0012043 | ParaView | Bug | public | 2011-04-04 11:47 | 2011-05-02 20:13 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | Nathan Fabian | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Summary | 0012043: vtkExodusIIWriter segfaults due to null pointer dereference for attached dataset | ||||||||
Description | Load attached file "sample.vtu" Save Data as "Exodus II File" => Crash in VTK/Parallel/vtkExodusIIWriter.cxx:1036 for (int j = 0; j < fd->GetNumberOfArrays (); j ++) { const char *name = fd->GetArray (j)->GetName (); due to fd->GetArray(j) returning a null pointer which is subsequently attempted to dereference. Tested with Linux 64bit build using git master (VTK commit dec7dbc6976a1dc9297a5ac59bdc66f9ae461a35) and official 64bit Linux binary release of ParaView 3.10.0 | ||||||||
Attached Files | sample.vtu [^] (2,050 bytes) 2011-04-04 11:47 0001-BUG-Fix-for-12043.-Detect-null-arrays-and-reports-er.patch [^] (2,063 bytes) 2011-04-13 04:35 [Show Content] | ||||||||
(0026172) Sven Buijssen (reporter) 2011-04-13 04:35 |
Suggested patch attached. |
(0026259) Nathan Fabian (developer) 2011-04-26 13:35 |
The patch looks correct from a defensive programming standpoint. I wonder why those arrays are coming in NULL. It seems to imply a problem further up the chain. I'm unable to apply the patch at the moment due to firewall issues. If someone has the capability to push that would be great, otherwise I'll push when I am able. |
(0026262) Nathan Fabian (developer) 2011-04-26 17:02 |
I was able to upload the patch. |
(0026400) Alan Scott (manager) 2011-05-02 20:13 |
Crash has been fixed. There is an output message that states the following: Warning: In ..\..\..\..\src\ParaView3\VTK\Parallel\vtkExodusIIWriter.cxx, line 1043 vtkExodusIIWriter (09784F38): Array in input field data has Null name, cannot output it Warning: In ..\..\..\..\src\ParaView3\VTK\Parallel\vtkExodusIIWriter.cxx, line 1043 vtkExodusIIWriter (09784F38): Array in input field data has Null name, cannot output it Since the reporter provided this patch, the writer seems to work, and this error output could be a different bug, I am closing this one. Tested Windows, trunk, local server. |
2011-04-04 11:47 | Sven Buijssen | New Issue | |
2011-04-04 11:47 | Sven Buijssen | File Added: sample.vtu | |
2011-04-13 04:35 | Sven Buijssen | File Added: 0001-BUG-Fix-for-12043.-Detect-null-arrays-and-reports-er.patch | |
2011-04-13 04:35 | Sven Buijssen | Note Added: 0026172 | |
2011-04-14 10:26 | Sebastien Jourdain | Assigned To | => Nathan Fabian |
2011-04-14 10:26 | Sebastien Jourdain | Status | backlog => tabled |
2011-04-26 13:35 | Nathan Fabian | Note Added: 0026259 | |
2011-04-26 17:02 | Nathan Fabian | Note Added: 0026262 | |
2011-04-26 17:02 | Nathan Fabian | Status | tabled => @80@ |
2011-04-26 17:02 | Nathan Fabian | Resolution | open => fixed |
2011-05-02 20:13 | Alan Scott | Note Added: 0026400 | |
2011-05-02 20:13 | Alan Scott | Status | @80@ => closed |
