0011756 | ParaView | Bug | public | 2011-01-25 21:21 | 2016-07-13 21:29 | ||||
Assigned To | Robert Maynard | ||||||||
Summary | 0011756: Prism - Link selection bug | ||||||||
Description | Ask me for my tutorial on Prism, as well as data to run Prism. ParaView trunk, local server, Windows. Turn on contours, as well as showing the tables curves. Go to timestep 2. Now, with the SESAME surface as well as the 3D view showing, try to select cells through on the SESAME surface. You should be able to select the data - not the contours or curves. | ||||||||
Project | Sandia | ||||||||
(0028350) Greg Weirs (developer) 2012-03-09 13:43 |
As of 3.14.0 I observe that the sesame surface is selected rather than the simulation data. In 3.12.0 I think the problem selecting sesame curves and sesame contours (instead of simulation data) had been fixed for Select Cells ON. Select Cells Through is still problematic regardless. |
(0036452) Alan Scott (manager) 2016-07-13 21:29 |
Prism has gone away. Closing bug. |
2011-01-25 21:21 | Alan Scott | New Issue | |
2011-01-25 21:36 | Alan Scott | Description Updated | |
2011-03-25 15:29 | Robert Maynard | Assigned To | => Robert Maynard |
2011-03-25 15:29 | Robert Maynard | Status | backlog => tabled |
2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
2011-09-01 10:56 | Utkarsh Ayachit | Project | => Sandia |
2012-03-09 13:43 | Greg Weirs | Note Added: 0028350 | |
2016-07-13 21:29 | Alan Scott | Note Added: 0036452 | |
2016-07-13 21:29 | Alan Scott | Status | backlog => closed |
2016-07-13 21:29 | Alan Scott | Resolution | open => fixed |
