0011718ParaViewBugpublic2011-01-18 11:172015-01-02 10:45
ReporterUtkarsh Ayachit
Assigned ToCory Quammen
StatusclosedResolutionno change required
PlatformOSOS Version
Product VersionDevelopment
Target VersionFixed in Version4.3
Summary0011718: Slice Offsets don't work as expected.
Description* Wavelet
* Slice
* Delete All Offsets
* Add 10 offsets using "New Range" (default parameters).
* Apply
* delete first 2 and last 2 values. HIt apply. You'll see 6 planes. So far so good.
* now delete middle 4. Hit apply. You should see only 2 planes. You see far more.
I've verified that ParaView is calling the API correctly on vtkCutter. Looks like vtkCutter is somehow not doing the right thing.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0033627)
Cory Quammen (developer)
2014-10-10 10:45
This appears to work as expected in 4.2.
(0033644)
2014-10-15 10:08
Topics merged into master:
        15025_fix_annotations
        15035_reverse_connections_dsrs
        15043_add_qmake_variable_back
        15044_update_example_plugins
        cmake-cmp0053-warnings
        live-breakpoint
        pv-plot-bar-lut
        visible_range
(0033771)
Alan Scott (manager)
2014-11-06 20:11
Tested as per Utkarsh's directions. Linux, local server, master.
 Issue History
2011-01-18 11:17 Utkarsh Ayachit New Issue
2014-10-10 10:45 Cory Quammen Note Added: 0033627
2014-10-10 10:45 Cory Quammen Status backlog => gatekeeper review
2014-10-10 10:45 Cory Quammen Resolution open => no change required
2014-10-10 10:45 Cory Quammen Assigned To => Cory Quammen
2014-10-15 10:08 Utkarsh Ayachit Fixed in Version => git-master
2014-10-15 10:08 Utkarsh Ayachit Status gatekeeper review => customer review
2014-10-15 10:08 Utkarsh Ayachit Note Added: 0033644
2014-11-06 20:11 Alan Scott Note Added: 0033771
2014-11-06 20:11 Alan Scott Status customer review => closed
2015-01-02 10:45 Utkarsh Ayachit Fixed in Version git-master => 4.3
