0012195 | ParaView | Bug | public | 2011-05-16 18:50 | 2016-07-25 22:27 | ||||
Reporter | Fa-Gung Fan | ||||||||
Assigned To | Cory Quammen | ||||||||
Platform | x86 64-bit | OS | Ubuntu 10.04 LTS 64-bit | OS Version | Ubuntu 10.04 LTS | ||||
Product Version | 3.10.1 | ||||||||
Summary | 0012195: ParaView slows to a halt even without doing anything | ||||||||
Description | I downloaded ParaView-3.10.1-Linux-x86_64.tar.gz binary from http://www.paraview.org/paraview/resources/software.html, [^] and used it on a Ubuntu 10.04 LTS 64-bit Dual Quad-Core Xeon processor PC. I turned on "Use Multi-core". However, I found that once ParaView starts, it grabs all CPU cycles even before doing anything. The software almost slows to a halt. Every action takes painfully long time to complete. | ||||||||
Steps To Reproduce | Download ParaView-3.10.1-Linux-x86_64.tar.gz binary and use it on a Ubuntu 10.04 LTS 64-bit PC. | ||||||||
(0036561) Cory Quammen (developer) 2016-07-25 13:05 |
Chances are the MPI version against which ParaView was built uses a busy loop when awaiting messages from process 0. Your best bet is to start MPI with one fewer processes than you have cores so that the UI remains responsive. |
(0036596) Alan Scott (manager) 2016-07-25 22:27 |
What Cory said. Closing. |
2011-05-16 18:50 | Fa-Gung Fan | New Issue | |
2016-07-25 13:05 | Cory Quammen | Note Added: 0036561 | |
2016-07-25 13:05 | Cory Quammen | Status | backlog => closed |
2016-07-25 13:05 | Cory Quammen | Assigned To | => Cory Quammen |
2016-07-25 13:05 | Cory Quammen | Resolution | open => no change required |
2016-07-25 22:24 | Cory Quammen | Status | closed => backlog |
2016-07-25 22:24 | Cory Quammen | Resolution | no change required => reopened |
2016-07-25 22:24 | Cory Quammen | Status | backlog => customer review |
2016-07-25 22:24 | Cory Quammen | Resolution | reopened => fixed |
2016-07-25 22:27 | Alan Scott | Note Added: 0036596 | |
2016-07-25 22:27 | Alan Scott | Status | customer review => closed |
