0011352 | ParaView | Bug | public | 2010-10-22 05:18 | 2016-08-12 09:58 | ||||
Reporter | phil627 | ||||||||
Product Version | 3.8.1 | ||||||||
Summary | 0011352: Saving of views does not work properly when 'Use Parallel Projection' is switched on. | ||||||||
Description | I want to compare datasets and need to use the same view to do so. I can do this by saving views in the camera settings menu but I have noticed that this only works if I have 'Use Parallel Projection' turned off. This feature should work whether you have parallel projection turned on or off. | ||||||||
Additional Information | This problem can be demonstrated by: 1) start pv 2) enable parallel projection 3) make a cone source with the default values 4) change the view noticeably: rotate, shift, move out, etc, etc ... 5) from the camera dialog, save the camera config 6) close pv 7) start a new pv 8) make a cone source 9) from the camera dialog, load the camera config you saved in step 4 | ||||||||
(0037890) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-10-22 05:18 | phil627 | New Issue | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037890 | |
2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
