0012100 | ParaView | Feature | public | 2011-04-18 07:38 | 2016-08-12 09:58 | ||||
Reporter | Jens Kleimann | ||||||||
Platform | any | OS | any | OS Version | any | ||||
Product Version | 3.10.1 | ||||||||
Summary | 0012100: A "Reload data" button would be nice. | ||||||||
Description | When finding the best parameters for a simulation, I often do repeated runs with small modifications, and then wish to see the effect on the data as visualized in Paraview. For such a cycle, it would be very helpful if there was a simple (one-click) way of telling Paraview to re-load all data files for the current pipeline into memory, and then to execute that pipeline based on the new data. As far as I can see, currently one has to erase the contents of the pipelien browser, then explicitly do File->Recent Files and select the desired file, and re-build the pipeline from scratch. | ||||||||
Relationships | ||||||
(0026210) Utkarsh Ayachit (administrator) 2011-04-18 08:37 |
Let's try to get this done for 4.0. This is the second most requested feature on the uservoice. |
(0037958) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-04-18 07:38 | Jens Kleimann | New Issue | |
2011-04-18 08:37 | Utkarsh Ayachit | Note Added: 0026210 | |
2011-04-18 08:37 | Utkarsh Ayachit | Target Version | => 4.0 |
2011-04-18 08:41 | Utkarsh Ayachit | Relationship added | duplicate of 0007314 |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037958 | |
