0011163 | ParaView | Bug | public | 2010-08-23 15:09 | 2010-09-15 19:48 | ||||
Priority | urgent | Severity | crash | Reproducibility | always | ||||
Target Version | 3.8.1 | Fixed in Version | |||||||
Summary | 0011163: ParaView crashes always SSH'ing into a mesa build | ||||||||
Description | ParaView 3.8.1, as of Friday 8/20. Cygwin, ssh -X into a Linux box. From there, do a client/server connect to a mesa build. It will crash when it tries to start up. I get the following output: pvserver: main/renderbuffer.c:1924: _mesa_add_renderbuffer: Assertion `bufferName == BUFFER_DEPTH || bufferName == BUFFER_STENCIL || fb->Attachment[bufferName].Renderbuffer == ((void *)0)' failed. [rs1749:21412] *** Process received signal *** This is using Mesa-7.8.2, although I don't expect it to change for other versions of ParaView. The free world as we know it today won't end if this doesn't get fixed, but it would be a REALLY NICE THING TO HAVE for 3.8.1. | ||||||||
Relationships | |||||||
(0021931) David Partyka (developer) 2010-08-24 16:17 edited on: 2010-08-24 16:18 |
Confirmed. Providing the backtrace. Note that I did this all on one machine instead of Alan's use case of running pvserver on a 3rd machine. Also --use-offscreen-rendering is required to reproduce. (gdb) bt #0 0x00007fffeb62fa75 in raise () from /lib/libc.so.6 #1 0x00007fffeb6335c0 in abort () from /lib/libc.so.6 #2 0x00007fffeb628941 in __assert_fail () from /lib/libc.so.6 #3 0x00007fffeacc2e4c in _mesa_add_renderbuffer (fb=0xbb95c0, bufferName=<value optimized out>, rb=0xbddd80) at main/renderbuffer.c:1922 #4 0x00007fffeac7b5dd in OSMesaMakeCurrent (osmesa=0xb69730, buffer=0x7fffe734f010, type=<value optimized out>, width=1299, height=<value optimized out>) at osmesa.c:1332 #5 0x00007fffef4e6687 in vtkXOpenGLRenderWindow::MakeCurrent (this=0xb29c80) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkXOpenGLRenderWindow.cxx:1318 #6 0x00007fffef4e587a in vtkXOpenGLRenderWindow::CreateOffScreenWindow (this=0xb29c80, width=1299, height=926) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkXOpenGLRenderWindow.cxx:940 #7 0x00007fffef4e5d7d in vtkXOpenGLRenderWindow::Initialize (this=0xb29c80) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkXOpenGLRenderWindow.cxx:1066 #8 0x00007fffef4e6183 in vtkXOpenGLRenderWindow::Start (this=0xb29c80) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkXOpenGLRenderWindow.cxx:1185 0000009 0x00007fffef3a168f in vtkRenderWindow::DoStereoRender (this=0xb29c80) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkRenderWindow.cxx:687 #10 0x00007fffef3a1660 in vtkRenderWindow::DoFDRender (this=0xb29c80) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkRenderWindow.cxx:676 0000011 0x00007fffef3a1117 in vtkRenderWindow::DoAARender (this=0xb29c80) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkRenderWindow.cxx:563 #12 0x00007fffef3a06ed in vtkRenderWindow::Render (this=0xb29c80) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkRenderWindow.cxx:376 #13 0x00007fffef4e8ba5 in vtkXOpenGLRenderWindow::Render (this=0xb29c80) at /home/partyd/Kitware/ParaView/src/VTK/Rendering/vtkXOpenGLRenderWindow.cxx:1845 #14 0x00007ffff0b65071 in vtkParallelRenderManager::RenderRMI (this=0xb1d890) at /home/partyd/Kitware/ParaView/src/VTK/Parallel/vtkParallelRenderManager.cxx:756 #15 0x00007ffff75ee7d2 in vtkPVClientServerRenderManager::RenderRMI (this=0xb1d890) at /home/partyd/Kitware/ParaView/src/Servers/Filters/vtkPVClientServerRenderManager.h:55 #16 0x00007ffff75ed56b in RenderRMI (arg=0xb1d890) at /home/partyd/Kitware/ParaView/src/Servers/Filters/vtkPVClientServerRenderManager.cxx:57 #17 0x00007ffff0a851c8 in vtkMultiProcessController::ProcessRMI (this=0xb18200, remoteProcessId=1, arg=0x0, argLength=0, rmiTag=34532) at /home/partyd/Kitware/ParaView/src/VTK/Parallel/vtkMultiProcessController.cxx:636 #18 0x00007ffff0a85004 in vtkMultiProcessController::ProcessRMIs (this=0xb18200, reportErrors=0, dont_loop=1) at /home/partyd/Kitware/ParaView/src/VTK/Parallel/vtkMultiProcessController.cxx:600 #19 0x00007ffff7b62c4a in vtkRemoteConnection::ProcessCommunication (this=0xb098e0) at /home/partyd/Kitware/ParaView/src/Servers/Common/vtkRemoteConnection.cxx:74 #20 0x00007ffff7aeb17a in vtkProcessModuleConnectionManager::MonitorConnections (this=0x97c710, msec=0) at /home/partyd/Kitware/ParaView/src/Servers/Common/vtkProcessModuleConnectionManager.cxx:435 #21 0x00007ffff7af40b6 in vtkProcessModule::StartServer (this=0x64e630, msec=0) at /home/partyd/Kitware/ParaView/src/Servers/Common/vtkProcessModule.cxx:446 #22 0x00007ffff7af3b31 in vtkProcessModule::Start (this=0x64e630, argc=1, argv=0x64c8d0) at /home/partyd/Kitware/ParaView/src/Servers/Common/vtkProcessModule.cxx:357 #23 0x00007ffff763f39b in vtkPVMain::Run (this=0x64c3f0, options=0x64c140) at /home/partyd/Kitware/ParaView/src/Servers/Filters/vtkPVMain.cxx:276 #24 0x00000000004012cf in main (argc=2, argv=0x7fffffffe678) at /home/partyd/Kitware/ParaView/src/Servers/Executables/pvserver.cxx:45 |
(0021934) David Partyka (developer) 2010-08-24 17:07 |
This apparently is a Mesa bug. MakeCurrent() is recreating the render buffer each time it is called. The second time it is called in vtkXOpenGLRenderWindow it crashes. A bug report will be filed with the Mesa developers. |
(0022017) Utkarsh Ayachit (administrator) 2010-08-31 09:34 |
Mesa bug. |
(0022244) Alan Scott (manager) 2010-09-15 19:48 |
Agreed, this is a Mesa bug. Successful compiles are done using the Mesa from Kitware. |
2010-08-23 15:09 | Alan Scott | New Issue | |
2010-08-23 16:28 | David Partyka | Status | backlog => tabled |
2010-08-23 16:28 | David Partyka | Assigned To | => David Partyka |
2010-08-24 16:17 | David Partyka | Note Added: 0021931 | |
2010-08-24 16:18 | David Partyka | Note Edited: 0021931 | |
2010-08-24 17:07 | David Partyka | Note Added: 0021934 | |
2010-08-31 09:34 | Utkarsh Ayachit | Note Added: 0022017 | |
2010-08-31 09:34 | Utkarsh Ayachit | Relationship added | duplicate of 0010900 |
2010-08-31 09:34 | Utkarsh Ayachit | Duplicate ID | 0 => 10900 |
2010-08-31 09:34 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-08-31 09:34 | Utkarsh Ayachit | Resolution | open => fixed |
2010-09-15 19:48 | Alan Scott | Note Added: 0022244 | |
2010-09-15 19:48 | Alan Scott | Status | @80@ => closed |
