0012327 | ParaView | (No Category) | public | 2011-07-01 16:37 | 2013-11-01 13:17 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | |||||||||
Product Version | 3.10.1 | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0012327: Selection inspector's label mode drop-down lists not updated when creating new data array with calculator | ||||||||
Description | Sources - Wavelet - Apply. Selection Inspector - Create Selection - Field Type: Point - New Value: 1 Selection Inspector - Display Style - Point Label - Check Visible Selection Inspector - Display Style - Point Label - Label Mode drop-down list contains "Point IDs" and "RTData". Filters - Calculator - Operation: "coords" - Apply. Selection Inspector - Display Style - Point Label - Label Mode drop-down list still merely contains "Point IDs" and "RTData". The selection needs to be re-created in order for the new "Result" data array to appear in the drop-down list. (The list is updated, though, when an existing calculator-created data array gets renamed.) Tested with ParaView 3.10.1 and git master branch as of now. | ||||||||
Project | TBD | ||||||||
(0031803) Sven Buijssen (reporter) 2013-10-31 07:55 |
Not applicable any more since Selection Inspector got removed in git-master. |
2011-07-01 16:37 | Sven Buijssen | New Issue | |
2013-10-31 07:55 | Sven Buijssen | Note Added: 0031803 | |
2013-10-31 07:55 | Sven Buijssen | Status | backlog => closed |
2013-10-31 07:55 | Sven Buijssen | Resolution | open => no change required |
2013-10-31 07:55 | Sven Buijssen | Fixed in Version | => git-master |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
