0012210 | ParaView | Bug | public | 2011-05-19 21:58 | 2013-10-01 13:31 | ||||
Reporter | Burlen | ||||||||
Assigned To | Burlen | ||||||||
Product Version | 3.10 | ||||||||
Summary | 0012210: surface lic with opacity < 1 shows process boundary in parallel run | ||||||||
Description | surface lic with opacity < 1 shows process boundary in parallel run tons of these in the terminal Process id: 1 >> Warning: In /work/ext/ParaView/ParaView-3.10.0/VTK/Rendering/vtkShaderProgram2.cxx, line 382 vtkShaderProgram2 (0x5d518c0): another program was used (id=15), our id is6. Process id: 0 >> Warning: In /work/ext/ParaView/ParaView-3.10.0/VTK/Rendering/vtkShaderProgram2.cxx, line 382 vtkShaderProgram2 (0x50c90d0): another program was used (id=8), our id is6. | ||||||||
Steps To Reproduce | load data slice surface lic opacity = 0.5 | ||||||||
Attached Files | bug_lic.png [^] (252,505 bytes) 2011-05-19 22:01
(0031670) Burlen (developer) 2013-10-01 13:31 |
this has been fixed |
2011-05-19 21:58 | Burlen | New Issue | |
2011-05-19 21:58 | Burlen | File Added: bug_lic.png | |
2011-05-19 22:01 | Burlen | Category | (No Category) => Bug |
2011-05-19 22:01 | Burlen | Description Updated | |
2011-05-19 22:01 | Burlen | File Deleted: bug_lic.png | |
2011-05-19 22:01 | Burlen | File Added: bug_lic.png | |
2013-06-05 17:12 | Burlen | Assigned To | => Burlen |
2013-10-01 13:31 | Burlen | Note Added: 0031670 | |
2013-10-01 13:31 | Burlen | Status | backlog => closed |
2013-10-01 13:31 | Burlen | Resolution | open => fixed |
