0011923 | ParaView | Bug | public | 2011-03-03 11:46 | 2015-01-11 08:35 | ||||
Reporter | Madhura Phadke | ||||||||
Priority | normal | Severity | trivial | Reproducibility | always | ||||
Platform | Ubuntu | OS | Ubuntu | OS Version | 10.04 | ||||
Target Version | 4.0 | Fixed in Version | 3.98.0 | ||||||
Summary | 0011923: Paraview 3.10 RC bits: unable to save animation | ||||||||
Description | I switched to Paraview 3.10.0 RC1 (downloaded from the website) and I get the following error when saving animation as a .avi file: Generic Warning: In /home/kitware/Projects/ParaView-3.10/source/VTK/IO/vtkFFMPEGWriter.cxx, line 211 Could not open codec. ERROR: In /home/kitware/Projects/ParaView-3.10/source/VTK/IO/vtkFFMPEGWriter.cxx, line 514 vtkFFMPEGWriter (0x12e902d0): Error initializing video stream. I noticed this error only when I give frame rate >1. I am able to save animation successfully if I give frame rate as 1fps. I am using Ubuntu 10.04, and I tried out saving animation of camera in orbit around the contour of a wavelet. | ||||||||
Steps To Reproduce | On Paraview 3.10 RC: 1. Create a source, and animate camera along the orbit. 2. Save animation using File Menu. 3. Select the options: -Save as .avi file -frame rate as 20 fps | ||||||||
Additional Information | Reply from David Partyka to my email: ------- I can recreate this bug with my own binary but also discovered it seems to work if the frame rate is a power of 2 (2,4,8,16,32,..). I have a feeling something is going wrong possibly computing bit rates etc when initializing ffmpeg. Do you mind also reporting a bug on ParaView.org/Bug. ------- | ||||||||
Project | TBD | ||||||||
Topic Name | 11923_fix_ffmpeg_fps_issues | ||||||||
(0025762) Alan Scott (manager) 2011-03-11 18:34 |
This is still present in 3.10.0 release. |
(0025763) Alan Scott (manager) 2011-03-11 18:34 |
Targeting 3.10.1. |
(0028328) phsiao (reporter) 2012-02-29 09:41 |
This is still present in 3.14.0 release. System Info: Mac OS X 10.6.8 CMake 2.8.7 Qt 4.6.3 ffmpeg 0.6.1 and 0.6.5 |
(0029434) Joe Borg (reporter) 2012-10-19 02:42 |
I have the same issue on Linux and OSX |
(0029507) Utkarsh Ayachit (administrator) 2012-10-24 17:59 |
commit 7850deb7e5f17ab76de2a2ac07ef40d7b7234adf Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Oct 24 17:56:07 2012 -0400 BUG 0011923. Fix computation of bit-rate-tolerance. Bit rate tolerance was being computed incorrectly when FrameRate > 1. There is no need to specify any bit-rate tolerance, so we simply use the default values, unless overridden by the user. Change-Id: If76321cc2689d64c6be98d23e561801f1d0bf41b |
(0029543) Utkarsh Ayachit (administrator) 2012-10-29 10:50 |
merged into master, if applicable. |
(0030101) Alan Scott (manager) 2013-01-11 14:11 |
I am pretty sure this is fixed. If it is still an issue, please reopen the bug with details how to replicate it (such as what dataset/source to use). Tested with can.exo, changed fps to 2 in save animation. Worked. Tested Windows, local server, master. |
2011-03-03 11:46 | Madhura Phadke | New Issue | |
2011-03-11 18:34 | Alan Scott | Note Added: 0025762 | |
2011-03-11 18:34 | Alan Scott | Note Added: 0025763 | |
2011-03-11 18:34 | Alan Scott | Target Version | => 3.10.1 |
2011-03-11 18:34 | Alan Scott | Description Updated | |
2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
2012-02-29 09:41 | phsiao | Note Added: 0028328 | |
2012-10-19 02:42 | Joe Borg | Note Added: 0029434 | |
2012-10-24 11:07 | Utkarsh Ayachit | Project | => TBD |
2012-10-24 11:07 | Utkarsh Ayachit | Type | => incorrect functionality |
2012-10-24 11:07 | Utkarsh Ayachit | Target Version | => 4.0 |
2012-10-24 17:59 | Utkarsh Ayachit | Topic Name | => 11923_fix_ffmpeg_fps_issues |
2012-10-24 17:59 | Utkarsh Ayachit | Note Added: 0029507 | |
2012-10-24 17:59 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-10-24 17:59 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-10-24 17:59 | Utkarsh Ayachit | Resolution | open => fixed |
2012-10-24 17:59 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-10-29 10:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-10-29 10:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-29 10:50 | Utkarsh Ayachit | Note Added: 0029543 | |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2013-01-11 14:11 | Alan Scott | Note Added: 0030101 | |
2013-01-11 14:11 | Alan Scott | Status | customer review => closed |
2015-01-09 13:47 | Dave DeMarle | Source_changeset_attached | => VTK master 3e4819c9 |
2015-01-09 13:48 | Dave DeMarle | Source_changeset_attached | => VTK master ecc05794 |
2015-01-09 13:48 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 7973caf8 |
2015-01-09 13:49 | Utkarsh Ayachit | Source_changeset_attached | => VTK master d9a0cdf3 |
2015-01-09 13:49 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 7850deb7 |
2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 60101e96 |
2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 6b6be702 |
