| 0011211 | ParaView | Bug | public | 2010-09-07 04:23 | 2010-12-07 17:29 | ||||
| Reporter | thorenz | ||||||||
| Assigned To | Robert Maynard | ||||||||
| Priority | normal | Severity | major | Reproducibility | always | ||||
| Product Version | Development | ||||||||
| Target Version | Fixed in Version | 3.10 | |||||||
| Summary | 0011211: ParaView-3.9.0 gives wrong contour (iso-surface) on OpenFOAM-datasets | ||||||||
| Description | When reading an OpenFOAM-dataset, the contour filter (iso-surface would be a better name :) doesn't work correctly. In the applied file "openfoam_surface.jpg" you see the variable "alpha1" plotted on the surface. The contour filter for alpha1=0.5 should extract a surface between red and blue areas. Instead a strange surface is generated which covers many cells (openfoam_contour.jpg) but which is not the iso-surface. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | ![]() | ||||||||
| Relationships | |
| Relationships |
| Notes | |
(0022175) thorenz (reporter) 2010-09-10 02:40 |
The same is true for Paraview 3.8 |
(0022271) thorenz (reporter) 2010-09-20 03:48 |
The situation can be "cured" by applying the "Clean to Grid"-Filter on the dataset first. |
(0022348) Takuya OSHIMA (reporter) 2010-09-26 02:19 |
Can you share a dataset that causes the problem and give the exact procedure to replicate? |
(0022358) thorenz (reporter) 2010-09-27 03:31 |
Hello Takuya, I uploaded a testcase to our ftp: ftp://ftp.baw.de/incoming/test.zip [^] Sorry, it is 800MB. Currently, I don't have a smaller one that shows the problem. The procedure is the following: - load "result.foam" - select "Decomposed case" - Apply - filter "Contour" with alpha1=0.5 I hope you can reproduce it :) Carsten P.S: Many thanks for vtkPOpenFOAMReader. It helps a lot :) I'm using it on our cluster and it gave me ~10x speed improve because of parallel data reading. |
(0022359) Takuya OSHIMA (reporter) 2010-09-27 06:09 |
A 96 processor case. Cool :) Yes it did reproduce, however only when I selected cell-alpha1 (alpha1 with a cube on its left) from the Contour By combo box. There should be another alpha1 (point-alpha1, alpha1 with a dot on its left), and when I selected it the contour filter ran fine (I attached arraySelectionScreenshot.png to show which array to choose). If my understanding is right the contour filter only works with the point-arrays, so the cell-arrays should not be in the selection list. I'm not sure which (the reader or the contour filter) is causing the problem but anyhow, please try the point-alpha1. Takuya |
(0022360) thorenz (reporter) 2010-09-27 08:49 |
Hi Takuya, the "point-alpha1" is not in the data set, it is generated by the OpenFOAM reader. Alpha1 is a cell centered quantity in OpenFOAM. You are right, using it without interpolating to the nodes causes the problem. So, is this a bug in the reader or in the filter? I don't know, but I got a workaround now: Use the point data :) |
(0022362) thorenz (reporter) 2010-09-27 09:08 |
Update: I just tried to read another unstructured dataset written from another code in Ensight format. It shows the same behaviour: The regarded quantity is cell centered, "Contour" filter gives garbage. Applying "Cell to point" first and "Contour" on the point data afterwards gives correct result. So, it seems to be a problem in the Contour filter. |
(0022531) Takuya OSHIMA (reporter) 2010-10-19 05:15 |
I can confirm in the git master that the cell-arrays are no longer listed in the array selection of the contour panel, probably thanks to the following commit. Could someone please mark this bug as resolved? commit a844b9eb4ca130b344da40435ec50764897d4b57 Merge: e98c0a7 2036cc1 Author: Robert Maynard <robert.maynard@kitware.com> Date: Mon Oct 18 13:22:58 2010 -0400 Merge topic 'AutomaticPropertyConversion' 2036cc1 BUG: Corrected an issue with the contour filter supporting cell prop |
(0023727) thorenz (reporter) 2010-12-06 04:31 edited on: 2010-12-06 04:31 |
Checked out Paraview-3.9 on 2010-12-06 Now it works o.k. |
(0023732) Robert Maynard (developer) 2010-12-06 09:26 |
Corrected an issue with the contour filter supporting cell properties when it should only support point properties by default. |
(0023780) Alan Scott (manager) 2010-12-07 17:29 |
As per reporter, and tested local server, windows client, trunk. |
| Notes |
| Issue History | |||
| 2010-09-07 04:23 | thorenz | New Issue | |
| 2010-09-07 04:23 | thorenz | File Added: pics.zip | |
| 2010-09-10 02:40 | thorenz | Note Added: 0022175 | |
| 2010-09-20 03:48 | thorenz | Note Added: 0022271 | |
| 2010-09-26 02:19 | Takuya OSHIMA | Note Added: 0022348 | |
| 2010-09-27 03:31 | thorenz | Note Added: 0022358 | |
| 2010-09-27 06:08 | Takuya OSHIMA | File Added: arraySelectionScreenshot.png | |
| 2010-09-27 06:09 | Takuya OSHIMA | Note Added: 0022359 | |
| 2010-09-27 08:49 | thorenz | Note Added: 0022360 | |
| 2010-09-27 09:08 | thorenz | Note Added: 0022362 | |
| 2010-10-19 05:15 | Takuya OSHIMA | Note Added: 0022531 | |
| 2010-12-05 21:34 | David Partyka | Assigned To | => Robert Maynard |
| 2010-12-05 21:34 | David Partyka | Status | backlog => tabled |
| 2010-12-06 04:31 | thorenz | Note Added: 0023727 | |
| 2010-12-06 04:31 | thorenz | Note Edited: 0023727 | |
| 2010-12-06 09:26 | Robert Maynard | Note Added: 0023732 | |
| 2010-12-06 09:26 | Robert Maynard | Status | tabled => @80@ |
| 2010-12-06 09:26 | Robert Maynard | Fixed in Version | => 3.10 |
| 2010-12-06 09:26 | Robert Maynard | Resolution | open => fixed |
| 2010-12-07 17:29 | Alan Scott | Note Added: 0023780 | |
| 2010-12-07 17:29 | Alan Scott | Status | @80@ => closed |
| Issue History |
