0011865 | ParaView | Bug | public | 2011-02-15 17:15 | 2016-08-12 09:58 | ||||
Reporter | Orion Poplawski | ||||||||
Summary | 0011865: Cannot create GLX context. Aborting. | ||||||||
Description | When run over ssh without any glx capability, paraview aborts. It this is expected behavior, it should not call abort() which generates a core dump, but instead simply exit. If it should be able to run without a glx context this also a bug. $ paraview ERROR: In /builddir/build/BUILD/ParaView-3.10.0-RC1/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 404 vtkXOpenGLRenderWindow (0x2571fc0): Could not find a decent visual ERROR: In /builddir/build/BUILD/ParaView-3.10.0-RC1/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 404 vtkXOpenGLRenderWindow (0x2571fc0): Could not find a decent visual X Error: BadValue (integer parameter out of range for operation) 2 Extension: 136 (Uknown extension) Minor opcode: 3 (Unknown request) Resource id: 0x21 ERROR: In /builddir/build/BUILD/ParaView-3.10.0-RC1/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 631 vtkXOpenGLRenderWindow (0x2571fc0): Cannot create GLX context. Aborting. $ glxinfo name of display: localhost:12.0 Error: couldn't find RGB GLX visual or fbconfig | ||||||||
(0037927) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-02-15 17:15 | Orion Poplawski | New Issue | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037927 | |
