0011567 | ParaView | Bug | public | 2010-12-03 12:42 | 2016-08-12 09:58 | ||||
Reporter | Sebastien Jourdain | ||||||||
Assigned To | Sebastien Jourdain | ||||||||
Product Version | 3.10 | ||||||||
Summary | 0011567: Merge MarkSelection filter with SortedTableStreamer | ||||||||
Description | Right now the pipeline sorting algorithm fully execute for each selection change even if only the selection change. This selection information should be handle by the SortedTableStreamer to prevent sorting the array when nothing change. Except for the selection. | ||||||||
Steps To Reproduce | Print in BuildCache and make sure this is not called when selection is changed and only when sorting action occurs. | ||||||||
(0037901) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-12-03 12:42 | Sebastien Jourdain | New Issue | |
2010-12-03 12:42 | Sebastien Jourdain | Status | backlog => tabled |
2010-12-03 12:42 | Sebastien Jourdain | Assigned To | => Sebastiennn Jourdain |
2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037901 | |
