0012328VTK(No Category)public2011-07-01 16:522016-08-12 09:55
ReporterJeff Mauldin
Assigned ToDave DeMarle
PriorityhighSeverityminorReproducibilityhave not tried
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0012328: 'Show grid lines' for axes display draws lines outside bounding box on two axes
DescriptionWhen you display the cube axis, and then go to the Edit Cube Axes Properties box, and turn on Show Grid Lines, the behavior is incorrect. For the X-Axis it seems to be okay. However, for the Y and Z Axes, the grid lines are drawn much beyond the range of the bounding box described by the cube axes lines.
To demonstrate, simply start up paraview, create a cone source, turn on Show Cube Axes (in the Annotation section of the Display tab), hit the Edit button to bring up Edit Cube Axes Properties, go to the Y-Axis tab, select the Show Grid Lines check box, and hit okay. Same problem for the Z-Axis. okay for X-Axis.
I suspect the error is connected with the following code in vtkCubeAxesActor.cxx in the method vtkCubeAxesActor::ComputeTickSize
  double xExt = 20; //bounds[1] - bounds[0];
  double yExt = bounds[3] - bounds[2];
  double zExt = bounds[5] - bounds[4];
although I haven't yet tried changing, I'm wondering why xExt is arbitrarily set to 20 rather than using the bounds.
This also, I think affects the tick mark length in a bad way.
I'm attaching state file.
TagsNo tags attached.
ProjectSandia
Typeincorrect functionality
Attached Files? file icon BadGridLines.pvsm [^] (72,262 bytes) 2011-07-01 16:52
 Relationships
  Notes
(0031190)
Dave DeMarle (administrator)
2013-07-22 17:44
Jeff if this is still present in pv 4.0/vtk 6.0, please reopen this report.
(0037238)
Kitware Robot (administrator)
2016-08-12 09:55
Resolving issue as `moved`.
This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page.
 Issue History
2011-07-01 16:52 Jeff Mauldin New Issue
2011-07-01 16:52 Jeff Mauldin File Added: BadGridLines.pvsm
2013-07-22 17:44 Dave DeMarle Note Added: 0031190
2013-07-22 17:44 Dave DeMarle Status backlog => expired
2013-07-22 17:44 Dave DeMarle Assigned To => Dave DeMarle
2016-08-12 09:55 Kitware Robot Note Added: 0037238
2016-08-12 09:55 Kitware Robot Status expired => closed
2016-08-12 09:55 Kitware Robot Resolution open => moved
