-platform way to find fcntl.h and those code bases need to be fixed to work on Windows if they are intended to work on Windows. Any finding of an include file should use the typically accepted CMake/cross-platform pattern (as exemplified by my attempt at a simple-repro case for this bug): include(CheckIncludeFiles) check_include_files(fcntl.h HAVE_FCNTL_H) |
(0037834) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-06-09 12:17 | Robert Maynard | New Issue | |
2010-06-09 12:17 | Robert Maynard | Status | backlog => tabled |
2010-06-09 12:17 | Robert Maynard | Assigned To | => David Cole |
2010-06-11 09:24 | David Cole | Note Added: 0020988 | |
2010-06-11 10:23 | David Cole | Note Added: 0020990 | |
2010-06-11 11:39 | David Cole | Note Added: 0020992 | |
2010-06-11 11:39 | David Cole | Project | @2@ => ParaView |
2010-06-11 11:40 | David Cole | Assigned To | David Cole => Robert Maynard |
2011-06-16 13:10 | Zack Galbreath | Category | CMake => (No Category) |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037834 | |
2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
