0011117 | ParaView | Bug | public | 2010-08-11 15:58 | 2016-07-13 15:23 | ||||
Assigned To | Alan Scott | ||||||||
Summary | 0011117: Color legend needs to be wider of use smaller fonts | ||||||||
Description | I have a user that has made complaints about font layout on the color scale editor. After looking at it, I think he has a seed of truth to his complaint. Use case: ParaView trunk, local server, Windows. Open disk_out_ref.exo. Calculator. Use GlobalNodeId*1e6-1e6+1.2345678 in the formula. Color Legend. With Windows, if you make ParaView non full screened, and grab the right edge of the ParaView Window, and move it slowly left and right, you will see that the max values will bounce from 1 to 2 digits. Either the Color Legend needs to be widened so this doesn't happen, or the the font needs to be smaller so this doesn't happen. Min and Max should never have fewer than 2 digits of precision. See attached screenshot. Note that I was using the default width for the color editor. | ||||||||
Attached Files | colorLegendExponent.png [^] (52,263 bytes) 2010-08-11 15:58
(0036402) Alan Scott (manager) 2016-07-13 15:23 |
Color legend has been replaced, and looks fine. Closing. |
2010-08-11 15:58 | Alan Scott | New Issue | |
2010-08-11 15:58 | Alan Scott | File Added: colorLegendExponent.png | |
2016-07-13 15:23 | Alan Scott | Note Added: 0036402 | |
2016-07-13 15:23 | Alan Scott | Status | expired => closed |
2016-07-13 15:23 | Alan Scott | Assigned To | => Alan Scott |
2016-07-13 15:23 | Alan Scott | Resolution | open => fixed |
