0011796 | ParaView | Feature | public | 2011-02-04 12:08 | 2016-08-12 09:58 | ||||
Reporter | David Doria | ||||||||
Platform | Linux | OS | Fedora | OS Version | 13 | ||||
Summary | 0011796: Smart context menu for outline representation | ||||||||
Description | The new smart context menus are awesome! The only trouble is, once you switch to "outline" view, you cannot right click on the object anymore to change it to something other than outline view - you have to use the old "Display" tab method. It is still possible to select the in wireframe mode (the line are the same thickness as the outline), so it should be possible to select the outline. | ||||||||
(0026988) Utkarsh Ayachit (administrator) 2011-07-11 13:09 |
A solution would be to that in selection mode the outline representation renders as a box with front face culling. That would avoid hinding any data normally visible inside the box. Of course, it still doesn't solve the problem with data behind the box. Maybe we play tricks with the death test instead? |
(0037918) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-02-04 12:08 | David Doria | New Issue | |
2011-07-11 13:09 | Utkarsh Ayachit | Note Added: 0026988 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037918 | |
