For another project, please consult its home page to locate the current issue tracker.
0011038 | ParaView | Bug | public | 2010-07-26 15:34 | 2016-08-12 09:58 | ||||
Reporter | Koen van Mierlo | ||||||||
Priority | normal | Severity | trivial | Reproducibility | have not tried | ||||
Product Version | 3.8 | ||||||||
Summary | 0011038: rendering through OSmesa does not work on multiple nodes | ||||||||
Description | I compiled paraview 3.8 (pvbatch) without X and with OSmesa support to run on the university cluster. When I submit a pvbatch job it works fine on just 1 node of the cluster (max 8 procs) however the rendering goes wrong when using 2 or more nodes on the cluster. See the attached .png files. | ||||||||
Additional Information | I used the patched OSmesa 7.8.2 source from this location http://cgit.freedesktop.org/mesa/mesa/commit/?id=91c37599f621a0ec498c0f0add14f16470ca852b [^] | ||||||||
Attached Files | ![]() ![]() ![]() ![]() ![]() ![]() ![]() # This is the CMakeCache file. # For build in directory: /home/kvm/projects/ParaView-patch # It was generated by CMake: /home/kvm/cmake-2.8.2-Linux-i386/bin/cmake # You can edit this file to change values found and used by cmake. # If you do not want to change any of the values, simply exit the editor. # If you do want to change a value, simply edit, save, and exit the editor. # The syntax for the file is as follows: # KEY:TYPE=VALUE # KEY is the name of a variable in the cache. # TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!. # VALUE is the current value for the KEY. ######################## # EXTERNAL cache entries ######################## //Dependencies for the target AnalyzeReader_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Dependencies for the target AnalyzeWriter_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Build the documentation (Doxygen). BUILD_DOCUMENTATION:BOOL=OFF //Build ParaView examples. BUILD_EXAMPLES:BOOL=OFF //Build ICE-T with shared libraries. BUILD_SHARED_LIBS:BOOL=ON //Build the testing tree. BUILD_TESTING:BOOL=OFF //Path to a program. BZRCOMMAND:FILEPATH=BZRCOMMAND-NOTFOUND //Path to a program. CMAKE_AR:FILEPATH=/usr/bin/ar //For backwards compatibility, what version of CMake commands and // syntax should this version of CMake try to support. CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.4 //Choose the type of build, options are: None(CMAKE_CXX_FLAGS or // CMAKE_C_FLAGS used) Debug Release RelWithDebInfo MinSizeRel. CMAKE_BUILD_TYPE:STRING=Release //Enable/Disable color output during build. CMAKE_COLOR_MAKEFILE:BOOL=ON //CXX compiler. CMAKE_CXX_COMPILER:FILEPATH=/home/local/software/rh53/gcc/4.3.3/bin/c++ //Flags used by the compiler during all build types. CMAKE_CXX_FLAGS:STRING= //Flags used by the compiler during debug builds. CMAKE_CXX_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //C compiler. CMAKE_C_COMPILER:FILEPATH=/home/local/software/rh53/gcc/4.3.3/bin/gcc //Flags used by the compiler during all build types. CMAKE_C_FLAGS:STRING= //Flags used by the compiler during debug builds. CMAKE_C_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //Flags used by the linker. CMAKE_EXE_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Use HP pthreads. CMAKE_HP_PTHREADS:BOOL= //Install path prefix, prepended onto install directories. CMAKE_INSTALL_PREFIX:PATH=/usr/local //Path to a program. CMAKE_LINKER:FILEPATH=/usr/bin/ld //Path to a program. CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/gmake //Flags used by the linker during the creation of modules. CMAKE_MODULE_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Path to a program. CMAKE_NM:FILEPATH=/usr/bin/nm //Path to a program. CMAKE_OBJCOPY:FILEPATH=/usr/bin/objcopy //Path to a program. CMAKE_OBJDUMP:FILEPATH=/usr/bin/objdump //Value Computed by CMake CMAKE_PROJECT_NAME:STATIC=ParaView //Path to a program. CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib //Flags used by the linker during the creation of dll's. CMAKE_SHARED_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Path to a program. CMAKE_STRIP:FILEPATH=/usr/bin/strip //Thread library used. CMAKE_THREAD_LIBS:STRING=-lpthread //Use the pthreads library. CMAKE_USE_PTHREADS:BOOL=1 //If true, cmake will use relative paths in makefiles and projects. CMAKE_USE_RELATIVE_PATHS:BOOL=OFF //Use sproc libs. CMAKE_USE_SPROC:BOOL= //Use the win32 thread library. CMAKE_USE_WIN32_THREADS:BOOL= //If this value is on, makefiles will be generated without the // .SILENT directive, and all commands will be echoed to the console // during the make. This is useful for debugging only. With Visual // Studio IDE projects all commands are done without /nologo. CMAKE_VERBOSE_MAKEFILE:BOOL=FALSE //X11 extra flags. CMAKE_X_CFLAGS:STRING= //Libraries and options used in X11 programs. CMAKE_X_LIBS:STRING=/usr/lib64/libSM.so;/usr/lib64/libICE.so;/usr/lib64/libX11.so;/usr/lib64/libXext.so //Path to program used to compress files for transfer to the dart // server COMPRESSIONCOMMAND:FILEPATH=/bin/gzip //Path to the coverage program that CTest uses for performing coverage // inspection COVERAGE_COMMAND:FILEPATH=/home/local/software/rh53/gcc/4.3.3/bin/gcov //Enable to build Debian packages CPACK_BINARY_DEB:BOOL=OFF //Enable to build NSIS packages CPACK_BINARY_NSIS:BOOL=OFF //Enable to build RPM packages CPACK_BINARY_RPM:BOOL=OFF //Enable to build STGZ packages CPACK_BINARY_STGZ:BOOL=ON //Enable to build TBZ2 packages CPACK_BINARY_TBZ2:BOOL=OFF //Enable to build TGZ packages CPACK_BINARY_TGZ:BOOL=ON //Enable to build TZ packages CPACK_BINARY_TZ:BOOL=ON //Enable to build TBZ2 source packages CPACK_SOURCE_TBZ2:BOOL=ON //Enable to build TGZ source packages CPACK_SOURCE_TGZ:BOOL=ON //Enable to build TZ source packages CPACK_SOURCE_TZ:BOOL=ON //Enable to build ZIP source packages CPACK_SOURCE_ZIP:BOOL=OFF //Path to a program. CVSCOMMAND:FILEPATH=/usr/bin/cvs //Options passed to the cvs update command. CVS_UPDATE_OPTIONS:STRING=-d -A -P //Value Computed by CMake Cosmo_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/Cosmo //Dependencies for the target Cosmo_LIB_DEPENDS:STATIC=general;vtksys;general;vtkCommon;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so; //Value Computed by CMake Cosmo_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/Cosmo //Limit of reported errors, -1 reports all. DART_BUILD_ERROR_REPORT_LIMIT:BOOL=OFF //Limit of reported warnings, -1 reports all. DART_BUILD_WARNING_REPORT_LIMIT:BOOL=OFF //If you have Dart installed, where is it located? DART_ROOT:PATH=DART_ROOT-NOTFOUND //Maximum time allowed before CTest will kill the test. DART_TESTING_TIMEOUT:STRING=1500 //Show the actual output of the build, or if off show a . for each // 1024 bytes. DART_VERBOSE_BUILD:BOOL=OFF //Should Dart server send email when build errors are found in // Continuous builds? DELIVER_CONTINUOUS_EMAIL:BOOL=Off //Value Computed by CMake DICOMParser_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/DICOMParser //Value Computed by CMake DICOMParser_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/DICOMParser //Build mpi4py support to allow python filters to use mpi calls ENABLE_MPI4PY:BOOL=OFF //Path to a program. GITCOMMAND:FILEPATH=GITCOMMAND-NOTFOUND //Path to gunzip executable GUNZIPCOMMAND:FILEPATH=/bin/gunzip //Dependencies for the target H5PartReader_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Enable datasets larger than memory HDF5_ENABLE_HSIZET:BOOL=ON //Enable support for large (64-bit) files on Linux. HDF5_ENABLE_LINUX_LFS:BOOL=ON //Enable parallel build (uses MPI) HDF5_ENABLE_PARALLEL:BOOL=OFF //Compile Stream Virtual File Driver support HDF5_STREAM_VFD:BOOL=ON //Path to a program. HGCOMMAND:FILEPATH=HGCOMMAND-NOTFOUND //Value Computed by CMake ICET_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Utilities/IceT //Value Computed by CMake ICET_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Utilities/IceT //Value Computed by CMake ICE_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Utilities/Xdmf2/Ice //Path to a file. ICE_HAVE_FCNTL:PATH=/usr/include //Path to a file. ICE_HAVE_MMAN:PATH=/usr/include/sys //Path to a file. ICE_HAVE_NETINET:PATH=/usr/include/netinet //Value Computed by CMake ICE_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Utilities/Xdmf2/Ice //Path to java command, used by the Dart server to create html. JAVACOMMAND:FILEPATH=JAVACOMMAND-NOTFOUND //Value Computed by CMake KWCommon_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Common/KWCommon //Enable testing in KWCommon (if BUILD_TESTING is ON as well). KWCommon_BUILD_TESTING:BOOL=ON //Dependencies for the target KWCommon_LIB_DEPENDS:STATIC=general;vtkCommon;general;vtksys; //Value Computed by CMake KWCommon_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Common/KWCommon //Command to build the project MAKECOMMAND:STRING=/usr/bin/gmake -i //Value Computed by CMake MAPREDUCE_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/mrmpi //Value Computed by CMake MAPREDUCE_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/mrmpi //Path to the memory checking command, used for memory error detection. MEMORYCHECK_COMMAND:FILEPATH=/usr/bin/valgrind //File that contains suppressions for the memory checker MEMORYCHECK_SUPPRESSIONS_FILE:FILEPATH= //Executable for running MPI programs. MPIEXEC:FILEPATH=/home/local/software/rh53/openmpi/1.3.3/gcc/bin/mpiexec //Maximum number of processors available to run MPI applications. MPIEXEC_MAX_NUMPROCS:STRING=2 //Flag used by MPI to specify the number of processes for MPIEXEC; // the next option will be the number of processes. MPIEXEC_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIEXEC. MPIEXEC_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by MPIEXEC. MPIEXEC_PREFLAGS:STRING= //Dependencies for the target MPIPython_LIB_DEPENDS:STATIC=general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;/usr/lib64/libpython2.4.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so; //MPI compiler. Used only to detect MPI compilation flags. MPI_COMPILER:FILEPATH=/home/local/software/rh53/openmpi/1.3.3/gcc/bin/mpic++ //MPI compilation flags MPI_COMPILE_FLAGS:STRING= //Extra MPI libraries to link against MPI_EXTRA_LIBRARY:STRING=/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;/usr/lib64/libdl.so;/usr/lib64/libnsl.so;/usr/lib64/libutil.so;/usr/lib64/libm.so;/usr/lib64/libdl.so //MPI include path MPI_INCLUDE_PATH:STRING=/local/software/rh53/openmpi/1.3.3/gcc/include //MPI library to link against MPI_LIBRARY:FILEPATH=/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so //MPI linking flags MPI_LINK_FLAGS:STRING=-Wl,--export-dynamic //Dependencies for the target MapReduceMPI_LIB_DEPENDS:STATIC=general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so; //Value Computed by CMake MaterialLibrary_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/MaterialLibrary //Value Computed by CMake MaterialLibrary_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/MaterialLibrary //Dependencies for the target Moments_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Dependencies for the target NIfTIReader_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Dependencies for the target NIfTIWriter_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Path to a file. OPENGL_INCLUDE_DIR:PATH= //Path to a library. OPENGL_gl_LIBRARY:FILEPATH= //Path to a library. OPENGL_glu_LIBRARY:FILEPATH= //Path to a file. OPENGL_xmesa_INCLUDE_DIR:PATH= //Path to a file. OSMESA_INCLUDE_DIR:PATH=/home/kvm/Mesa-7.8.2-patch/include //Path to a library. OSMESA_LIBRARY:FILEPATH=/home/kvm/Mesa-7.8.2-patch/lib/libOSMesa.so //Build ParaView with enforced secure connection (--connect-id) PARAVIEW_ALWAYS_SECURE_CONNECTION:BOOL=OFF //Build Reader/Writer for Analyze and NIfTI. PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIReaderWriter:BOOL=ON //Build Reader for *.h5part files PARAVIEW_BUILD_PLUGIN_H5PartReader:BOOL=ON //Build Manta ray traced rendering PARAVIEW_BUILD_PLUGIN_Manta:BOOL=OFF //Build Filters for Flux and Circulation Fields PARAVIEW_BUILD_PLUGIN_Moments:BOOL=ON //Build NetDMF file format reader PARAVIEW_BUILD_PLUGIN_NetDMFReader:BOOL=OFF //Build Point Sprites PARAVIEW_BUILD_PLUGIN_PointSprite:BOOL=ON //Build Prism PARAVIEW_BUILD_PLUGIN_Prism:BOOL=ON //Build SLACTools PARAVIEW_BUILD_PLUGIN_SLACTools:BOOL=ON //Build SierraPlotTools PARAVIEW_BUILD_PLUGIN_SierraPlotTools:BOOL=ON //Build SurfaceLIC PARAVIEW_BUILD_PLUGIN_SurfaceLIC:BOOL=ON //Build VisItReaderPlugin PARAVIEW_BUILD_PLUGIN_VisItReaderPlugin:BOOL=OFF //Build pvblot PARAVIEW_BUILD_PLUGIN_pvblot:BOOL=ON //Build ParaView Qt Client. This requires Qt. PARAVIEW_BUILD_QT_GUI:BOOL=OFF //Build ParaView against the PVAdaptor private source library. // Requires Kitware License PARAVIEW_BUILD_WITH_ADAPTOR:BOOL=OFF //Path to a file. PARAVIEW_DATA_ROOT:PATH=PARAVIEW_DATA_ROOT-NOTFOUND //Disable VTK Testing PARAVIEW_DISABLE_VTK_TESTING:BOOL=OFF //Enable/Disable the CoProcessing library. PARAVIEW_ENABLE_COPROCESSING:BOOL=OFF //Build ParaView with Floating Point Exceptions turned on PARAVIEW_ENABLE_FPE:BOOL=OFF //Enable/Disable Python scripting support. PARAVIEW_ENABLE_PYTHON:BOOL=ON //Extra modules that ParaView will try to import. The modules have // to provide ParaViewImport.cmake file. PARAVIEW_EXTRA_EXTERNAL_MODULES:STRING= //Install ParaView plugin development files. PARAVIEW_INSTALL_DEVELOPMENT:BOOL=OFF //Compile paraview for minimum image PARAVIEW_MINIMAL_BUILD:BOOL=OFF //Build Python Testing support if PARAVIEW_ENABLE_PYTHON is ON PARAVIEW_TESTING_WITH_PYTHON:BOOL=ON //Use IceT multi display manager PARAVIEW_USE_ICE_T:BOOL=ON //Build ParaView with MPI support PARAVIEW_USE_MPI:BOOL=ON //Use MPI synchronous-send commands for communication PARAVIEW_USE_MPI_SSEND:BOOL=OFF //Use SILO library PARAVIEW_USE_SILO:BOOL=OFF //Use system installed HDF5 PARAVIEW_USE_SYSTEM_HDF5:BOOL=OFF //Does an external project define proj_list or should libproj4 // define it? PROJ_LIST_EXTERNAL:BOOL=OFF //Should libproj4 include projection code that relies on GSL? PROJ_USE_GSL:BOOL=OFF //Should libproj4 be built as a thread-friendly library? PROJ_USE_PTHREADS:BOOL=OFF //Value Computed by CMake PVFilters_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Servers/Filters //Value Computed by CMake PVFilters_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Servers/Filters //Value Computed by CMake PVServerCommon_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Servers/Common //Value Computed by CMake PVServerCommon_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Servers/Common //Value Computed by CMake PVServer_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Servers //Value Computed by CMake PVServer_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Servers //Value Computed by CMake PVServers_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Servers/Executables //Value Computed by CMake PVServers_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Servers/Executables //Command to run after a failed test to cleanup processes. Example: // "killall -9 rsh paraview" PV_TEST_CLEAN_COMMAND:STRING= //Node which serves as the client node, used to connect from the // server side in reverse connection mode. PV_TEST_CLIENT:STRING=localhost //Command to run before a test begins. Multiple commands are separated // by ';'. PV_TEST_INIT_COMMAND:STRING= //Add module MPIPython PYTHON_ENABLE_MODULE_MPIPython:BOOL=ON //Add module vtkChartsPython PYTHON_ENABLE_MODULE_vtkChartsPython:BOOL=ON //Add module vtkCommonPython PYTHON_ENABLE_MODULE_vtkCommonPython:BOOL=ON //Add module vtkFilteringPython PYTHON_ENABLE_MODULE_vtkFilteringPython:BOOL=ON //Add module vtkGenericFilteringPython PYTHON_ENABLE_MODULE_vtkGenericFilteringPython:BOOL=ON //Add module vtkGeovisPython PYTHON_ENABLE_MODULE_vtkGeovisPython:BOOL=ON //Add module vtkGraphicsPython PYTHON_ENABLE_MODULE_vtkGraphicsPython:BOOL=ON //Add module vtkHybridPython PYTHON_ENABLE_MODULE_vtkHybridPython:BOOL=ON //Add module vtkIOPython PYTHON_ENABLE_MODULE_vtkIOPython:BOOL=ON //Add module vtkImagingPython PYTHON_ENABLE_MODULE_vtkImagingPython:BOOL=ON //Add module vtkInfovisPython PYTHON_ENABLE_MODULE_vtkInfovisPython:BOOL=ON //Add module vtkPVFiltersPython PYTHON_ENABLE_MODULE_vtkPVFiltersPython:BOOL=ON //Add module vtkPVServerCommonPython PYTHON_ENABLE_MODULE_vtkPVServerCommonPython:BOOL=ON //Add module vtkPVServerManagerPython PYTHON_ENABLE_MODULE_vtkPVServerManagerPython:BOOL=ON //Add module vtkParallelPython PYTHON_ENABLE_MODULE_vtkParallelPython:BOOL=ON //Add module vtkRenderingPython PYTHON_ENABLE_MODULE_vtkRenderingPython:BOOL=ON //Add module vtkViewsPython PYTHON_ENABLE_MODULE_vtkViewsPython:BOOL=ON //Add module vtkVolumeRenderingPython PYTHON_ENABLE_MODULE_vtkVolumeRenderingPython:BOOL=ON //Add module vtkWidgetsPython PYTHON_ENABLE_MODULE_vtkWidgetsPython:BOOL=ON //Path to a program. PYTHON_EXECUTABLE:FILEPATH=/usr/bin/python2.4 //Extra libraries to link when linking to python (such as "z" for // zlib). Separate multiple libraries with semicolons. PYTHON_EXTRA_LIBS:STRING= //Path to a file. PYTHON_INCLUDE_DIR:PATH=/usr/include/python2.4 //Path to a library. PYTHON_LIBRARY:FILEPATH=/usr/lib64/libpython2.4.so //Add module MPIPython shared PYTHON_MODULE_MPIPython_BUILD_SHARED:BOOL=ON //Add module vtkChartsPython shared PYTHON_MODULE_vtkChartsPython_BUILD_SHARED:BOOL=ON //Add module vtkCommonPython shared PYTHON_MODULE_vtkCommonPython_BUILD_SHARED:BOOL=ON //Add module vtkFilteringPython shared PYTHON_MODULE_vtkFilteringPython_BUILD_SHARED:BOOL=ON //Add module vtkGenericFilteringPython shared PYTHON_MODULE_vtkGenericFilteringPython_BUILD_SHARED:BOOL=ON //Add module vtkGeovisPython shared PYTHON_MODULE_vtkGeovisPython_BUILD_SHARED:BOOL=ON //Add module vtkGraphicsPython shared PYTHON_MODULE_vtkGraphicsPython_BUILD_SHARED:BOOL=ON //Add module vtkHybridPython shared PYTHON_MODULE_vtkHybridPython_BUILD_SHARED:BOOL=ON //Add module vtkIOPython shared PYTHON_MODULE_vtkIOPython_BUILD_SHARED:BOOL=ON //Add module vtkImagingPython shared PYTHON_MODULE_vtkImagingPython_BUILD_SHARED:BOOL=ON //Add module vtkInfovisPython shared PYTHON_MODULE_vtkInfovisPython_BUILD_SHARED:BOOL=ON //Add module vtkPVFiltersPython shared PYTHON_MODULE_vtkPVFiltersPython_BUILD_SHARED:BOOL=ON //Add module vtkPVServerCommonPython shared PYTHON_MODULE_vtkPVServerCommonPython_BUILD_SHARED:BOOL=ON //Add module vtkPVServerManagerPython shared PYTHON_MODULE_vtkPVServerManagerPython_BUILD_SHARED:BOOL=ON //Add module vtkParallelPython shared PYTHON_MODULE_vtkParallelPython_BUILD_SHARED:BOOL=ON //Add module vtkRenderingPython shared PYTHON_MODULE_vtkRenderingPython_BUILD_SHARED:BOOL=ON //Add module vtkViewsPython shared PYTHON_MODULE_vtkViewsPython_BUILD_SHARED:BOOL=ON //Add module vtkVolumeRenderingPython shared PYTHON_MODULE_vtkVolumeRenderingPython_BUILD_SHARED:BOOL=ON //Add module vtkWidgetsPython shared PYTHON_MODULE_vtkWidgetsPython_BUILD_SHARED:BOOL=ON //Utility library needed for vtkpython PYTHON_UTIL_LIBRARY:FILEPATH=/usr/lib64/libutil.so //Value Computed by CMake ParaView_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch //Value Computed by CMake ParaView_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0 //Value Computed by CMake PointSpritePlugin_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Plugins/PointSprite //Build the example. PointSpritePlugin_BUILD_EXAMPLES:BOOL=ON //Value Computed by CMake PointSpritePlugin_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Plugins/PointSprite //Dependencies for the target PointSprite_Graphics_LIB_DEPENDS:STATIC=general;vtkGraphics; //Dependencies for the target PointSprite_Plugin_LIB_DEPENDS:STATIC=general;vtkPVServerManager;general;PointSprite_Rendering;general;PointSprite_Graphics; //Dependencies for the target PointSprite_Rendering_LIB_DEPENDS:STATIC=general;vtkHybrid;general;vtkRendering;general;vtkImaging; //Dependencies for the target PrismServerPlugin_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Invalid qmake found QT_QMAKE_EXECUTABLE:FILEPATH=QT_QMAKE_EXECUTABLE-NOTFOUND-NOTFOUND //Path to a file. QT_QTDESIGNER_INCLUDE_DIR:PATH=QT_QTDESIGNER_INCLUDE_DIR-NOTFOUND //Path to scp command, used by CTest for submitting results to // a Dart server SCPCOMMAND:FILEPATH=/usr/bin/scp //Name of the computer/site where compile is being run SITE:STRING=blue33 //Dependencies for the target SLACTools_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Path to the SLURM sbatch executable SLURM_SBATCH_COMMAND:FILEPATH=SLURM_SBATCH_COMMAND-NOTFOUND //Path to the SLURM srun executable SLURM_SRUN_COMMAND:FILEPATH=SLURM_SRUN_COMMAND-NOTFOUND //Path to a program. SVNCOMMAND:FILEPATH=/usr/bin/svn //Value Computed by CMake ServerManager_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Servers/ServerManager //Value Computed by CMake ServerManager_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Servers/ServerManager //Build the 2007 Verdict User Manual VERDICT_BUILD_DOC:BOOL=OFF //Should tests of the VERDICT library be built? VERDICT_ENABLE_TESTING:BOOL=OFF //Mangle verdict names for inclusion in a larger library? VERDICT_MANGLE:BOOL=ON //VTK requires the verdict prefix to be vtk VERDICT_MANGLE_PREFIX:STRING=vtk //VTK requires doubles VERDICT_USE_FLOAT:BOOL=OFF //Path to a library. VLI_LIBRARY_FOR_VP1000:FILEPATH=VLI_LIBRARY_FOR_VP1000-NOTFOUND //Value Computed by CMake VPIC_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/VPIC //Dependencies for the target VPIC_LIB_DEPENDS:STATIC=general;vtksys; //Value Computed by CMake VPIC_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/VPIC //Value Computed by CMake VTKCS_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Utilities/VTKClientServer //Value Computed by CMake VTKCS_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Utilities/VTKClientServer //Value Computed by CMake VTKEXPAT_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtkexpat //Value Computed by CMake VTKEXPAT_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtkexpat //Value Computed by CMake VTKFREETYPE_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtkfreetype //Value Computed by CMake VTKFREETYPE_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtkfreetype //Value Computed by CMake VTKFTGL_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/ftgl //Value Computed by CMake VTKFTGL_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/ftgl //Value Computed by CMake VTKHDF5_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Utilities/hdf5 //Value Computed by CMake VTKHDF5_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Utilities/hdf5 //Value Computed by CMake VTKJPEG_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtkjpeg //Value Computed by CMake VTKJPEG_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtkjpeg //Value Computed by CMake VTKNETCDF_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtknetcdf //Value Computed by CMake VTKNETCDF_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtknetcdf //Value Computed by CMake VTKPNG_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtkpng //Value Computed by CMake VTKPNG_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtkpng //Value Computed by CMake VTKPythonWrapping_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Utilities/VTKPythonWrapping //Value Computed by CMake VTKPythonWrapping_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Utilities/VTKPythonWrapping //Value Computed by CMake VTKTIFF_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtktiff //Value Computed by CMake VTKTIFF_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtktiff //Value Computed by CMake VTKZLIB_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtkzlib //Value Computed by CMake VTKZLIB_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtkzlib //Value Computed by CMake VTK_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK //Path to a file. VTK_DATA_ROOT:PATH=VTK_DATA_ROOT-NOTFOUND //Build leak checking support into VTK. VTK_DEBUG_LEAKS:BOOL=OFF //Add compiler flags to do stricter checking when building debug. VTK_EXTRA_COMPILER_WARNINGS:BOOL=OFF //Location of the OpenGL extensions header file (glext.h). VTK_GLEXT_FILE:FILEPATH=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/ParseOGLExt/headers/glext.h //Location of the GLX extensions header file (glxext.h). VTK_GLXEXT_FILE:FILEPATH=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/ParseOGLExt/headers/glxext.h //Path to a file. VTK_LARGE_DATA_ROOT:PATH=VTK_LARGE_DATA_ROOT-NOTFOUND //Remove all legacy code completely. VTK_LEGACY_REMOVE:BOOL=OFF //Silence all legacy code messages. VTK_LEGACY_SILENT:BOOL=OFF //; separated directories to search for materials/shaders VTK_MATERIALS_DIRS:STRING=/home/kvm/projects/ParaView-patch/VTK/Utilities/MaterialLibrary/Repository //Path to a program. VTK_MPIRUN_EXE:FILEPATH=/home/local/software/rh53/openmpi/1.3.3/gcc/bin/mpiexec //Maximum number of processors available to run parallel applications. // (see /home/kvm/projects/ParaView-3.8.0/VTK/CMakeLists.txt for // more info.) VTK_MPI_MAX_NUMPROCS:STRING=2 //Flag used by mpi to specify the number of processes, the next // option will be the number of processes. (see /home/kvm/projects/ParaView-3.8.0/VTK/CMakeLists.txt // for more info.) VTK_MPI_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIRun.(see /home/kvm/projects/ParaView-3.8.0/VTK/CMakeLists.txt // for more info.) VTK_MPI_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by VTK_MPIRUN_EXE. (see /home/kvm/projects/ParaView-3.8.0/VTK/CMakeLists.txt // for more info.) VTK_MPI_PREFLAGS:STRING= //These flags will be directly before the number of processess // flag (see /home/kvm/projects/ParaView-3.8.0/VTK/CMakeLists.txt // for more info.) VTK_MPI_PRENUMPROC_FLAGS:STRING= //Forced to ON since neither OPEN_gl_LIBRARY nor MangledMesa were // found VTK_OPENGL_HAS_OSMESA:BOOL=ON //Value Computed by CMake VTK_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK //Locale for VTK C++ tests. Example fr_FR.utf8, empty string for // env variable. VTK_TESTING_LOCALE:STRING= //VTK tests call vtkFloatingPointExceptions::Enable() VTK_TESTING_USE_FPE:BOOL=ON //VTK c++ tests will start with specified locale. VTK_TESTING_USE_LOCALE:BOOL=OFF //Build VTK with 64 bit ids VTK_USE_64BIT_IDS:BOOL=ON //Use Boost libraries for graph algorithms - www.boost.org. VTK_USE_BOOST:BOOL=OFF //Build pixel and vertex shader support for Cg. VTK_USE_CG_SHADERS:BOOL=OFF //Build VTK chart support (OpenGL based) VTK_USE_CHARTS:BOOL=ON //Turn this option off and tests and warning/error macros will // not popup windows VTK_USE_DISPLAY:BOOL=OFF //If the FFMPEG library is available, should VTK use it for saving // .avi animation files? VTK_USE_FFMPEG_ENCODER:BOOL=OFF //Use GCC visibility support if available. VTK_USE_GCC_VISIBILITY:BOOL=ON //Build the vtkGeovis kit. Needed for performing geographic visualization. VTK_USE_GEOVIS:BOOL=ON //Build VTK with gl2ps support. VTK_USE_GL2PS:BOOL=OFF //Build pixel and vertex shader support for GLSL. VTK_USE_GLSL_SHADERS:BOOL=ON //Use Gnu R interface for VTK. Requires Gnu R installation. VTK_USE_GNU_R:BOOL=OFF //Build VTK with GUI Support VTK_USE_GUISUPPORT:BOOL=OFF //Build the vtkInfovis kit. Needed for performing information // visualization. VTK_USE_INFOVIS:BOOL=ON //Use mangled Mesa with OpenGL. VTK_USE_MANGLED_MESA:BOOL=OFF //Use Matlab Engine and Matlab Mex files. Requires valid Matlab // installation. VTK_USE_MATLAB_MEX:BOOL=OFF //Build metaio VTK_USE_METAIO:BOOL=ON //Enable use of the patented mpeg2 library. You are solely responsible // for any legal issues associated with using patented code in // your software. VTK_USE_MPEG2_ENCODER:BOOL=OFF //Build the MySQL driver for vtkSQLDatabase. VTK_USE_MYSQL:BOOL=OFF //Use NVIDIAs X server extension NVCONTROL. VTK_USE_NVCONTROL:BOOL=OFF //Add support for arbitrary-dimension sparse and dense arrays. VTK_USE_N_WAY_ARRAYS:BOOL=ON //Build the ODBC database interface VTK_USE_ODBC:BOOL=OFF //Use off screen calls by default. VTK_USE_OFFSCREEN:BOOL=ON //Build experimental Ogg/Theora support VTK_USE_OGGTHEORA_ENCODER:BOOL=OFF //Build the PostgreSQL driver for vtkSQLDatabase. VTK_USE_POSTGRES:BOOL=OFF //Build Qt support VTK_USE_QT:BOOL=OFF //Use QtOpenGL in QVTK VTK_USE_QVTK_QTOPENGL:BOOL=OFF //Build shared libraries with rpath. This makes it easy to run // executables from the build tree when using shared libraries, // but removes install support. VTK_USE_RPATH:BOOL=ON //Use the system's expat library. VTK_USE_SYSTEM_EXPAT:BOOL=OFF //Use the system's freetype library. VTK_USE_SYSTEM_FREETYPE:BOOL=OFF //Use the system's jpeg library. VTK_USE_SYSTEM_JPEG:BOOL=OFF //Use the system's proj4 library. VTK_USE_SYSTEM_LIBPROJ4:BOOL=OFF //Use the system's libxml2 library. VTK_USE_SYSTEM_LIBXML2:BOOL=OFF //Use the system's png library. VTK_USE_SYSTEM_PNG:BOOL=OFF //Use the system's tiff library. VTK_USE_SYSTEM_TIFF:BOOL=OFF //Use the system's zlib library. VTK_USE_SYSTEM_ZLIB:BOOL=OFF //Use 3Dconnexion device VTK_USE_TDX:BOOL=OFF //Build the vtkTextAnalysis kit. Needed for performing text analysis. VTK_USE_TEXT_ANALYSIS:BOOL=OFF //Build VTK with Tk support VTK_USE_TK:BOOL=OFF //Build the vtkViews kit. Needed for creating packaged and linked // views. VTK_USE_VIEWS:BOOL=ON //Enable support for VolumePro 1000. VTK_USE_VOLUMEPRO_1000:BOOL=OFF //Build classes for the X11 window system. VTK_USE_X:BOOL=OFF //Location of the WGL extensions header file (wglext.h). VTK_WGLEXT_FILE:FILEPATH=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/ParseOGLExt/headers/wglext.h //Path to a file. VTK_WRAP_HINTS:FILEPATH=/home/kvm/projects/ParaView-3.8.0/VTK/Wrapping/hints //Wrap VTK classes into the Java language. VTK_WRAP_JAVA:BOOL=OFF //Path to a file. X11_ICE_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_ICE_LIB:FILEPATH=/usr/lib64/libICE.so //Path to a library. X11_SM_LIB:FILEPATH=/usr/lib64/libSM.so //Path to a file. X11_X11_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_X11_LIB:FILEPATH=/usr/lib64/libX11.so //Path to a file. X11_XShm_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_XTest_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_XTest_LIB:FILEPATH=/usr/lib64/libXtst.so //Path to a file. X11_Xaccessrules_INCLUDE_PATH:PATH=X11_Xaccessrules_INCLUDE_PATH-NOTFOUND //Path to a file. X11_Xaccessstr_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xau_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xau_LIB:FILEPATH=/usr/lib64/libXau.so //Path to a file. X11_Xcomposite_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xcomposite_LIB:FILEPATH=/usr/lib64/libXcomposite.so //Path to a file. X11_Xcursor_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xcursor_LIB:FILEPATH=/usr/lib64/libXcursor.so //Path to a file. X11_Xdamage_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xdamage_LIB:FILEPATH=/usr/lib64/libXdamage.so //Path to a file. X11_Xdmcp_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xdmcp_LIB:FILEPATH=/usr/lib64/libXdmcp.so //Path to a library. X11_Xext_LIB:FILEPATH=/usr/lib64/libXext.so //Path to a file. X11_Xfixes_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xfixes_LIB:FILEPATH=/usr/lib64/libXfixes.so //Path to a file. X11_Xft_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xft_LIB:FILEPATH=/usr/lib64/libXft.so //Path to a file. X11_Xi_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xi_LIB:FILEPATH=/usr/lib64/libXi.so //Path to a file. X11_Xinerama_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xinerama_LIB:FILEPATH=/usr/lib64/libXinerama.so //Path to a file. X11_Xinput_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xinput_LIB:FILEPATH=/usr/lib64/libXi.so //Path to a file. X11_Xkb_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xkblib_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xlib_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xpm_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xpm_LIB:FILEPATH=/usr/lib64/libXpm.so //Path to a file. X11_Xrandr_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xrandr_LIB:FILEPATH=/usr/lib64/libXrandr.so //Path to a file. X11_Xrender_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xrender_LIB:FILEPATH=/usr/lib64/libXrender.so //Path to a file. X11_Xscreensaver_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xscreensaver_LIB:FILEPATH=/usr/lib64/libXss.so //Path to a file. X11_Xshape_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xt_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xt_LIB:FILEPATH=/usr/lib64/libXt.so //Path to a file. X11_Xutil_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xv_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xv_LIB:FILEPATH=/usr/lib64/libXv.so //Path to a library. X11_Xxf86misc_LIB:FILEPATH=/usr/lib64/libXxf86misc.so //Path to a file. X11_dpms_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_xf86misc_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_xf86vmode_INCLUDE_PATH:PATH=/usr/include //Build Xdmf Utilities XDMF_BUILD_UTILS:BOOL=OFF //XDMF has Network Distributed Global Memory (NDGM) XDMF_HAS_NDGM:BOOL=OFF //Path to a file. XDMF_HAVE_FCNTL:PATH=/usr/include //Path to a file. XDMF_HAVE_MMAN:PATH=/usr/include/sys //Path to a file. XDMF_HAVE_NETINET:PATH=/usr/include/netinet //Use bzip2 XDMF_USE_BZIP2:BOOL=OFF //Build GZip Compression XDMF_USE_GZIP:BOOL=OFF //Build Support for MySQL DataItems XDMF_USE_MYSQL:BOOL=OFF //Build a C# wrapping interface XDMF_WRAP_CSHARP:BOOL=OFF //Build a Python wrapping interface XDMF_WRAP_PYTHON:BOOL=OFF //Value Computed by CMake Xdmf_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Utilities/Xdmf2 //Dependencies for the target Xdmf_LIB_DEPENDS:STATIC=general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;vtkhdf5;general;vtklibxml2; //Value Computed by CMake Xdmf_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Utilities/Xdmf2 //Value Computed by CMake alglib_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtkalglib //Value Computed by CMake alglib_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtkalglib //Dependencies for the target icet_LIB_DEPENDS:STATIC=general;/home/kvm/Mesa-7.8.2-patch/lib/libOSMesa.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so; //Dependencies for the target icet_mpi_LIB_DEPENDS:STATIC=general;/home/kvm/Mesa-7.8.2-patch/lib/libOSMesa.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so;general;icet; //Dependencies for the target icet_strategies_LIB_DEPENDS:STATIC=general;/home/kvm/Mesa-7.8.2-patch/lib/libOSMesa.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so;general;icet; //Value Computed by CMake libproj4_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtklibproj4 //Value Computed by CMake libproj4_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtklibproj4 //Value Computed by CMake mpi4py_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/Utilities/mpi4py //Value Computed by CMake mpi4py_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/Utilities/mpi4py //Dependencies for the target mpistubs_LIB_DEPENDS:STATIC=general;vtksys; //Dependencies for the target pvblot_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Value Computed by CMake verdict_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/verdict //Value Computed by CMake verdict_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/verdict //Dependencies for the target vtkChartsPythonD_LIB_DEPENDS:STATIC=general;vtkCharts;general;vtkHybridPythonD;general;vtkViewsPythonD; //Dependencies for the target vtkChartsPython_LIB_DEPENDS:STATIC=general;vtkChartsPythonD; //Dependencies for the target vtkCharts_LIB_DEPENDS:STATIC=general;vtkHybrid;general;vtkViews;general;vtkIO;general;vtkftgl;general;vtkfreetype; //Dependencies for the target vtkClientServer_LIB_DEPENDS:STATIC=general;vtkCommon; //Dependencies for the target vtkCommonCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommon; //Dependencies for the target vtkCommonPythonD_LIB_DEPENDS:STATIC=general;vtkCommon; //Dependencies for the target vtkCommonPython_LIB_DEPENDS:STATIC=general;vtkCommonPythonD; //Dependencies for the target vtkCommon_LIB_DEPENDS:STATIC=general;vtksys;general;-lm;general;-lpthread;general;dl; //Dependencies for target vtkDICOMParser_LIB_DEPENDS:STATIC= //Value Computed by CMake vtkExodus2_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtkexodus2 //Value Computed by CMake vtkExodus2_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtkexodus2 //Dependencies for the target vtkFilteringCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltering;general;vtkCommonCS; //Dependencies for the target vtkFilteringPythonD_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkCommonPythonD; //Dependencies for the target vtkFilteringPython_LIB_DEPENDS:STATIC=general;vtkFilteringPythonD; //Dependencies for the target vtkFiltering_LIB_DEPENDS:STATIC=general;vtkCommon; //Dependencies for the target vtkGenericFilteringCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkGenericFiltering;general;vtkFilteringCS; //Dependencies for the target vtkGenericFilteringPythonD_LIB_DEPENDS:STATIC=general;vtkGenericFiltering;general;vtkFilteringPythonD;general;vtkGraphicsPythonD; //Dependencies for the target vtkGenericFilteringPython_LIB_DEPENDS:STATIC=general;vtkGenericFilteringPythonD; //Dependencies for the target vtkGenericFiltering_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkGraphics; //Dependencies for the target vtkGeovisPythonD_LIB_DEPENDS:STATIC=general;vtkGeovis;general;vtkWidgetsPythonD;general;vtkViewsPythonD; //Dependencies for the target vtkGeovisPython_LIB_DEPENDS:STATIC=general;vtkGeovisPythonD; //Dependencies for the target vtkGeovis_LIB_DEPENDS:STATIC=general;vtkWidgets;general;vtkViews;general;vtkproj4; //Dependencies for the target vtkGraphicsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkGraphics;general;vtkFilteringCS;general;vtkIOCS; //Dependencies for the target vtkGraphicsPythonD_LIB_DEPENDS:STATIC=general;vtkGraphics;general;vtkFilteringPythonD; //Dependencies for the target vtkGraphicsPython_LIB_DEPENDS:STATIC=general;vtkGraphicsPythonD; //Dependencies for the target vtkGraphics_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkverdict; //Dependencies for the target vtkHybridCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkHybrid;general;vtkRenderingCS;general;vtkParallelCS; //Dependencies for the target vtkHybridPythonD_LIB_DEPENDS:STATIC=general;vtkHybrid;general;vtkRenderingPythonD;general;vtkIOPythonD; //Dependencies for the target vtkHybridPython_LIB_DEPENDS:STATIC=general;vtkHybridPythonD; //Dependencies for the target vtkHybrid_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO;general;vtkParallel;general;vtkexoIIc;general;vtkftgl; //Dependencies for the target vtkIOCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIO;general;vtkFilteringCS; //Dependencies for the target vtkIOPythonD_LIB_DEPENDS:STATIC=general;vtkIO;general;vtkFilteringPythonD; //Dependencies for the target vtkIOPython_LIB_DEPENDS:STATIC=general;vtkIOPythonD; //Dependencies for the target vtkIO_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkDICOMParser;general;vtkNetCDF;general;vtkmetaio;general;vtksqlite;general;vtkpng;general;vtkzlib;general;vtkjpeg;general;vtktiff;general;vtkexpat;general;vtksys; //Dependencies for the target vtkImagingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImaging;general;vtkFilteringCS; //Dependencies for the target vtkImagingPythonD_LIB_DEPENDS:STATIC=general;vtkImaging;general;vtkFilteringPythonD; //Dependencies for the target vtkImagingPython_LIB_DEPENDS:STATIC=general;vtkImagingPythonD; //Dependencies for the target vtkImaging_LIB_DEPENDS:STATIC=general;vtkFiltering; //Dependencies for the target vtkInfovisCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkInfovis;general;vtkFilteringCS;general;vtkRenderingCS;general;vtkParallelCS; //Dependencies for the target vtkInfovisPythonD_LIB_DEPENDS:STATIC=general;vtkInfovis;general;vtkWidgetsPythonD; //Dependencies for the target vtkInfovisPython_LIB_DEPENDS:STATIC=general;vtkInfovisPythonD; //Dependencies for the target vtkInfovis_LIB_DEPENDS:STATIC=general;vtkWidgets;general;vtkParallel;general;vtklibxml2;general;vtkalglib; //Dependencies for target vtkNetCDF_LIB_DEPENDS:STATIC= //Dependencies for the target vtkPVCommandOptions_LIB_DEPENDS:STATIC=general;vtkIO; //Dependencies for the target vtkPVFiltersCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVFilters;general;vtkParallelCS;general;vtkHybridCS;general;vtkRenderingCS;general;vtkVolumeRenderingCS;general;vtkWidgetsCS; //Dependencies for the target vtkPVFiltersPythonD_LIB_DEPENDS:STATIC=general;vtkPVFilters;general;vtkPVFilters;general;vtkPVServerCommonPythonD;general;vtkPVFiltersCS;general;vtkRenderingPythonD;general;vtkWidgetsPythonD;general;vtkParallelPythonD; //Dependencies for the target vtkPVFiltersPython_LIB_DEPENDS:STATIC=general;vtkPVFiltersPythonD; //Dependencies for the target vtkPVFilters_LIB_DEPENDS:STATIC=general;vtkPVServerCommon;general;vtkPVServerCommonCS;general;vtkXdmfCS;general;vtkHybridCS;general;vtkParallelCS;general;vtkVolumeRenderingCS;general;vtkWidgetsCS;general;KWCommon;general;vtksys;general;/usr/lib64/libpython2.4.so;general;vtkPVPythonInterpretor;general;vtkhdf5;general;vtkClientServer;general;icet;general;icet_mpi;general;icet_strategies; //Dependencies for the target vtkPVPythonInterpretor_LIB_DEPENDS:STATIC=general;vtkCommon;general;/usr/lib64/libpython2.4.so;general;/usr/lib64/libutil.so; //Dependencies for the target vtkPVPython_LIB_DEPENDS:STATIC=general;vtkPVServerManagerPythonD;general;vtkCommon;general;vtkFiltering;general;vtkIO;general;vtkGraphics;general;vtkImaging;general;vtkPVPythonInterpretor;general;/usr/lib64/libpython2.4.so;general;/usr/lib64/libutil.so; //Dependencies for the target vtkPVServerCommonCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerCommon;general;vtkParallelCS;general;vtkHybridCS;general;vtkRenderingCS; //Dependencies for the target vtkPVServerCommonPythonD_LIB_DEPENDS:STATIC=general;vtkPVServerCommon;general;vtkCommonPythonD;general;vtkFilteringPythonD;general;vtkIOPythonD;general;vtkPVServerCommon;general;vtkPVServerCommonCS; //Dependencies for the target vtkPVServerCommonPython_LIB_DEPENDS:STATIC=general;vtkPVServerCommonPythonD; //Dependencies for the target vtkPVServerCommon_LIB_DEPENDS:STATIC=general;vtkHybridCS;general;vtkParallelCS;general;vtkInfovisCS;general;KWCommon;general;vtksys;general;vtkhdf5;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so;general;vtkClientServer;general;vtkPVCommandOptions; //Dependencies for the target vtkPVServerManagerPythonD_LIB_DEPENDS:STATIC=general;vtkPVServerManager;general;vtkPVServerCommonPythonD;general;vtkPVServerManager; //Dependencies for the target vtkPVServerManagerPython_LIB_DEPENDS:STATIC=general;vtkPVServerManagerPythonD; //Dependencies for the target vtkPVServerManager_LIB_DEPENDS:STATIC=general;vtkPVFiltersCS;general;vtkClientServer;general;KWCommon;general;vtkXdmfCS;general;vtkXdmf; //Dependencies for the target vtkParallelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkParallel;general;vtkRenderingCS; //Dependencies for the target vtkParallelPythonD_LIB_DEPENDS:STATIC=general;vtkParallel;general;vtkRenderingPythonD;general;vtkIOPythonD; //Dependencies for the target vtkParallelPython_LIB_DEPENDS:STATIC=general;vtkParallelPythonD; //Dependencies for the target vtkParallel_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO;general;VPIC;general;Cosmo;general;vtkexoIIc;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-rte.so;general;/local/software/rh53/openmpi/1.3.3/gcc/lib/libopen-pal.so;general;/usr/lib64/libdl.so;general;/usr/lib64/libnsl.so;general;/usr/lib64/libutil.so;general;/usr/lib64/libm.so;general;/usr/lib64/libdl.so; //Dependencies for the target vtkRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRendering;general;vtkGenericFilteringCS;general;vtkGraphicsCS;general;vtkImagingCS;general;vtkIOCS; //Dependencies for the target vtkRenderingPythonD_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkGraphicsPythonD;general;vtkImagingPythonD; //Dependencies for the target vtkRenderingPython_LIB_DEPENDS:STATIC=general;vtkRenderingPythonD; //Dependencies for the target vtkRendering_LIB_DEPENDS:STATIC=general;vtkGraphics;general;vtkImaging;general;vtkIO;general;vtkftgl;general;vtkfreetype;general;/home/kvm/Mesa-7.8.2-patch/lib/libOSMesa.so;general;/home/kvm/Mesa-7.8.2-patch/lib/libOSMesa.so; //Dependencies for the target vtkViewsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkViews;general;vtkInfovisCS;general;vtkFilteringCS; //Dependencies for the target vtkViewsPythonD_LIB_DEPENDS:STATIC=general;vtkViews;general;vtkInfovisPythonD; //Dependencies for the target vtkViewsPython_LIB_DEPENDS:STATIC=general;vtkViewsPythonD; //Dependencies for the target vtkViews_LIB_DEPENDS:STATIC=general;vtkInfovis; //Dependencies for the target vtkVolumeRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkVolumeRendering;general;vtkRenderingCS; //Dependencies for the target vtkVolumeRenderingPythonD_LIB_DEPENDS:STATIC=general;vtkVolumeRendering;general;vtkRenderingPythonD;general;vtkIOPythonD; //Dependencies for the target vtkVolumeRenderingPython_LIB_DEPENDS:STATIC=general;vtkVolumeRenderingPythonD; //Dependencies for the target vtkVolumeRendering_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO;general;/home/kvm/Mesa-7.8.2-patch/lib/libOSMesa.so; //Dependencies for the target vtkWidgetsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkWidgets;general;vtkRenderingCS;general;vtkHybridCS; //Dependencies for the target vtkWidgetsPythonD_LIB_DEPENDS:STATIC=general;vtkWidgets;general;vtkRenderingPythonD;general;vtkHybridPythonD; //Dependencies for the target vtkWidgetsPython_LIB_DEPENDS:STATIC=general;vtkWidgetsPythonD; //Dependencies for the target vtkWidgets_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkHybrid; //Dependencies for the target vtkXdmfCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkXdmf;general;vtkRenderingCS; //Dependencies for the target vtkXdmfPython_LIB_DEPENDS:STATIC=general;vtkIOPythonD;general;vtkRenderingPythonD;general;vtkParallelPythonD;general;Xdmf; //Dependencies for the target vtkXdmf_LIB_DEPENDS:STATIC=general;vtkIO;general;Xdmf;general;vtkRendering;general;vtkParallel; //Dependencies for target vtkalglib_LIB_DEPENDS:STATIC= //Dependencies for the target vtkexoIIc_LIB_DEPENDS:STATIC=general;vtkNetCDF; //Dependencies for target vtkexpat_LIB_DEPENDS:STATIC= //Dependencies for target vtkfreetype_LIB_DEPENDS:STATIC= //Dependencies for the target vtkftgl_LIB_DEPENDS:STATIC=general;vtkfreetype; //Dependencies for the target vtkhdf5_LIB_DEPENDS:STATIC=general;m;general;vtkzlib; //Dependencies for target vtkjpeg_LIB_DEPENDS:STATIC= //Value Computed by CMake vtklibxml2_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtklibxml2 //Dependencies for the target vtklibxml2_LIB_DEPENDS:STATIC=general;vtkzlib;general;dl;general;-lpthread;general;dl;general;m; //Value Computed by CMake vtklibxml2_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtklibxml2 //Value Computed by CMake vtkmetaio_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/vtkmetaio //Dependencies for the target vtkmetaio_LIB_DEPENDS:STATIC=general;vtkzlib;general;vtksys; //Value Computed by CMake vtkmetaio_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/vtkmetaio //Dependencies for the target vtkpng_LIB_DEPENDS:STATIC=general;vtkzlib;general;-lm; //Dependencies for the target vtkproj4_LIB_DEPENDS:STATIC=general;m; //Dependencies for the target vtksqlite_LIB_DEPENDS:STATIC=general;-lpthread; //Value Computed by CMake vtksys_BINARY_DIR:STATIC=/home/kvm/projects/ParaView-patch/VTK/Utilities/kwsys //Dependencies for the target vtksys_LIB_DEPENDS:STATIC=general;dl; //Value Computed by CMake vtksys_SOURCE_DIR:STATIC=/home/kvm/projects/ParaView-3.8.0/VTK/Utilities/kwsys //Dependencies for the target vtktiff_LIB_DEPENDS:STATIC=general;vtkzlib;general;vtkjpeg;general;-lm; //Dependencies for target vtkverdict_LIB_DEPENDS:STATIC= //Dependencies for target vtkzlib_LIB_DEPENDS:STATIC= ######################## # INTERNAL cache entries ######################## ALGLIB_SHARED_LIB:INTERNAL=ON //Host Arcitecture : Linux IRIXN32 IRIX64 AIX CYGWIN ARCH_TO_BUILD:INTERNAL=Linux //ADVANCED property for variable: BUILD_DOCUMENTATION BUILD_DOCUMENTATION-ADVANCED:INTERNAL=1 //ADVANCED property for variable: BUILD_EXAMPLES BUILD_EXAMPLES-ADVANCED:INTERNAL=1 //MODIFIED property for variable: BUILD_SHARED_LIBS BUILD_SHARED_LIBS-MODIFIED:INTERNAL=ON //ADVANCED property for variable: BUILD_TESTING BUILD_TESTING-ADVANCED:INTERNAL=1 //MODIFIED property for variable: BUILD_TESTING BUILD_TESTING-MODIFIED:INTERNAL=ON //ADVANCED property for variable: BZRCOMMAND BZRCOMMAND-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_ANSI_FOR_SCOPE:INTERNAL=TRUE //Have include iostream CMAKE_ANSI_STREAM_HEADERS:INTERNAL=1 //ADVANCED property for variable: CMAKE_AR CMAKE_AR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_BACKWARDS_COMPATIBILITY CMAKE_BACKWARDS_COMPATIBILITY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_BUILD_TOOL CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1 //What is the target build tool cmake is generating for. CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/gmake //MODIFIED property for variable: CMAKE_BUILD_TYPE CMAKE_BUILD_TYPE-MODIFIED:INTERNAL=ON //This is the directory where this CMakeCache.txt was created CMAKE_CACHEFILE_DIR:INTERNAL=/home/kvm/projects/ParaView-patch //Major version of cmake used to create the current loaded cache CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2 //Minor version of cmake used to create the current loaded cache CMAKE_CACHE_MINOR_VERSION:INTERNAL=8 //Patch version of cmake used to create the current loaded cache CMAKE_CACHE_PATCH_VERSION:INTERNAL=2 //ADVANCED property for variable: CMAKE_COLOR_MAKEFILE CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1 //Path to CMake executable. CMAKE_COMMAND:INTERNAL=/home/kvm/cmake-2.8.2-Linux-i386/bin/cmake //Path to cpack program executable. CMAKE_CPACK_COMMAND:INTERNAL=/home/kvm/cmake-2.8.2-Linux-i386/bin/cpack //Path to ctest program executable. CMAKE_CTEST_COMMAND:INTERNAL=/home/kvm/cmake-2.8.2-Linux-i386/bin/ctest //ADVANCED property for variable: CMAKE_CXX_COMPILER CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1 CMAKE_CXX_COMPILER_WORKS:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_COMPILER CMAKE_C_COMPILER-ADVANCED:INTERNAL=1 CMAKE_C_COMPILER_WORKS:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS CMAKE_C_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE //Path to cache edit program executable. CMAKE_EDIT_COMMAND:INTERNAL=/home/kvm/cmake-2.8.2-Linux-i386/bin/ccmake //Executable file format CMAKE_EXECUTABLE_FORMAT:INTERNAL=ELF //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Name of generator. CMAKE_GENERATOR:INTERNAL=Unix Makefiles //Result of TRY_COMPILE CMAKE_HAS_ANSI_STRING_STREAM:INTERNAL=TRUE //Is X11 around. CMAKE_HAS_X:INTERNAL=1 //Have function connect CMAKE_HAVE_CONNECT:INTERNAL=1 //Have function gethostbyname CMAKE_HAVE_GETHOSTBYNAME:INTERNAL=1 //Have include CMAKE_HAVE_LIMITS_H CMAKE_HAVE_LIMITS_H:INTERNAL=1 //Have library pthreads CMAKE_HAVE_PTHREADS_CREATE:INTERNAL= //Have library pthread CMAKE_HAVE_PTHREAD_CREATE:INTERNAL=1 //Have include CMAKE_HAVE_PTHREAD_H CMAKE_HAVE_PTHREAD_H:INTERNAL=1 //Have function remove CMAKE_HAVE_REMOVE:INTERNAL=1 //Have function shmat CMAKE_HAVE_SHMAT:INTERNAL=1 //Have include CMAKE_HAVE_SYS_PRCTL_H CMAKE_HAVE_SYS_PRCTL_H:INTERNAL=1 //Have include CMAKE_HAVE_UNISTD_H CMAKE_HAVE_UNISTD_H:INTERNAL=1 //Start directory with the top level CMakeLists.txt file for this // project CMAKE_HOME_DIRECTORY:INTERNAL=/home/kvm/projects/ParaView-3.8.0 //ADVANCED property for variable: CMAKE_HP_PTHREADS CMAKE_HP_PTHREADS-ADVANCED:INTERNAL=1 //Install .so files without execute permission. CMAKE_INSTALL_SO_NO_EXE:INTERNAL=0 //Have library ICE CMAKE_LIB_ICE_HAS_ICECONNECTIONNUMBER:INTERNAL=1 //ADVANCED property for variable: CMAKE_LINKER CMAKE_LINKER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MAKE_PROGRAM CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_NM CMAKE_NM-ADVANCED:INTERNAL=1 //Does the compiler support ansi for scope. CMAKE_NO_ANSI_FOR_SCOPE:INTERNAL=0 //ADVANCED property for variable: CMAKE_NO_ANSI_STREAM_HEADERS CMAKE_NO_ANSI_STREAM_HEADERS-ADVANCED:INTERNAL=1 //Does the compiler support headers like iostream. CMAKE_NO_ANSI_STREAM_HEADERS:INTERNAL=0 //Does the compiler support sstream CMAKE_NO_ANSI_STRING_STREAM:INTERNAL=0 //Does the compiler support std::. CMAKE_NO_STD_NAMESPACE:INTERNAL=0 //number of local generators CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=103 //ADVANCED property for variable: CMAKE_OBJCOPY CMAKE_OBJCOPY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_OBJDUMP CMAKE_OBJDUMP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_RANLIB CMAKE_RANLIB-ADVANCED:INTERNAL=1 //Test Support for 64 bit file systems CMAKE_REQUIRE_LARGE_FILE_SUPPORT:INTERNAL=1 //Path to CMake installation. CMAKE_ROOT:INTERNAL=/home/kvm/cmake-2.8.2-Linux-i386/share/cmake-2.8 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(char) CMAKE_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) CMAKE_SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) CMAKE_SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) CMAKE_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) CMAKE_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) CMAKE_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(unsigned short) CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(void*) CMAKE_SIZEOF_VOID_P:INTERNAL=8 //ADVANCED property for variable: CMAKE_SKIP_RPATH CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1 //Whether to build with rpath. CMAKE_SKIP_RPATH:INTERNAL=0 //Result of TRY_COMPILE CMAKE_STD_NAMESPACE:INTERNAL=TRUE //ADVANCED property for variable: CMAKE_STRIP CMAKE_STRIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_THREAD_LIBS CMAKE_THREAD_LIBS-ADVANCED:INTERNAL=1 //uname command CMAKE_UNAME:INTERNAL=/bin/uname //ADVANCED property for variable: CMAKE_USE_PTHREADS CMAKE_USE_PTHREADS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_USE_SPROC CMAKE_USE_SPROC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_USE_WIN32_THREADS CMAKE_USE_WIN32_THREADS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1 //Result of TEST_BIG_ENDIAN CMAKE_WORDS_BIGENDIAN:INTERNAL=0 //ADVANCED property for variable: CMAKE_X_CFLAGS CMAKE_X_CFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_X_LIBS CMAKE_X_LIBS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: COMPRESSIONCOMMAND COMPRESSIONCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: COVERAGE_COMMAND COVERAGE_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_DEB CPACK_BINARY_DEB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_NSIS CPACK_BINARY_NSIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_RPM CPACK_BINARY_RPM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_STGZ CPACK_BINARY_STGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TBZ2 CPACK_BINARY_TBZ2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TGZ CPACK_BINARY_TGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TZ CPACK_BINARY_TZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TBZ2 CPACK_SOURCE_TBZ2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TGZ CPACK_SOURCE_TGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TZ CPACK_SOURCE_TZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_ZIP CPACK_SOURCE_ZIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CVSCOMMAND CVSCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CVS_UPDATE_OPTIONS CVS_UPDATE_OPTIONS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_BUILD_ERROR_REPORT_LIMIT DART_BUILD_ERROR_REPORT_LIMIT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_BUILD_WARNING_REPORT_LIMIT DART_BUILD_WARNING_REPORT_LIMIT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_ROOT DART_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_TESTING_TIMEOUT DART_TESTING_TIMEOUT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_VERBOSE_BUILD DART_VERBOSE_BUILD-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DELIVER_CONTINUOUS_EMAIL DELIVER_CONTINUOUS_EMAIL-ADVANCED:INTERNAL=1 //Other test DEV_T_IS_SCALAR:INTERNAL=1 //MODIFIED property for variable: ENABLE_MPI4PY ENABLE_MPI4PY-MODIFIED:INTERNAL=ON //ADVANCED property for variable: EXECUTABLE_OUTPUT_PATH EXECUTABLE_OUTPUT_PATH-ADVANCED:INTERNAL=1 //Single output directory for building all executables. EXECUTABLE_OUTPUT_PATH:INTERNAL=/home/kvm/projects/ParaView-patch/bin //Have include malloc.h EX_HAVE_MALLOC_H:INTERNAL=1 //Details about finding MPI FIND_PACKAGE_MESSAGE_DETAILS_MPI:INTERNAL=[/local/software/rh53/openmpi/1.3.3/gcc/lib/libmpi_cxx.so][/local/software/rh53/openmpi/1.3.3/gcc/include] //Details about finding OSMesa FIND_PACKAGE_MESSAGE_DETAILS_OSMesa:INTERNAL=[/home/kvm/Mesa-7.8.2-patch/lib/libOSMesa.so][/home/kvm/Mesa-7.8.2-patch/include] //Details about finding PythonLibs FIND_PACKAGE_MESSAGE_DETAILS_PythonLibs:INTERNAL=[/usr/lib64/libpython2.4.so][/usr/include/python2.4] //Details about finding Threads FIND_PACKAGE_MESSAGE_DETAILS_Threads:INTERNAL=[TRUE] //Details about finding X11 FIND_PACKAGE_MESSAGE_DETAILS_X11:INTERNAL=[/usr/lib64/libX11.so][/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include] //ADVANCED property for variable: GITCOMMAND GITCOMMAND-ADVANCED:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddress GLX_DECLARES_FUNCTION_glXGetProcAddress:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddressARB GLX_DECLARES_FUNCTION_glXGetProcAddressARB:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddressARB_AS_EMPTY GLX_DECLARES_FUNCTION_glXGetProcAddressARB_AS_EMPTY:INTERNAL= //Test GLX_DECLARES_FUNCTION_glXGetProcAddress_AS_EMPTY GLX_DECLARES_FUNCTION_glXGetProcAddress_AS_EMPTY:INTERNAL= //Test GLX_DEFINES_MACRO_GLX_ARB_get_proc_address GLX_DEFINES_MACRO_GLX_ARB_get_proc_address:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_1 GLX_DEFINES_MACRO_GLX_VERSION_1_1:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_2 GLX_DEFINES_MACRO_GLX_VERSION_1_2:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_3 GLX_DEFINES_MACRO_GLX_VERSION_1_3:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_4 GLX_DEFINES_MACRO_GLX_VERSION_1_4:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXFBConfig GLX_DEFINES_TYPE_GLXFBConfig:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXextFuncPtr GLX_DEFINES_TYPE_GLXextFuncPtr:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXextFuncPtr_AS_EMPTY GLX_DEFINES_TYPE_GLXextFuncPtr_AS_EMPTY:INTERNAL= //Test GLX_INCLUDES_GLXEXT GLX_INCLUDES_GLXEXT:INTERNAL=1 GLX_USES_MACRO_GLX_GLXEXT_LEGACY:INTERNAL=TRUE //ADVANCED property for variable: GUNZIPCOMMAND GUNZIPCOMMAND-ADVANCED:INTERNAL=1 //Have symbol alloca HAVE_ALLOCA:INTERNAL=1 //Have include HAVE_ALLOCA_H HAVE_ALLOCA_H:INTERNAL=1 //Have includes HAVE_ANSIDECL_H HAVE_ANSIDECL_H:INTERNAL= //Have include HAVE_ARPA_INET_H HAVE_ARPA_INET_H:INTERNAL=1 //Have include HAVE_ARPA_NAMESER_H HAVE_ARPA_NAMESER_H:INTERNAL=1 //Have include HAVE_ASSERT_H HAVE_ASSERT_H:INTERNAL=1 //Other test HAVE_ATTRIBUTE:INTERNAL= //Result of TRY_COMPILE HAVE_CMAKE_REQUIRE_LARGE_FILE_SUPPORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_VOID_P:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_WORDS_BIGENDIAN:INTERNAL=TRUE //Have include HAVE_CTYPE_H HAVE_CTYPE_H:INTERNAL=1 //Have function difftime HAVE_DIFFTIME:INTERNAL=1 //Have include HAVE_DIRENT_H HAVE_DIRENT_H:INTERNAL=1 //Have include HAVE_DLFCN_H HAVE_DLFCN_H:INTERNAL=1 //Have library dl;-lpthread;dl;m HAVE_DLOPEN:INTERNAL=1 //Have includes HAVE_DL_H HAVE_DL_H:INTERNAL= //Have include HAVE_ERRNO_H HAVE_ERRNO_H:INTERNAL=1 //Have include HAVE_FCNTL_H HAVE_FCNTL_H:INTERNAL=1 //Have include HAVE_FEATURES_H HAVE_FEATURES_H:INTERNAL=1 //Have include fenv.h HAVE_FENV_H:INTERNAL=1 //Have symbol finite HAVE_FINITE:INTERNAL=1 //Have include HAVE_FLOAT_H HAVE_FLOAT_H:INTERNAL=1 //Have function floor HAVE_FLOOR:INTERNAL= //Have function fork HAVE_FORK:INTERNAL=1 //Have symbol fpclass HAVE_FPCLASS:INTERNAL= //Have symbol fprintf HAVE_FPRINTF:INTERNAL=1 //Have symbol fp_class HAVE_FP_CLASS:INTERNAL= //Have includes HAVE_FP_CLASS_H HAVE_FP_CLASS_H:INTERNAL= //Have function frexpf HAVE_FREXPF:INTERNAL=1 //Have function frexpl HAVE_FREXPL:INTERNAL=1 //Have function fseek64 HAVE_FSEEK64:INTERNAL= //Have symbol ftime HAVE_FTIME:INTERNAL=1 //NetCDF test HAVE_FTRUNCATE:INTERNAL=1 //Other test HAVE_FUNCTION:INTERNAL=1 //Test HAVE_GCC_ERROR_RETURN_TYPE HAVE_GCC_ERROR_RETURN_TYPE:INTERNAL=1 //Test HAVE_GCC_VISIBILITY HAVE_GCC_VISIBILITY:INTERNAL=1 //Result of TRY_COMPILE HAVE_GETADDRINFO_COMPILED:INTERNAL=TRUE //Have function gethostname HAVE_GETHOSTNAME:INTERNAL=1 //Have function getopt HAVE_GETOPT:INTERNAL=1 //Have function getpwuid HAVE_GETPWUID:INTERNAL=1 //Have function getrusage HAVE_GETRUSAGE:INTERNAL=1 //Have symbol gettimeofday HAVE_GETTIMEOFDAY:INTERNAL=1 //Have includes HAVE_GLOBUS_COMMON_H HAVE_GLOBUS_COMMON_H:INTERNAL= //Result of TRY_COMPILE HAVE_ICET_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_VOID_P:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF___INT64:INTERNAL=FALSE //Have includes HAVE_IEEEFP_H HAVE_IEEEFP_H:INTERNAL= //Have include HAVE_INTTYPES_H HAVE_INTTYPES_H:INTERNAL=1 //Have function ioctl HAVE_IOCTL:INTERNAL=1 //Have includes HAVE_IO_H HAVE_IO_H:INTERNAL= //Have function isascii HAVE_ISASCII:INTERNAL=1 //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF___INT64:INTERNAL=FALSE //Have library dl; HAVE_LIBDL:INTERNAL=1 //Have library m; HAVE_LIBM:INTERNAL=1 //Have library socket;m HAVE_LIBSOCKET:INTERNAL= //Have library ucb;m HAVE_LIBUCB:INTERNAL= //Have library ws2_32;m HAVE_LIBWS2_32:INTERNAL= //Have library wsock32;m HAVE_LIBWSOCK32:INTERNAL= //Have include HAVE_LIMITS_H HAVE_LIMITS_H:INTERNAL=1 //Have symbol localtime HAVE_LOCALTIME:INTERNAL=1 //Have function longjmp HAVE_LONGJMP:INTERNAL=1 //Have function lseek64 HAVE_LSEEK64:INTERNAL=1 //Have include HAVE_MALLOC_H HAVE_MALLOC_H:INTERNAL=1 //Have include HAVE_MATH_H HAVE_MATH_H:INTERNAL=1 //Have function memmove HAVE_MEMMOVE:INTERNAL=1 //Have include HAVE_MEMORY_H HAVE_MEMORY_H:INTERNAL=1 //Have function memset HAVE_MEMSET:INTERNAL=1 //Have includes HAVE_MFHDF_H HAVE_MFHDF_H:INTERNAL= //Have function mmap HAVE_MMAP:INTERNAL=1 //Have includes HAVE_NAN_H HAVE_NAN_H:INTERNAL= //Have includes HAVE_NDIR_H HAVE_NDIR_H:INTERNAL= //Have include HAVE_NETDB_H HAVE_NETDB_H:INTERNAL=1 //Have include HAVE_NETINET_IN_H HAVE_NETINET_IN_H:INTERNAL=1 //Have include HAVE_NETINET_TCP_H HAVE_NETINET_TCP_H:INTERNAL=1 //Other test HAVE_OFF64_T:INTERNAL=1 //Have includes HAVE_PDB_H HAVE_PDB_H:INTERNAL= //Have function pow HAVE_POW:INTERNAL= //Have symbol printf HAVE_PRINTF:INTERNAL=1 //Have include HAVE_PTHREAD_H HAVE_PTHREAD_H:INTERNAL=1 //Have include HAVE_RESOLV_H HAVE_RESOLV_H:INTERNAL=1 //Have include HAVE_SETJMP_H HAVE_SETJMP_H:INTERNAL=1 //Have library dld;dl HAVE_SHLLOAD:INTERNAL= //Have function sigaction HAVE_SIGACTION:INTERNAL=1 //Have symbol signal HAVE_SIGNAL:INTERNAL=1 //Have include HAVE_SIGNAL_H HAVE_SIGNAL_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_JDSHKJFHDKS:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_OFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_PTRDIFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SSIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UCHAR:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SIZEOF_UINT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF___INT64:INTERNAL=FALSE //Have symbol snprintf HAVE_SNPRINTF:INTERNAL=1 //Other test HAVE_SOCKLEN_T:INTERNAL=1 //Result of TRY_COMPILE HAVE_SOCKLEN_T_COMPILED:INTERNAL=TRUE //Have symbol SO_REUSEADDR HAVE_SO_REUSEADDR:INTERNAL=1 //Have symbol sprintf HAVE_SPRINTF:INTERNAL=1 //Have function sqrt HAVE_SQRT:INTERNAL= //Have includes HAVE_SRBCLIENT_H HAVE_SRBCLIENT_H:INTERNAL= //Have symbol sscanf HAVE_SSCANF:INTERNAL=1 //Have symbol stat HAVE_STAT:INTERNAL=1 //Other test HAVE_STAT_ST_BLOCKS:INTERNAL=1 //Have include HAVE_STDARG_H HAVE_STDARG_H:INTERNAL=1 //Have include stddef.h HAVE_STDDEF_H:INTERNAL=1 //Have include stdint.h HAVE_STDINT_H:INTERNAL=1 //Have include stdint.h HAVE_STDINT_H_CXX:INTERNAL=1 //Have include HAVE_STDIO_H HAVE_STDIO_H:INTERNAL=1 //Have include HAVE_STDLIB_H HAVE_STDLIB_H:INTERNAL=1 //Have function strcasecmp HAVE_STRCASECMP:INTERNAL=1 //Have function strchr HAVE_STRCHR:INTERNAL=1 //Have symbol strdup HAVE_STRDUP:INTERNAL=1 //Have symbol strerror HAVE_STRERROR:INTERNAL=1 //Have symbol strftime HAVE_STRFTIME:INTERNAL=1 //Have include HAVE_STRINGS_H HAVE_STRINGS_H:INTERNAL=1 //Have include HAVE_STRING_H HAVE_STRING_H:INTERNAL=1 //Have symbol strndup HAVE_STRNDUP:INTERNAL=1 //Have function strrchr HAVE_STRRCHR:INTERNAL=1 //Have function strstr HAVE_STRSTR:INTERNAL=1 //Have function strtol HAVE_STRTOL:INTERNAL=1 //Have function strtoll HAVE_STRTOLL:INTERNAL=1 //Have function areroul HAVE_STRTOUL:INTERNAL= //Other test HAVE_STRUCT_TIMEZONE:INTERNAL=1 //Other test HAVE_STRUCT_TM_TM_ZONE:INTERNAL=1 //NetCDF test HAVE_ST_BLKSIZE:INTERNAL=1 //Have function system HAVE_SYSTEM:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_DIR_H_COMPILED:INTERNAL=TRUE //Have includes HAVE_SYS_FILIO_H HAVE_SYS_FILIO_H:INTERNAL= //Have include HAVE_SYS_IOCTL_H HAVE_SYS_IOCTL_H:INTERNAL=1 //Have include HAVE_SYS_MMAN_H HAVE_SYS_MMAN_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_NDIR_H_COMPILED:INTERNAL=FALSE //Have includes HAVE_SYS_PROC_H HAVE_SYS_PROC_H:INTERNAL= //Have include HAVE_SYS_RESOURCE_H HAVE_SYS_RESOURCE_H:INTERNAL=1 //Have include HAVE_SYS_SELECT_H HAVE_SYS_SELECT_H:INTERNAL=1 //Have include HAVE_SYS_SOCKET_H HAVE_SYS_SOCKET_H:INTERNAL=1 //Have include HAVE_SYS_STAT_H HAVE_SYS_STAT_H:INTERNAL=1 HAVE_SYS_SYSINFO_H:INTERNAL= //Have include HAVE_SYS_TIMEB_H HAVE_SYS_TIMEB_H:INTERNAL=1 //Have include HAVE_SYS_TIME_H HAVE_SYS_TIME_H:INTERNAL=1 //Have include sys/types.h HAVE_SYS_TYPES_H:INTERNAL=1 //Other test HAVE_TIMEZONE:INTERNAL=1 //Have include HAVE_TIME_H HAVE_TIME_H:INTERNAL=1 //Have symbol TIOCGETD HAVE_TIOCGETD:INTERNAL=1 //Have symbol TIOCGWINSZ HAVE_TIOCGWINSZ:INTERNAL=1 //Other test HAVE_TM_GMTOFF:INTERNAL=1 //Other test HAVE_TM_ZONE:INTERNAL=1 //Have include HAVE_UNISTD_H HAVE_UNISTD_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_VA_COPY_COMPILED:INTERNAL=TRUE //Have symbol vfprintf HAVE_VFPRINTF:INTERNAL=1 //Have symbol vsnprintf HAVE_VSNPRINTF:INTERNAL=1 //Have symbol vsprintf HAVE_VSPRINTF:INTERNAL=1 //Result of TRY_COMPILE HAVE_VTK_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF___INT64:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_VTK_UINTPTR_T:INTERNAL=TRUE //Have function waitpid HAVE_WAITPID:INTERNAL=1 //Have includes HAVE_WINDOWS_H HAVE_WINDOWS_H:INTERNAL= //Have includes HAVE_WINSOCK_H HAVE_WINSOCK_H:INTERNAL= //Have symbol _stat HAVE__STAT:INTERNAL= //Result of TRY_COMPILE HAVE___VA_COPY_COMPILED:INTERNAL=TRUE //ADVANCED property for variable: HDF5_ENABLE_HSIZET HDF5_ENABLE_HSIZET-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_ENABLE_LINUX_LFS HDF5_ENABLE_LINUX_LFS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_ENABLE_PARALLEL HDF5_ENABLE_PARALLEL-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE HDF5_PRINTF_LL_TEST_COMPILE:INTERNAL=TRUE //Result of TRY_RUN HDF5_PRINTF_LL_TEST_RUN:INTERNAL=0 //ADVANCED property for variable: HDF5_STREAM_VFD HDF5_STREAM_VFD-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HGCOMMAND HGCOMMAND-ADVANCED:INTERNAL=1 //HTMLDocumentation files generated from ServerManager HTMLDocumentation_FILES:INTERNAL=/home/kvm/projects/ParaView-patch/Documentation/ParaViewSources.html;/home/kvm/projects/ParaView-patch/Documentation/ParaViewFilters.html;/home/kvm/projects/ParaView-patch/Documentation/ParaViewReaders.html;/home/kvm/projects/ParaView-patch/Documentation/ParaViewWriters.html //This is set from VTK_MPIRUN_EXE. ICET_MPIRUN_EXE:INTERNAL=/home/local/software/rh53/openmpi/1.3.3/gcc/bin/mpiexec //This is set from VTK_MPI_MAX_NUMPROCS. ICET_MPI_MAX_NUMPROCS:INTERNAL=2 //This is set from VTK_MPI_POSTFLAGS. ICET_MPI_POSTFLAGS:INTERNAL= //This is set from a combination of VTK_MPI_PREFLAGS VTK_MPI_NUMPROC_FLAG // VTK_MPI_MAX_NUMPROCS VTK_MPI_PREFLAGS. ICET_MPI_PREFLAGS:INTERNAL=;-np;2; //CHECK_TYPE_SIZE: sizeof(char) ICET_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) ICET_SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) ICET_SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) ICET_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) ICET_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) ICET_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) ICET_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(void*) ICET_SIZEOF_VOID_P:INTERNAL=8 //CHECK_TYPE_SIZE: __int64 unknown ICET_SIZEOF___INT64:INTERNAL= //Whether streams support 64-bit types ICE_HAVE_64BIT_STREAMS:INTERNAL=1 //ADVANCED property for variable: ICE_HAVE_FCNTL ICE_HAVE_FCNTL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICE_HAVE_MMAN ICE_HAVE_MMAN-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICE_HAVE_NETINET ICE_HAVE_NETINET-ADVANCED:INTERNAL=1 //Other test INLINE_TEST___inline:INTERNAL=1 //Other test INLINE_TEST___inline__:INTERNAL=1 //Other test INLINE_TEST_inline:INTERNAL=1 //ADVANCED property for variable: JAVACOMMAND JAVACOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: KWCommon_BUILD_TESTING KWCommon_BUILD_TESTING-ADVANCED:INTERNAL=1 //include paths for KWCommon KWCommon_INCLUDE_PATH:INTERNAL=/home/kvm/projects/ParaView-3.8.0/Common/KWCommon //libraries for KWCommon KWCommon_LIBRARIES:INTERNAL=KWCommon //Result of TRY_RUN KWSYS_CHAR_IS_SIGNED:INTERNAL=0 //Result of TRY_COMPILE KWSYS_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_ARGUMENT_DEPENDENT_LOOKUP_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_CSTDDEF_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_CSTDIO_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_FULL_SPECIALIZATION_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_MEMBER_TEMPLATES_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_NULL_TEMPLATE_ARGS_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_C_HAS_PTRDIFF_T_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_C_HAS_SSIZE_T_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_HAVE_BINARY_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_ANSI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_SSTREAM_COMPILED:INTERNAL=TRUE //Result of TRY_RUN KWSYS_LFS_WORKS:INTERNAL=0 //Result of TRY_COMPILE KWSYS_LFS_WORKS_COMPILED:INTERNAL=TRUE //CHECK_TYPE_SIZE: sizeof(char) KWSYS_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int) KWSYS_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) KWSYS_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) KWSYS_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) KWSYS_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: __int64 unknown KWSYS_SIZEOF___INT64:INTERNAL= //Result of TRY_COMPILE KWSYS_STAT_HAS_ST_MTIM_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_MAX_SIZE_ARGUMENT_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_OBJECTS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_REBIND_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_TEMPLATE_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ITERATOR_TRAITS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_STRING_HAVE_NEQ_CHAR_COMPILED:INTERNAL=TRUE //ADVANCED property for variable: LIBRARY_OUTPUT_PATH LIBRARY_OUTPUT_PATH-ADVANCED:INTERNAL=1 //Single output directory for building all libraries. LIBRARY_OUTPUT_PATH:INTERNAL=/home/kvm/projects/ParaView-patch/bin //ADVANCED property for variable: MAKECOMMAND MAKECOMMAND-ADVANCED:INTERNAL=1 //Path to vtkMaterialLibraryMacro.h MATERIAL_LIBRARY_MATERIAL_MACRO_HEADER:INTERNAL=/home/kvm/projects/ParaView-patch/VTK/Utilities/MaterialLibrary/vtkMaterialLibraryMacro.h //Path to vtkShaderCodeLibraryMacro.h MATERIAL_LIBRARY_SHADER_MACRO_HEADER:INTERNAL=/home/kvm/projects/ParaView-patch/VTK/Utilities/MaterialLibrary/vtkShaderCodeLibraryMacro.h //ADVANCED property for variable: MEMORYCHECK_COMMAND MEMORYCHECK_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MEMORYCHECK_SUPPRESSIONS_FILE MEMORYCHECK_SUPPRESSIONS_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC MPIEXEC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_MAX_NUMPROCS MPIEXEC_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_NUMPROC_FLAG MPIEXEC_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_POSTFLAGS MPIEXEC_POSTFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_PREFLAGS MPIEXEC_PREFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_COMPILER MPI_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_COMPILE_FLAGS MPI_COMPILE_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_EXTRA_LIBRARY MPI_EXTRA_LIBRARY-ADVANCED:INTERNAL=0 //ADVANCED property for variable: MPI_INCLUDE_PATH MPI_INCLUDE_PATH-ADVANCED:INTERNAL=0 //Scratch variable for MPI detection MPI_LIB:INTERNAL=MPI_LIB-NOTFOUND //ADVANCED property for variable: MPI_LIBRARY MPI_LIBRARY-ADVANCED:INTERNAL=0 //ADVANCED property for variable: MPI_LINK_FLAGS MPI_LINK_FLAGS-ADVANCED:INTERNAL=1 //Have library c NOT_NEED_LIBNSL:INTERNAL=1 //ADVANCED property for variable: OPENGL_INCLUDE_DIR OPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //MODIFIED property for variable: OPENGL_INCLUDE_DIR OPENGL_INCLUDE_DIR-MODIFIED:INTERNAL=ON //ADVANCED property for variable: OPENGL_gl_LIBRARY OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1 //MODIFIED property for variable: OPENGL_gl_LIBRARY OPENGL_gl_LIBRARY-MODIFIED:INTERNAL=ON //ADVANCED property for variable: OPENGL_glu_LIBRARY OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1 //MODIFIED property for variable: OPENGL_glu_LIBRARY OPENGL_glu_LIBRARY-MODIFIED:INTERNAL=ON //ADVANCED property for variable: OPENGL_xmesa_INCLUDE_DIR OPENGL_xmesa_INCLUDE_DIR-ADVANCED:INTERNAL=1 //MODIFIED property for variable: OPENGL_xmesa_INCLUDE_DIR OPENGL_xmesa_INCLUDE_DIR-MODIFIED:INTERNAL=ON //ADVANCED property for variable: OSMESA_INCLUDE_DIR OSMESA_INCLUDE_DIR-ADVANCED:INTERNAL=1 //MODIFIED property for variable: OSMESA_INCLUDE_DIR OSMESA_INCLUDE_DIR-MODIFIED:INTERNAL=ON //ADVANCED property for variable: OSMESA_LIBRARY OSMESA_LIBRARY-ADVANCED:INTERNAL=1 //MODIFIED property for variable: OSMESA_LIBRARY OSMESA_LIBRARY-MODIFIED:INTERNAL=ON //ADVANCED property for variable: PARAVIEW_ALWAYS_SECURE_CONNECTION PARAVIEW_ALWAYS_SECURE_CONNECTION-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIReaderWriter PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIReaderWriter-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_H5PartReader PARAVIEW_BUILD_PLUGIN_H5PartReader-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_Manta PARAVIEW_BUILD_PLUGIN_Manta-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_Moments PARAVIEW_BUILD_PLUGIN_Moments-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_NetDMFReader PARAVIEW_BUILD_PLUGIN_NetDMFReader-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_PointSprite PARAVIEW_BUILD_PLUGIN_PointSprite-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_Prism PARAVIEW_BUILD_PLUGIN_Prism-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SLACTools PARAVIEW_BUILD_PLUGIN_SLACTools-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SierraPlotTools PARAVIEW_BUILD_PLUGIN_SierraPlotTools-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SurfaceLIC PARAVIEW_BUILD_PLUGIN_SurfaceLIC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_VisItReaderPlugin PARAVIEW_BUILD_PLUGIN_VisItReaderPlugin-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_pvblot PARAVIEW_BUILD_PLUGIN_pvblot-ADVANCED:INTERNAL=1 //MODIFIED property for variable: PARAVIEW_BUILD_QT_GUI PARAVIEW_BUILD_QT_GUI-MODIFIED:INTERNAL=ON //ADVANCED property for variable: PARAVIEW_BUILD_WITH_ADAPTOR PARAVIEW_BUILD_WITH_ADAPTOR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_DISABLE_VTK_TESTING PARAVIEW_DISABLE_VTK_TESTING-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_ENABLE_COPROCESSING PARAVIEW_ENABLE_COPROCESSING-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_ENABLE_FPE PARAVIEW_ENABLE_FPE-ADVANCED:INTERNAL=1 //MODIFIED property for variable: PARAVIEW_ENABLE_PYTHON PARAVIEW_ENABLE_PYTHON-MODIFIED:INTERNAL=ON //ADVANCED property for variable: PARAVIEW_EXTRA_EXTERNAL_MODULES PARAVIEW_EXTRA_EXTERNAL_MODULES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_INSTALL_DEVELOPMENT PARAVIEW_INSTALL_DEVELOPMENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_MINIMAL_BUILD PARAVIEW_MINIMAL_BUILD-ADVANCED:INTERNAL=1 //List of configured plugins PARAVIEW_PLUGINLIST:INTERNAL=Moments;PrismServerPlugin;PointSprite_Plugin;pvblot;SLACTools;H5PartReader;AnalyzeReader;AnalyzeWriter;NIfTIReader;NIfTIWriter //List of configured plugins. PARAVIEW_PLUGIN_CONFIG_LIST:INTERNAL= //ADVANCED property for variable: PARAVIEW_TESTING_WITH_PYTHON PARAVIEW_TESTING_WITH_PYTHON-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_USE_ICE_T PARAVIEW_USE_ICE_T-ADVANCED:INTERNAL=1 //MODIFIED property for variable: PARAVIEW_USE_MPI PARAVIEW_USE_MPI-MODIFIED:INTERNAL=ON //ADVANCED property for variable: PARAVIEW_USE_MPI_SSEND PARAVIEW_USE_MPI_SSEND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_USE_SILO PARAVIEW_USE_SILO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_USE_SYSTEM_HDF5 PARAVIEW_USE_SYSTEM_HDF5-ADVANCED:INTERNAL=1 //Width for printf for type `long long' or `__int64', us. `ll PRINTF_LL_WIDTH:INTERNAL="l" //Have symbol atanh PROJ_HAVE_ATANH:INTERNAL=1 //Have symbol csin PROJ_HAVE_COMPLEX:INTERNAL=1 //ADVANCED property for variable: PROJ_LIST_EXTERNAL PROJ_LIST_EXTERNAL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PROJ_USE_GSL PROJ_USE_GSL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PROJ_USE_PTHREADS PROJ_USE_PTHREADS-ADVANCED:INTERNAL=1 //Path to paraview module. PV_PYTHON_MODULE_DIR:INTERNAL=/home/kvm/projects/ParaView-patch/Utilities/VTKPythonWrapping //ADVANCED property for variable: PV_TEST_CLEAN_COMMAND PV_TEST_CLEAN_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_CLIENT PV_TEST_CLIENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_INIT_COMMAND PV_TEST_INIT_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_MPIPython PYTHON_ENABLE_MODULE_MPIPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkChartsPython PYTHON_ENABLE_MODULE_vtkChartsPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkCommonPython PYTHON_ENABLE_MODULE_vtkCommonPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkFilteringPython PYTHON_ENABLE_MODULE_vtkFilteringPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkGenericFilteringPython PYTHON_ENABLE_MODULE_vtkGenericFilteringPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkGeovisPython PYTHON_ENABLE_MODULE_vtkGeovisPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkGraphicsPython PYTHON_ENABLE_MODULE_vtkGraphicsPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkHybridPython PYTHON_ENABLE_MODULE_vtkHybridPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkIOPython PYTHON_ENABLE_MODULE_vtkIOPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkImagingPython PYTHON_ENABLE_MODULE_vtkImagingPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkInfovisPython PYTHON_ENABLE_MODULE_vtkInfovisPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkPVFiltersPython PYTHON_ENABLE_MODULE_vtkPVFiltersPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkPVServerCommonPython PYTHON_ENABLE_MODULE_vtkPVServerCommonPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkPVServerManagerPython PYTHON_ENABLE_MODULE_vtkPVServerManagerPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkParallelPython PYTHON_ENABLE_MODULE_vtkParallelPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkRenderingPython PYTHON_ENABLE_MODULE_vtkRenderingPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkViewsPython PYTHON_ENABLE_MODULE_vtkViewsPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkVolumeRenderingPython PYTHON_ENABLE_MODULE_vtkVolumeRenderingPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vtkWidgetsPython PYTHON_ENABLE_MODULE_vtkWidgetsPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_EXECUTABLE PYTHON_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_EXTRA_LIBS PYTHON_EXTRA_LIBS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_INCLUDE_DIR PYTHON_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_INCLUDE_PATH PYTHON_INCLUDE_PATH-ADVANCED:INTERNAL=1 //Path to where Python.h is found (deprecated) PYTHON_INCLUDE_PATH:INTERNAL=/usr/include/python2.4 //ADVANCED property for variable: PYTHON_LIBRARY PYTHON_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_MPIPython_BUILD_SHARED PYTHON_MODULE_MPIPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkChartsPython_BUILD_SHARED PYTHON_MODULE_vtkChartsPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkCommonPython_BUILD_SHARED PYTHON_MODULE_vtkCommonPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkFilteringPython_BUILD_SHARED PYTHON_MODULE_vtkFilteringPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkGenericFilteringPython_BUILD_SHARED PYTHON_MODULE_vtkGenericFilteringPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkGeovisPython_BUILD_SHARED PYTHON_MODULE_vtkGeovisPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkGraphicsPython_BUILD_SHARED PYTHON_MODULE_vtkGraphicsPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkHybridPython_BUILD_SHARED PYTHON_MODULE_vtkHybridPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkIOPython_BUILD_SHARED PYTHON_MODULE_vtkIOPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkImagingPython_BUILD_SHARED PYTHON_MODULE_vtkImagingPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkInfovisPython_BUILD_SHARED PYTHON_MODULE_vtkInfovisPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkPVFiltersPython_BUILD_SHARED PYTHON_MODULE_vtkPVFiltersPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkPVServerCommonPython_BUILD_SHARED PYTHON_MODULE_vtkPVServerCommonPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkPVServerManagerPython_BUILD_SHARED PYTHON_MODULE_vtkPVServerManagerPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkParallelPython_BUILD_SHARED PYTHON_MODULE_vtkParallelPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkRenderingPython_BUILD_SHARED PYTHON_MODULE_vtkRenderingPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkViewsPython_BUILD_SHARED PYTHON_MODULE_vtkViewsPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkVolumeRenderingPython_BUILD_SHARED PYTHON_MODULE_vtkVolumeRenderingPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vtkWidgetsPython_BUILD_SHARED PYTHON_MODULE_vtkWidgetsPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_UTIL_LIBRARY PYTHON_UTIL_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PointSpritePlugin_BUILD_EXAMPLES PointSpritePlugin_BUILD_EXAMPLES-ADVANCED:INTERNAL=1 QT_QMAKE_EXECUTABLE_LAST:INTERNAL=/usr/lib64/qt-3.3/bin/qmake //ADVANCED property for variable: QT_QTDESIGNER_INCLUDE_DIR QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SCPCOMMAND SCPCOMMAND-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE SHARED_LIBRARY_PATH_INFO_COMPILED:INTERNAL=TRUE //Result of TRY_RUN SHARED_LIBRARY_PATH_TYPE:INTERNAL=0 //runtime library path variable name. SHARED_LIBRARY_PATH_VAR_NAME:INTERNAL=LD_LIBRARY_PATH //ADVANCED property for variable: SITE SITE-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(char) SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int16_t) SIZEOF_INT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(int32_t) SIZEOF_INT32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int64_t) SIZEOF_INT64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int8_t) SIZEOF_INT8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int_fast16_t) SIZEOF_INT_FAST16_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast32_t) SIZEOF_INT_FAST32_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast64_t) SIZEOF_INT_FAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast8_t) SIZEOF_INT_FAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int_least16_t) SIZEOF_INT_LEAST16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(int_least32_t) SIZEOF_INT_LEAST32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int_least64_t) SIZEOF_INT_LEAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_least8_t) SIZEOF_INT_LEAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: jdshkjfhdks unknown SIZEOF_JDSHKJFHDKS:INTERNAL= //CHECK_TYPE_SIZE: sizeof(long) SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long double) SIZEOF_LONG_DOUBLE:INTERNAL=16 //CHECK_TYPE_SIZE: sizeof(long long) SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(off_t) SIZEOF_OFF_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(ptrdiff_t) SIZEOF_PTRDIFF_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(size_t) SIZEOF_SIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(ssize_t) SIZEOF_SSIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: uchar unknown SIZEOF_UCHAR:INTERNAL= //CHECK_TYPE_SIZE: sizeof(uint16_t) SIZEOF_UINT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(uint32_t) SIZEOF_UINT32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(uint64_t) SIZEOF_UINT64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint8_t) SIZEOF_UINT8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(uint_fast16_t) SIZEOF_UINT_FAST16_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast32_t) SIZEOF_UINT_FAST32_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast64_t) SIZEOF_UINT_FAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast8_t) SIZEOF_UINT_FAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(uint_least16_t) SIZEOF_UINT_LEAST16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(uint_least32_t) SIZEOF_UINT_LEAST32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(uint_least64_t) SIZEOF_UINT_LEAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_least8_t) SIZEOF_UINT_LEAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: __int64 unknown SIZEOF___INT64:INTERNAL= //ADVANCED property for variable: SLURM_SBATCH_COMMAND SLURM_SBATCH_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SLURM_SRUN_COMMAND SLURM_SRUN_COMMAND-ADVANCED:INTERNAL=1 //Have include STDC_HEADERS STDC_HEADERS:INTERNAL=1 //Result of TRY_COMPILE SUPPORT_IP6_COMPILED:INTERNAL=TRUE //ADVANCED property for variable: SVNCOMMAND SVNCOMMAND-ADVANCED:INTERNAL=1 //Other test SYSTEM_SCOPE_THREADS:INTERNAL=1 //Other test TIME_WITH_SYS_TIME:INTERNAL=1 //ADVANCED property for variable: VERDICT_BUILD_DOC VERDICT_BUILD_DOC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_ENABLE_TESTING VERDICT_ENABLE_TESTING-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_MANGLE VERDICT_MANGLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_MANGLE_PREFIX VERDICT_MANGLE_PREFIX-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_USE_FLOAT VERDICT_USE_FLOAT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VLI_LIBRARY_FOR_VP1000 VLI_LIBRARY_FOR_VP1000-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VTK_ANSI_STREAM_EOF_COMPILED:INTERNAL=TRUE //Result of TRY_RUN VTK_ANSI_STREAM_EOF_RESULT:INTERNAL=0 VTK_CMAKE_DIR:INTERNAL=/home/kvm/projects/ParaView-3.8.0/VTK/CMake //Support for C++ type bool VTK_COMPILER_HAS_BOOL:INTERNAL=1 //Support for full template specialization syntax VTK_COMPILER_HAS_FULL_SPECIALIZATION:INTERNAL=1 //ADVANCED property for variable: VTK_DATA_ROOT VTK_DATA_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_DEBUG_LEAKS VTK_DEBUG_LEAKS-ADVANCED:INTERNAL=1 //The directory in which code for Shaders is provided. VTK_DEFAULT_SHADERS_DIR:INTERNAL=/home/kvm/projects/ParaView-patch/VTK/Utilities/MaterialLibrary/Repository VTK_DIR:INTERNAL=/home/kvm/projects/ParaView-patch/VTK //String encoder. VTK_ENCODESTRING_EXE:INTERNAL=/home/kvm/projects/ParaView-patch/bin/vtkEncodeString //Support for C++ explict templates VTK_EXPLICIT_TEMPLATES:INTERNAL=1 //ADVANCED property for variable: VTK_GLEXT_FILE VTK_GLEXT_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_GLXEXT_FILE VTK_GLXEXT_FILE-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS:INTERNAL=TRUE //OpenGL includes used to test glXGetProcAddressARB prototype. VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS_INCLUDES:INTERNAL=/usr/include //Already set VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS_TESTED:INTERNAL=1 //Have symbol feenableexcept VTK_HAS_FEENABLEEXCEPT:INTERNAL=1 //Have symbol isinf VTK_HAS_ISINF:INTERNAL= //Have symbol isnan VTK_HAS_ISNAN:INTERNAL= //Have symbol _isnan VTK_HAS__ISNAN:INTERNAL= //Have include iosfwd VTK_HAVE_ANSI_STREAMS:INTERNAL=1 //Support for getsockname with socklen_t VTK_HAVE_GETSOCKNAME_WITH_SOCKLEN_T:INTERNAL=1 //Have library socket VTK_HAVE_LIBSOCKET:INTERNAL= //Have include iostream.h VTK_HAVE_OLD_STREAMS:INTERNAL= //Have symbol SO_REUSEADDR VTK_HAVE_SO_REUSEADDR:INTERNAL=1 //Whether istream supports long long VTK_ISTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //ADVANCED property for variable: VTK_LARGE_DATA_ROOT VTK_LARGE_DATA_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_LEGACY_REMOVE VTK_LEGACY_REMOVE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_LEGACY_SILENT VTK_LEGACY_SILENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MATERIALS_DIRS VTK_MATERIALS_DIRS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPIRUN_EXE VTK_MPIRUN_EXE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_MAX_NUMPROCS VTK_MPI_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_NUMPROC_FLAG VTK_MPI_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_POSTFLAGS VTK_MPI_POSTFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_PREFLAGS VTK_MPI_PREFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_PRENUMPROC_FLAGS VTK_MPI_PRENUMPROC_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_NO_PYTHON_THREADS VTK_NO_PYTHON_THREADS-ADVANCED:INTERNAL=1 //Disable multithreading support in the Python bindings VTK_NO_PYTHON_THREADS:INTERNAL=1 //ADVANCED property for variable: VTK_OPENGL_HAS_OSMESA VTK_OPENGL_HAS_OSMESA-ADVANCED:INTERNAL=1 //MODIFIED property for variable: VTK_OPENGL_HAS_OSMESA VTK_OPENGL_HAS_OSMESA-MODIFIED:INTERNAL=ON //Whether ostream supports long long VTK_OSTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //OpenGL extensions parser. VTK_PARSEOGLEXT_EXE:INTERNAL=/home/kvm/projects/ParaView-patch/bin/vtkParseOGLExt //CHECK_TYPE_SIZE: sizeof(long long) VTK_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: __int64 unknown VTK_SIZEOF___INT64:INTERNAL= VTK_TCL_TK_STATIC:INTERNAL=ON //ADVANCED property for variable: VTK_TESTING_LOCALE VTK_TESTING_LOCALE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_TESTING_USE_FPE VTK_TESTING_USE_FPE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_TESTING_USE_LOCALE VTK_TESTING_USE_LOCALE-ADVANCED:INTERNAL=1 //Whether char is signed. VTK_TYPE_CHAR_IS_SIGNED:INTERNAL=1 //Result of TRY_COMPILE VTK_TYPE_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //CHECK_TYPE_SIZE: sizeof(uintptr_t) VTK_UINTPTR_T:INTERNAL=8 //ADVANCED property for variable: VTK_USE_64BIT_IDS VTK_USE_64BIT_IDS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_BOOST VTK_USE_BOOST-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_CG_SHADERS VTK_USE_CG_SHADERS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_CHARTS VTK_USE_CHARTS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_DISPLAY VTK_USE_DISPLAY-ADVANCED:INTERNAL=1 //MODIFIED property for variable: VTK_USE_DISPLAY VTK_USE_DISPLAY-MODIFIED:INTERNAL=ON //ADVANCED property for variable: VTK_USE_FFMPEG_ENCODER VTK_USE_FFMPEG_ENCODER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GCC_VISIBILITY VTK_USE_GCC_VISIBILITY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GEOVIS VTK_USE_GEOVIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GL2PS VTK_USE_GL2PS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GLSL_SHADERS VTK_USE_GLSL_SHADERS-ADVANCED:INTERNAL=1 //Have function glXGetProcAddressARB VTK_USE_GLX_GET_PROC_ADDRESS_ARB:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GNU_R VTK_USE_GNU_R-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GUISUPPORT VTK_USE_GUISUPPORT-ADVANCED:INTERNAL=1 //MODIFIED property for variable: VTK_USE_GUISUPPORT VTK_USE_GUISUPPORT-MODIFIED:INTERNAL=ON //ADVANCED property for variable: VTK_USE_INFOVIS VTK_USE_INFOVIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MANGLED_MESA VTK_USE_MANGLED_MESA-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MATLAB_MEX VTK_USE_MATLAB_MEX-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MATROX_IMAGING VTK_USE_MATROX_IMAGING-ADVANCED:INTERNAL=1 //Use Matrox Imaging Library for video input. VTK_USE_MATROX_IMAGING:INTERNAL=OFF //ADVANCED property for variable: VTK_USE_METAIO VTK_USE_METAIO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MPEG2_ENCODER VTK_USE_MPEG2_ENCODER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MPI VTK_USE_MPI-ADVANCED:INTERNAL=0 //Build VTK with MPI support VTK_USE_MPI:INTERNAL=ON //ADVANCED property for variable: VTK_USE_MYSQL VTK_USE_MYSQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_NVCONTROL VTK_USE_NVCONTROL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_N_WAY_ARRAYS VTK_USE_N_WAY_ARRAYS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_ODBC VTK_USE_ODBC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_OFFSCREEN VTK_USE_OFFSCREEN-ADVANCED:INTERNAL=1 //MODIFIED property for variable: VTK_USE_OFFSCREEN VTK_USE_OFFSCREEN-MODIFIED:INTERNAL=ON //ADVANCED property for variable: VTK_USE_OGGTHEORA_ENCODER VTK_USE_OGGTHEORA_ENCODER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_POSTGRES VTK_USE_POSTGRES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_QT VTK_USE_QT-ADVANCED:INTERNAL=1 //Build QVTK widget and plugin for Qt VTK_USE_QVTK:INTERNAL=OFF //ADVANCED property for variable: VTK_USE_QVTK_QTOPENGL VTK_USE_QVTK_QTOPENGL-ADVANCED:INTERNAL=1 //Build the vtkRendering kit. Needed for displaying data or using // widgets. VTK_USE_RENDERING:INTERNAL=ON //ADVANCED property for variable: VTK_USE_RPATH VTK_USE_RPATH-ADVANCED:INTERNAL=1 //MODIFIED property for variable: VTK_USE_RPATH VTK_USE_RPATH-MODIFIED:INTERNAL=ON //ADVANCED property for variable: VTK_USE_SYSTEM_EXPAT VTK_USE_SYSTEM_EXPAT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_FREETYPE VTK_USE_SYSTEM_FREETYPE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_JPEG VTK_USE_SYSTEM_JPEG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_LIBPROJ4 VTK_USE_SYSTEM_LIBPROJ4-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_LIBXML2 VTK_USE_SYSTEM_LIBXML2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_PNG VTK_USE_SYSTEM_PNG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_TIFF VTK_USE_SYSTEM_TIFF-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_ZLIB VTK_USE_SYSTEM_ZLIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_TDX VTK_USE_TDX-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_TEXT_ANALYSIS VTK_USE_TEXT_ANALYSIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_TK VTK_USE_TK-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_VIEWS VTK_USE_VIEWS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_VOLUMEPRO_1000 VTK_USE_VOLUMEPRO_1000-ADVANCED:INTERNAL=1 //MODIFIED property for variable: VTK_USE_X VTK_USE_X-MODIFIED:INTERNAL=ON //ADVANCED property for variable: VTK_WGLEXT_FILE VTK_WGLEXT_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_WRAP_HINTS VTK_WRAP_HINTS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_WRAP_JAVA VTK_WRAP_JAVA-ADVANCED:INTERNAL=1 //Wrap VTK classes into the Python language. VTK_WRAP_PYTHON:INTERNAL=ON //Location of program to do Python wrapping VTK_WRAP_PYTHON_EXE:INTERNAL=/home/kvm/projects/ParaView-patch/bin/vtkWrapPython //Location of program to do Python wrapping VTK_WRAP_PYTHON_INIT_EXE:INTERNAL=/home/kvm/projects/ParaView-patch/bin/vtkWrapPythonInit //Wrap VTK classes into the TCL language. VTK_WRAP_TCL:INTERNAL=OFF //ADVANCED property for variable: X11_ICE_INCLUDE_PATH X11_ICE_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_ICE_LIB X11_ICE_LIB-ADVANCED:INTERNAL=1 //Have library /usr/lib64/libX11.so;/usr/lib64/libXext.so X11_LIB_X11_SOLO:INTERNAL=1 //ADVANCED property for variable: X11_SM_LIB X11_SM_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_X11_INCLUDE_PATH X11_X11_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_X11_LIB X11_X11_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XShm_INCLUDE_PATH X11_XShm_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XTest_INCLUDE_PATH X11_XTest_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XTest_LIB X11_XTest_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xaccessrules_INCLUDE_PATH X11_Xaccessrules_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xaccessstr_INCLUDE_PATH X11_Xaccessstr_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xau_INCLUDE_PATH X11_Xau_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xau_LIB X11_Xau_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcomposite_INCLUDE_PATH X11_Xcomposite_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcomposite_LIB X11_Xcomposite_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcursor_INCLUDE_PATH X11_Xcursor_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcursor_LIB X11_Xcursor_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdamage_INCLUDE_PATH X11_Xdamage_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdamage_LIB X11_Xdamage_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdmcp_INCLUDE_PATH X11_Xdmcp_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdmcp_LIB X11_Xdmcp_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xext_LIB X11_Xext_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xfixes_INCLUDE_PATH X11_Xfixes_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xfixes_LIB X11_Xfixes_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xft_INCLUDE_PATH X11_Xft_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xft_LIB X11_Xft_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xi_INCLUDE_PATH X11_Xi_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xi_LIB X11_Xi_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinerama_INCLUDE_PATH X11_Xinerama_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinerama_LIB X11_Xinerama_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinput_INCLUDE_PATH X11_Xinput_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinput_LIB X11_Xinput_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkb_INCLUDE_PATH X11_Xkb_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkblib_INCLUDE_PATH X11_Xkblib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xlib_INCLUDE_PATH X11_Xlib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xpm_INCLUDE_PATH X11_Xpm_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xpm_LIB X11_Xpm_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrandr_INCLUDE_PATH X11_Xrandr_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrandr_LIB X11_Xrandr_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrender_INCLUDE_PATH X11_Xrender_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrender_LIB X11_Xrender_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xscreensaver_INCLUDE_PATH X11_Xscreensaver_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xscreensaver_LIB X11_Xscreensaver_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xshape_INCLUDE_PATH X11_Xshape_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xt_INCLUDE_PATH X11_Xt_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xt_LIB X11_Xt_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xutil_INCLUDE_PATH X11_Xutil_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xv_INCLUDE_PATH X11_Xv_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xv_LIB X11_Xv_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xxf86misc_LIB X11_Xxf86misc_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_dpms_INCLUDE_PATH X11_dpms_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_xf86misc_INCLUDE_PATH X11_xf86misc_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_xf86vmode_INCLUDE_PATH X11_xf86vmode_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_BUILD_UTILS XDMF_BUILD_UTILS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_HAS_NDGM XDMF_HAS_NDGM-ADVANCED:INTERNAL=1 //Whether streams support 64-bit types XDMF_HAVE_64BIT_STREAMS:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_FCNTL XDMF_HAVE_FCNTL-ADVANCED:INTERNAL=1 //Have include malloc.h XDMF_HAVE_MALLOC_H:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_MMAN XDMF_HAVE_MMAN-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_NETINET XDMF_HAVE_NETINET-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_REGENERATE_WRAPPERS XDMF_REGENERATE_WRAPPERS-ADVANCED:INTERNAL=1 //Regenerate XdmfPython.cxx XDMF_REGENERATE_WRAPPERS:INTERNAL=OFF //ADVANCED property for variable: XDMF_REGENERATE_YACCLEX XDMF_REGENERATE_YACCLEX-ADVANCED:INTERNAL=1 //Regenerate XdmfExprYacc.cxx and XdmfExprLex.cxx XDMF_REGENERATE_YACCLEX:INTERNAL=OFF //ADVANCED property for variable: XDMF_USE_BZIP2 XDMF_USE_BZIP2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_USE_GZIP XDMF_USE_GZIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_USE_MYSQL XDMF_USE_MYSQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_WRAP_CSHARP XDMF_WRAP_CSHARP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_WRAP_PYTHON XDMF_WRAP_PYTHON-ADVANCED:INTERNAL=1 XDMF_WRAP_TCL:INTERNAL=OFF //Have function _isinf float.h:INTERNAL= ![]() ![]() #!/bin/bash #PBS -S /bin/bash # run paraview 3.8 job in parallel # set default resource requirements for job # - these can be overridden on the qsub command line #PBS -l nodes=1:ppn=4 #PBS -l walltime=2:00:00 #Change to directory from which job was submitted cd $PBS_O_WORKDIR # set number of processors to run on (using list of node names in file $PBS_NODEFILE) nprocs=`wc -l $PBS_NODEFILE | awk '{ print $1 }'` # load modules so that we find the pvbatch command module load gcc module load openmpi/1.3.3/gcc module load use.own module load pvbatch38-patch mpirun -n $nprocs pvbatch --use-offscreen-rendering Q38.py ![]() ![]() ![]() | ||||||||
(0021489) Koen van Mierlo (reporter) 2010-07-27 04:44 |
I compiled paraview 3.8 with OSmesa 6.5.3 to check if this bug depends on the version of OSmesa. I get exactly the same output with OSmesa 6.5.3 so the version of OSmesa doesn't make a difference. |
(0021490) Koen van Mierlo (reporter) 2010-07-27 06:54 |
I have added output and error files from the 1 node (8 cores) and 2 nodes (16 cores) jobs. They seem to suggest that on the multiple node job the pvbatch process is killed as soon as 1 core has done the rendering and that it doesn't wait until all cores are done. |
(0022138) Koen van Mierlo (reporter) 2010-09-08 13:48 |
I thought that the bug could be caused by openmpi so I compiled a new version of openmpi (1.4.2). Unfortunately the bug is still there when I compile paraview 3.8.0 with osmesa 7.8.2 and openmpi 1.4.2 |
(0022252) Alan Scott (manager) 2010-09-15 22:17 |
We are having problems with newer versions of Mesa. Please ask the users list (which is read by Kitware) for feedback on which version of Mesa to use. If this fixes your problem, please then mark this bug "resolved" with a comment stating what you did to fix it. Alan |
(0022318) Koen van Mierlo (reporter) 2010-09-22 11:55 |
The paraview mailing list suggest to use either mesa 7.5.x or a development mesa from git. I don't know how to use git so instead I compiled osmesa 7.5.2 and the newest release candidate osmesa 7.8.3-rc1. Unfortunately the output is the same and the render error persists. I use the following command to configure / compile the osmesa library: ./configure --with-driver=osmesa --without-x --disable-glu --disable-egl --disable-gallium --prefix=/home/kvm/mesa752 --exec_prefix=/home/kvm/mesa752 |
(0022365) thorenz (reporter) 2010-09-27 10:05 |
Hello Koen, I tried to get Paraview with Mesa to work on our cluster. After several attempts I got it work, here it works fine now with 96 processes in parallel. Due to several dependencies, I can not use Mesa-7.5.x (or later), but have to use Mesa-7.2. I struggled a lot to get it to work, anyhow. The main clues for me were: - NEVER go back in the ccmake process for Paraview. Never never never change an option to one value first and to another later. In that case, completely remove the contents from the build directory and start from scratch. Otherwise you can have strange side effects. - Use different compilations for Mesa on the frontend and the nodes of the cluster (i.e. compile two versions of Mesa: With DRI (or whatever) for the frontend, without DRI, without X and with GLU for the nodes) - Use two different compilations of Paraview for frontend and nodes: The first one with X, the second without X, without PARAVIEW_BUIL_QT_GUI, with OSMESA, without OPENGL_INCLUDE_DIR, without OPENGL_gl_LIBRARY, with OPENGL_glu_LIBRARY=qmesa-libglu - Set LD_LIBRARY_PATH, so that the correct version of Mesa is loaded for frontend and nodes. Hope it helps, Carsten |
(0023752) Koen van Mierlo (reporter) 2010-12-07 09:20 |
Unfortunately this bug still exists with paraview 3.8.1 and OSmesa 7.9. Everything works fine when I submit a 1 node (8 core) pvbatch job to the cluster but the rendering goes wrong when I submit a 2 or more node job. |
(0037860) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-07-26 15:34 | Koen van Mierlo | New Issue | |
2010-07-26 15:34 | Koen van Mierlo | File Added: 4.png | |
2010-07-26 15:35 | Koen van Mierlo | File Added: 8.png | |
2010-07-26 15:35 | Koen van Mierlo | File Added: 16.png | |
2010-07-26 15:35 | Koen van Mierlo | File Added: 32.png | |
2010-07-26 15:35 | Koen van Mierlo | File Added: CMakeCache.txt | |
2010-07-26 15:36 | Koen van Mierlo | File Added: Q38.py | |
2010-07-26 15:36 | Koen van Mierlo | File Added: run_pv38_QY | |
2010-07-27 04:44 | Koen van Mierlo | Note Added: 0021489 | |
2010-07-27 06:54 | Koen van Mierlo | Note Added: 0021490 | |
2010-07-27 06:54 | Koen van Mierlo | File Added: run_pv38_8.o | |
2010-07-27 06:55 | Koen van Mierlo | File Added: run_pv38_16.o | |
2010-07-27 06:55 | Koen van Mierlo | File Added: run_pv38_16.e | |
2010-09-08 13:48 | Koen van Mierlo | Note Added: 0022138 | |
2010-09-15 22:17 | Alan Scott | Note Added: 0022252 | |
2010-09-22 11:55 | Koen van Mierlo | Note Added: 0022318 | |
2010-09-27 10:05 | thorenz | Note Added: 0022365 | |
2010-12-07 09:20 | Koen van Mierlo | Note Added: 0023752 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037860 | |
2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
