0012288 | VTK | Bug | public | 2011-06-20 16:49 | 2016-08-12 09:55 | ||||
Reporter | Zack Galbreath | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0012288: Memory leaks in testing vtkDLG application if loaded PentaHexa.vtk file | ||||||||
Description | Memory leaks in testing vtkDLG application from VTK pack. Memory leaks are detected if PentaHexa.vtk file is loaded. Loading another files from VTKData directory with samlpes doesn't reveal memory leaks. All the DLLs are delay-loaded. | ||||||||
Project | to be decided | ||||||||
Relationships | ||||||
(0026990) Ivan Manuylovich (reporter) 2011-07-11 16:31 |
The memory leak disappears after correction of function vtkDataSetSurfaceFilter::InsertPolygonInHash (deallocation of "tab" memory needed before return in one of the inner brunches) |
(0030897) Jean-Christophe Fillion-Robin (manager) 2013-06-05 13:19 |
Does the problem still occur with VTK 5.10 ? VTK 6 ? |
(0031189) Dave DeMarle (administrator) 2013-07-22 17:37 |
If this turns out to be still be present in 6.0.0, please reopen this report. |
(0037237) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2011-06-20 16:49 | Zack Galbreath | New Issue | |
2011-07-11 12:56 | Kyle Lutz | Relationship added | related to 0012348 |
2011-07-11 16:31 | Ivan Manuylovich | Note Added: 0026990 | |
2013-06-05 13:19 | Jean-Christophe Fillion-Robin | Note Added: 0030897 | |
2013-07-22 17:37 | Dave DeMarle | Note Added: 0031189 | |
2013-07-22 17:37 | Dave DeMarle | Status | backlog => expired |
2013-07-22 17:37 | Dave DeMarle | Resolution | open => fixed |
2013-07-22 17:37 | Dave DeMarle | Assigned To | => Dave DeMarle |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037237 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | fixed => moved |
