0011417 | ParaView | Bug | public | 2010-11-08 17:37 | 2010-11-09 16:25 | ||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0011417: Display/ Transform doesn't auto apply properly | ||||||||
Description | There are cases where the Display/ Transform doesn't seem to work correctly. Local server, Windows, Trunk. Open can.exo. All vars on, apply. Display tab, Transform. Change Origin to X == 10. Click in the Y entry box. Nothing happens. Change Scale to X == 2. Click in the Y entry box. We get two things - scaling, and origin movement. Origin should change without having to change something else. | ||||||||
(0023097) Utkarsh Ayachit (administrator) 2010-11-09 09:17 |
Origin is the point around which scaling or rotation should happen. With default scale and orientation, origin cannot produce any effect. |
(0023111) Alan Scott (manager) 2010-11-09 16:25 |
Ah, that makes sense. Closed. |
2010-11-08 17:37 | Alan Scott | New Issue | |
2010-11-09 09:17 | Utkarsh Ayachit | Note Added: 0023097 | |
2010-11-09 09:17 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-11-09 09:17 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2010-11-09 09:17 | Utkarsh Ayachit | Resolution | open => no change required |
2010-11-09 09:17 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-11-09 16:25 | Alan Scott | Note Added: 0023111 | |
2010-11-09 16:25 | Alan Scott | Status | @80@ => closed |
