0012217 | ParaView | Bug | public | 2011-05-23 16:55 | 2016-08-12 09:58 | ||||
Reporter | Burlen | ||||||||
Priority | normal | Severity | minor | Reproducibility | sometimes | ||||
Product Version | 3.10 | ||||||||
Summary | 0012217: boundary artifacts visible in surface lic save screenshot w/ multiple views | ||||||||
Description | boundary artifacts visible in surface lic save screenshot w/ mutiple views. The attached image shows the issue. | ||||||||
Steps To Reproduce | use builtin connection load dataset surface lic 3 view's one for each vector save screenshot, all views. (if you need the data I could share it, 269MB) | ||||||||
Attached Files | test.png [^] (464,593 bytes) 2011-05-23 16:55 3-stack-y.png [^] (1,399,017 bytes) 2011-05-23 17:26 | ||||||||
(0037980) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-05-23 16:55 | Burlen | New Issue | |
2011-05-23 16:55 | Burlen | File Added: test.png | |
2011-05-23 17:26 | Burlen | Summary | piece boundary visible in surface lic => boundary artifacts visible in surface lic save screenshot |
2011-05-23 17:26 | Burlen | Description Updated | |
2011-05-23 17:26 | Burlen | Steps to Reproduce Updated | |
2011-05-23 17:26 | Burlen | File Added: 3-stack-y.png | |
2011-05-23 17:41 | Burlen | Summary | boundary artifacts visible in surface lic save screenshot => boundary artifacts visible in surface lic save screenshot w/ multiple views |
2011-05-23 17:41 | Burlen | Description Updated | |
2011-05-23 17:41 | Burlen | Steps to Reproduce Updated | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037980 | |
