0010924 | ParaView | Bug | public | 2010-07-01 15:54 | 2010-07-06 21:31 | ||||
Target Version | 3.10 | Fixed in Version | |||||||
Summary | 0010924: Opacity no longer can be changed in the color editor. | ||||||||
Description | Opacity can no longer be changed in the color editor. I hear from a user that it use to be. Could it be added? ParaView 3.8.0, local server. Disk_out_ref.exo. Color by Temp. Color Editor. Note that you cannot change the opacity in this panel. | ||||||||
(0021210) Utkarsh Ayachit (administrator) 2010-07-01 16:05 |
Opacity can only be changed when you are volume rendering. Switch the representation type to volume render and you should be able to change opacity in the color editor. |
(0021261) Alan Scott (manager) 2010-07-06 21:31 |
Sounds fair. Closed. |
2010-07-01 15:54 | Alan Scott | New Issue | |
2010-07-01 16:05 | Utkarsh Ayachit | Note Added: 0021210 | |
2010-07-01 16:05 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-07-01 16:05 | Utkarsh Ayachit | Resolution | open => no change required |
2010-07-01 16:05 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-07-06 21:31 | Alan Scott | Note Added: 0021261 | |
2010-07-06 21:31 | Alan Scott | Status | @80@ => closed |
