View Issue Details [ Jump to Notes ] | [ Print ] |
0011073 | ParaView | Bug | public | 2010-07-30 12:30 | 2016-08-12 09:58 |
Reporter | Thomas Clark | |
Assigned To | Kitware Robot | |
Priority | normal | Severity | major | Reproducibility | always |
Status | closed | Resolution | moved | |
Product Version | 3.8 | |
Target Version | | Fixed in Version | | |
Summary | 0011073: Extract Surfaces filter not working correctly on imported fluent.cas files |
Description | I import an ASCII format Fluent Case (*.cas) file, with it's companion .dat file.
I then perform an 'extract surfaces' filter. The true surface is extracted, but some grid connectivity must be lost in the import, as there are curious artefacts on the surface - faces of cells adjacent to the true surface are also extracted, resulting in the 'double surface' or 'castellation' shown in the attached image.
I can supply a Case file and Paraview state file featuring this problem if required (~310mb in zipped form). |
Additional Information | Also observed in earlier versions of Paraview. |
Tags | No tags attached. |
Project | |
Topic Name | |
Type | |
Attached Files | incorrectSurfaceExtraction.png [^] (212,517 bytes) 2010-07-30 12:30
