0011716 | ParaView | Bug | public | 2011-01-17 15:11 | 2016-08-12 09:59 | ||||
Reporter | Jean M. Favre | ||||||||
Assigned To | Haocheng Liu | ||||||||
Platform | ALL OS | OS | OS Version | ||||||
Summary | 0011716: Reflect filter does not flip vectors unless there are returned by inCD->GetVectors() | ||||||||
Description | I thought the usage of SetActiveVectors or SetActiveScalars() was considered obsolete in ParaView, since there cannot be more than one such DataArray at a time. Filters such as vtkReflectionFilter which do a GetVectors() to find the vector to flip ignore all other vectors which are simply copied via outPD->CopyData(inPD, i, ptId); this is a bug, and results in wrong streamlines and all other vector displays in reflected surfaces in ParaView. | ||||||||
Steps To Reproduce | load the supplied file with vector "CF". Reflect across Z axis and display vector glyphs or streamlines. They are wrong on the reflected side. | ||||||||
Project | TBD | ||||||||
Attached Files | ![]() | ||||||||
(0033626) Cory Quammen (developer) 2014-10-10 10:41 |
I confirmed that this is still an issue in 4.2. |
(0035102) Menno Deij (reporter) 2015-08-31 07:09 edited on: 2015-08-31 07:09 |
This still is an issue in origin/master. |
(0035843) Menno Deij (reporter) 2016-03-16 05:44 |
Still an issue. It seems the origin of the problem is that the vtkDataSetAttributes::VECTORS attribute is not used properly in some readers and filters(?). A workaround in ParaView for surface vectors is to use the Surface Vectors filter, which sets the VECTORS attribute. For volume vectors there is no such workaround. |
(0038085) Kitware Robot (administrator) 2016-08-12 09:59 |
2011-01-17 15:11 | Jean M. Favre | New Issue | |
2011-01-17 15:11 | Jean M. Favre | File Added: reflect_0_0.vts | |
2014-10-10 10:41 | Cory Quammen | Note Added: 0033626 | |
2015-08-31 07:09 | Menno Deij | Note Added: 0035102 | |
2015-08-31 07:09 | Menno Deij | Note Edited: 0035102 | |
2016-03-16 05:44 | Menno Deij | Note Added: 0035843 | |
2016-07-25 15:43 | Haocheng Liu | Project | => TBD |
2016-07-25 15:43 | Haocheng Liu | Type | => incorrect functionality |
2016-07-25 15:43 | Haocheng Liu | Assigned To | => Haocheng Liu |
2016-07-25 15:43 | Haocheng Liu | Status | backlog => active development |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038085 | |
2016-08-12 09:59 | Kitware Robot | Status | active development => closed |
