View Issue Details [ Jump to Notes ] [ Print ]
0012009ParaViewBugpublic2011-03-25 08:592016-08-12 09:58
ReporterArno Mayrhofer
Assigned ToUtkarsh Ayachit
StatusclosedResolutionmoved
PlatformFedora 14OSOS Version
Product Version
Summary0012009: Line Style None does not work
DescriptionI'm using version 3.10.0
Line Style = None does not show correct behaviour (i.e. no line). Instead it shows a kind of dotted line that moves if mouse is moved.
Steps To Reproduce# Open any data file that can be viewed in Line Chart View and that has at least two different variables that can be displayed.
# Untick all variables
# Tick one variable of choice
# Select Line Style "None"
# Move mouse when cursor is inside the Line Chart View
Additional InformationHowever, there is more to it.
If the variable you show is not the first one in the list, tick any variable above it (in the Line Series list) and the correct representation is shown again (i.e. line of lower variable vanishes).
If you then also set Line Style = None to the upper variable both variables will be shown incorrectly with dotted lines.
Note: Bug does not appear with 3.8.1
TagsNo tags attached.
Project
Topic Name
Type
Attached Filespng file icon linestylenonebug.png [^] (19,068 bytes) 2011-03-25 08:59
 Relationships
  Notes
(0026019)
2011-04-01 11:07
Could not reproduce this with git-master.
(0026104)
Alan Scott (manager)
2011-04-05 17:53
edited on: 2011-04-05 17:54
I also could not reproduce this - exactly. If it is still a problem, please try to reproduce with one of the datasets in the ParaView Data download, or attach a dataset. Then, give really detailed directions.
It is possible that you are seeing a different ... behavior. It is possible to select using the right mouse button - i.e., drag the selection box. Since the hidden line still exists, you will see selection marks showing what was selected. Could this be the issue?
Tested Linux, local server, trunk.
(0026954)
Arno Mayrhofer (reporter)
2011-07-05 07:01
Sorry for the reopen request. But this problem still exists and has become worse. Now I can't even change the line style anymore. Whatever I do I get a solid line.
One important thing that I discovered though is that it must be related to the OS. I'm now using Fedora 15 (!). If I login through VNC to this machine on my old laptop then Gnome 3 goes into fallback mode, as my laptop doesn't have 3D hardware acceleration. In that case PV works fine.
If somebody could check PV on a F15 machine as well that would be most interesting. I can imagine that there is no issue with other OSs. However, there could be one as soon as other distributions upgrade to Gnome 3.
(0026955)
2011-07-05 07:07
Small Update: I also tried VNC from the computer in question and tigerVNC apparently doesn't support Gnome 3 yet. So it also goes into fallback mode and everything works fine.
Btw. Marker Style, etc. work just fine everywhere.
(0027666)
2011-11-07 05:36
Well I had recently the possibility of using another F15 machine and there it works flawlessly. Must be a very specific problem somewhere. I guess if nobody else experiences this problem, this can be closed.
(0029639)
Scott Webster (reporter)
2012-11-01 13:10
edited on: 2012-11-01 13:18
I just installed the latest Paraview version set up for OpenFOAM (3.12.0 64-bit) and I basically have this problem. I'm not sure it is entirely identical, but I can't change the line style. Whatever I do, it stays solid. I can add markers, change the colour etc, but the line style is stuck.
Edit: tried with 3.14.1 and have the same problem.
There are some other strange things too, like when I choose to show markers the axes get thicker, can't turn off axes in the view settings dialog... when I change the chart axes drop down to something other than bottom-left then I get axes on more than just two sides of the plot...
(0029648)
2012-11-02 12:29
I also don't experience this problem when connecting to my machine remotely via VNC.
(0037945)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
 Issue History
2011-03-25 08:59 Arno Mayrhofer New Issue
2011-03-25 08:59 Arno Mayrhofer File Added: linestylenonebug.png
2011-04-01 11:07 Utkarsh Ayachit Note Added: 0026019
2011-04-01 11:07 Utkarsh Ayachit Status backlog => @80@
2011-04-01 11:07 Utkarsh Ayachit Resolution open => unable to reproduce
2011-04-01 11:07 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2011-04-05 17:53 Alan Scott Note Added: 0026104
2011-04-05 17:53 Alan Scott Status @80@ => closed
2011-04-05 17:54 Alan Scott Note Edited: 0026104
2011-07-05 07:01 Arno Mayrhofer Note Added: 0026954
2011-07-05 07:01 Arno Mayrhofer Status closed => backlog
2011-07-05 07:01 Arno Mayrhofer Resolution unable to reproduce => reopened
2011-07-05 07:07 Arno Mayrhofer Note Added: 0026955
2011-11-07 05:36 Arno Mayrhofer Note Added: 0027666
2012-11-01 13:10 Scott Webster Note Added: 0029639
2012-11-01 13:18 Scott Webster Note Edited: 0029639
2012-11-02 12:29 Scott Webster Note Added: 0029648
2016-08-12 09:58 Kitware Robot Note Added: 0037945
2016-08-12 09:58 Kitware Robot Status backlog => closed
2016-08-12 09:58 Kitware Robot Resolution reopened => moved
