0012290 | ParaView | Bug | public | 2011-06-20 16:57 | 2016-08-12 09:58 | ||||
Reporter | Stephane P | ||||||||
Product Version | 3.10.1 | ||||||||
Summary | 0012290: histogram view not initially refreshed when loading state file or playing animation | ||||||||
Description | On the given use cases (see below), the histogram view is empty when it should display some result. Load the given tank.pvsm file. The histogram view is empty. It should display the "bin_values" array. It can be forced to display it by unselecting the array on the display tab and reselecting it. After having displayed the histogram, add an animation on the "Clip" filter (on Origin(2) from -24 to 274). When playing the animation, the histogram goes blank. It can also be forced to display the good result using the same trick as above. Additionaly, when playing the animation, an error is displayed when the cutting plane goes out of range (because the histogram cannot find any array to work on). Could this error be silent? | ||||||||
Project | ParaViS | ||||||||
Topic Name | 12290_fix_histogram_state_loading | ||||||||
Attached Files | tank.tar.gz [^] (964,701 bytes) 2011-06-20 16:57 | ||||||||
(0029509) Utkarsh Ayachit (administrator) 2012-10-24 21:40 edited on: 2012-10-24 21:42 |
commit 72dda59c89170d387e2feb29db2870af64079ba7 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Oct 24 21:38:33 2012 -0400 BUG 0012290. Silence non-critical error message. vtkExtractHistogram would raise errors during animation when the data wasn't available temporarily (as reported in BUG 0012290). We silence that error message. Change-Id: I0106568f831cfd3e20db39a7121629123100257c commit 3ad6aaa568d5b94142f5bc2be8c990181a2e4a0e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Oct 24 21:36:30 2012 -0400 BUG 0012290. Fix loading of state file with histograms. Old state files for charts often saved the CompositeDataSetIndex as 0. In that case we need to handle that by passing the entire data set for plotting. This fix addresses that use-case. This fixes the state loading issue reported in the BUG (although the bug was probably referring to an old issue that's already been addressed, since the plot renders correctly after this fix). Change-Id: Id4f21319e3c89c3d1fa94f8eb82334ace83e90d1 |
(0029544) Utkarsh Ayachit (administrator) 2012-10-29 10:50 |
merged into master, if applicable. |
(0030179) Alan Scott (manager) 2013-01-17 19:15 |
I am pretty sure this still doesn't work. I did the following: Linux, master (as of about January 15th, 2013), local server. * Opened the state file. Histogram did not show up. * Deleted the histogram filter and histogram view, and re-ran them. Worked! * Created the animation on the clip filter as described. Played forward. Worked! Hit play again. Nothing showed up in the histogram window once again. |
(0037984) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-06-20 16:57 | Zack Galbreath | New Issue | |
2011-06-20 16:57 | Zack Galbreath | File Added: tank.tar.gz | |
2011-06-20 16:57 | Zack Galbreath | Reporter | Zack Galbreath => Stephane P |
2011-06-23 10:15 | Utkarsh Ayachit | Project | to be decided => TBD |
2011-06-23 11:43 | Utkarsh Ayachit | Project | TBD => ParaViS |
2012-10-24 21:40 | Utkarsh Ayachit | Topic Name | => 12290_fix_histogram_state_loading |
2012-10-24 21:40 | Utkarsh Ayachit | Note Added: 0029509 | |
2012-10-24 21:40 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-10-24 21:40 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-10-24 21:40 | Utkarsh Ayachit | Resolution | open => fixed |
2012-10-24 21:40 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-10-24 21:42 | Utkarsh Ayachit | Note Edited: 0029509 | |
2012-10-29 10:50 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-10-29 10:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-29 10:50 | Utkarsh Ayachit | Note Added: 0029544 | |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2013-01-17 19:15 | Alan Scott | Note Added: 0030179 | |
2013-01-17 22:55 | Utkarsh Ayachit | Status | customer review => backlog |
2013-01-17 22:55 | Utkarsh Ayachit | Resolution | fixed => reopened |
2015-01-11 08:34 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 8169fb02 |
2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 72dda59c |
2015-01-11 08:35 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 3ad6aaa5 |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037984 | |
2016-08-12 09:58 | Kitware Robot | Fixed in Version | 3.98.0 => |
2016-08-12 09:58 | Kitware Robot | Resolution | reopened => moved |
