0010891 | ParaView | Bug | public | 2010-06-25 05:31 | 2010-07-07 11:06 | ||||
Reporter | Paul Edwards | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Target Version | 3.10 | Fixed in Version | 3.10 | ||||||
Summary | 0010891: Crash with ribbon filter | ||||||||
Description | To reproduce: * line source * ribbon filter As soon as it is applied it crashes. This is on linux running master branch | ||||||||
Additional Information | It's sorting an array in this function: void vtkPVDataSetAttributesInformation ::CopyFromDataSetAttributes(vtkDataSetAttributes *da) and one of the elements is a null pointer. This was introduce here: http://paraview.org/gitweb?p=ParaView.git;a=commitdiff;h=3a808a21e550f895d313da6bd2533acc55a8840d [^] | ||||||||
(0021172) Utkarsh Ayachit (administrator) 2010-06-25 11:21 |
commit 370729f9bc399d984f37f5b2f6dea72ddba9dcdb Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Jun 25 11:15:36 2010 -0400 Fixed segfault when there was no array name (BUG 0010891). |
(0021173) Utkarsh Ayachit (administrator) 2010-06-25 11:21 |
must move to release branch |
(0021262) Alan Scott (manager) 2010-07-06 21:37 |
Assuming it will get moved to release. Tested trunk, local server, windows. |
(0021284) Utkarsh Ayachit (administrator) 2010-07-07 11:06 |
This bug was introduced by the following commit which is not on the 3.8 release branch and hence this fix does not need to be moved to that branch. commit 3a808a21e550f895d313da6bd2533acc55a8840d Author: Zhanping Liu <zhanping.liu@kitware.com> Date: Fri Apr 30 15:31:45 2010 -0400 Fixed bug 10327 to sort variables in ParaView UI. Now varaibles are alphabetically sorted in Object Inspector (three panels: Properties, Display, and Information). |
2010-06-25 05:31 | Paul Edwards | New Issue | |
2010-06-25 11:15 | Utkarsh Ayachit | Status | backlog => tabled |
2010-06-25 11:15 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-06-25 11:15 | Utkarsh Ayachit | Target Version | => 3.8.1 |
2010-06-25 11:21 | Utkarsh Ayachit | Note Added: 0021172 | |
2010-06-25 11:21 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-06-25 11:21 | Utkarsh Ayachit | Resolution | open => fixed |
2010-06-25 11:21 | Utkarsh Ayachit | Note Added: 0021173 | |
2010-07-06 21:37 | Alan Scott | Note Added: 0021262 | |
2010-07-06 21:37 | Alan Scott | Status | @80@ => closed |
2010-07-07 09:55 | Utkarsh Ayachit | Fixed in Version | => Development |
2010-07-07 11:06 | Utkarsh Ayachit | Note Added: 0021284 | |
2010-07-07 11:06 | Utkarsh Ayachit | Fixed in Version | Development => 3.10 |
2010-07-07 11:06 | Utkarsh Ayachit | Target Version | 3.8.1 => 3.10 |
