0010946 | ParaView | Bug | public | 2010-07-06 21:42 | 2010-07-16 15:42 | ||||
Assigned To | Marcus D. Hanwell | ||||||||
Target Version | 3.10 | Fixed in Version | |||||||
Summary | 0010946: Set font button doesn't work for 2d plots | ||||||||
Description | Trunk, windows, local server * Wavelet. * Plot over Line * View Settings for the 2d plot. * Right Axis - Set Font. <bug> - nothing actually works on this panel. | ||||||||
(0021411) Marcus D. Hanwell (developer) 2010-07-16 14:23 |
I can try rebuilding, but these buttons work for both right and top axis here. I am able to change the font face, size, color. This is with master on Linux. If you think it might be a Windows specific error I can start a fresh build. I also tried the release branch, and this also works on there for me. Is this still an issue for you? You do need to click on apply for any of these settings to be pushed (or OK). |
(0021413) Alan Scott (manager) 2010-07-16 15:42 |
Not sure if this was reporter error, but it is fixed now. Note that instructions are incorrect - should have said "Left Axis - Set Font" Tested trunk, windows, local server. |
2010-07-06 21:42 | Alan Scott | New Issue | |
2010-07-13 23:11 | Marcus D. Hanwell | Status | backlog => tabled |
2010-07-13 23:11 | Marcus D. Hanwell | Assigned To | => Marcus D. Hanwell |
2010-07-16 14:23 | Marcus D. Hanwell | Note Added: 0021411 | |
2010-07-16 15:42 | Alan Scott | Note Added: 0021413 | |
2010-07-16 15:42 | Alan Scott | Status | tabled => closed |
2010-07-16 15:42 | Alan Scott | Resolution | open => fixed |
