0011860 | VTK | (No Category) | public | 2011-02-15 04:25 | 2016-08-12 09:55 | ||||
Reporter | Anthony Geay | ||||||||
Assigned To | Dave DeMarle | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Platform | Linux32bits | OS | OS Version | ||||||
Summary | 0011860: Crash on vtkUnstructuredGrid::GetCell after DeepCopy of an instance containing polhyedrons | ||||||||
Description | Test on Paraview3.10 RC1. In attached file ret0 contains polyhedrons and hexaedrons. After a DeepCopy on ret0, ret instance seems to be incorrect that leads to a crach in GetCell. | ||||||||
Steps To Reproduce | The execution of the attached file leads to a SIGSEGV. When replacing line 122 ret by ret0 it is OK. It seems that DeepCopy method does not perform copy of additional arrays needed by polyhedrons. Regards | ||||||||
Attached Files | ![]() | ||||||||
(0031203) Dave DeMarle (administrator) 2013-07-22 18:57 |
If this is still an issue in PV4.0/VTK6.0.0 please reopen this report. |
(0037219) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2011-02-15 04:25 | Anthony Geay | New Issue | |
2011-02-15 04:25 | Anthony Geay | File Added: mainPolyhedron.cxx | |
2013-07-22 18:57 | Dave DeMarle | Note Added: 0031203 | |
2013-07-22 18:57 | Dave DeMarle | Status | backlog => expired |
2013-07-22 18:57 | Dave DeMarle | Assigned To | => Dave DeMarle |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037219 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
