0012339 | ParaView | (No Category) | public | 2011-07-06 14:23 | 2012-05-31 10:31 | ||||
Status | closed | Resolution | reopened | ||||||
Summary | 0012339: pvvtk-next not working correctly on dashboards | ||||||||
Description | refer to http://www.cdash.org/CDash/viewUpdate.php?buildid=1307272 [^] The issue is happening because Rob forwarded PVVTK, however the SHA VTK in ParaView referred to was in PVVTK next and since the dashboard does not update pull from pvvtk-remote, it complained. On amber8, when I manually added the pvvtk remote and did a "git fetch pvvtk", then everything worked. | ||||||||
Project | Kitware | ||||||||
(0026970) David Partyka (developer) 2011-07-07 09:35 |
Switching VTK submodules to have PVVTK as their origin as a stop gab. git config remote.origin.url git://paraview.org/PVVTK.git [^] |
(0026971) David Partyka (developer) 2011-07-07 10:14 |
Made this change on all the dashboards, a longer term fix probably needs to be developed by Brad. |
(0026973) Utkarsh Ayachit (administrator) 2011-07-07 10:28 |
let's leave this open until we have fixed it the right way. |
(0026974) Utkarsh Ayachit (administrator) 2011-07-07 13:24 |
amber12 continuous still seems to have update issues. |
(0026975) David Partyka (developer) 2011-07-07 13:37 |
Oops, fixed that one now as well. |
(0027313) Utkarsh Ayachit (administrator) 2011-08-09 09:32 |
The proposed solution was to update the dashboard setup scripts to change the VTK "origin" for "next" dashboards to point to pvvtk remote. |
2011-07-06 14:23 | Utkarsh Ayachit | New Issue | |
2011-07-06 14:23 | Utkarsh Ayachit | Assigned To | => David Partyka |
2011-07-07 09:35 | David Partyka | Status | backlog => todo |
2011-07-07 09:35 | David Partyka | Note Added: 0026970 | |
2011-07-07 09:35 | David Partyka | Status | todo => active development |
2011-07-07 10:14 | David Partyka | Note Added: 0026971 | |
2011-07-07 10:14 | David Partyka | Status | active development => gatekeeper review |
2011-07-07 10:14 | David Partyka | Resolution | open => fixed |
2011-07-07 10:28 | Utkarsh Ayachit | Note Added: 0026973 | |
2011-07-07 10:28 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
2011-07-07 10:28 | Utkarsh Ayachit | Resolution | fixed => reopened |
2011-07-07 13:24 | Utkarsh Ayachit | Note Added: 0026974 | |
2011-07-07 13:37 | David Partyka | Note Added: 0026975 | |
2011-08-09 09:32 | Utkarsh Ayachit | Note Added: 0027313 | |
2012-05-31 10:31 | Utkarsh Ayachit | Status | backlog => closed |
