0012351 | ParaView | (No Category) | public | 2011-07-11 09:53 | 2011-07-22 14:15 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | Kyle Lutz | ||||||||
Product Version | 3.10.1 | ||||||||
Summary | 0012351: Regression since 3.10.0: PlotOverLine does not autoadjust x-axis range when altering point coordinates | ||||||||
Description | Sources - Wavelet - Apply Filters - Plot Over Line - Point 1: -10, 0, 0 Point 2: 0, 0, 0 - Apply => x axis data range is [0,10] (arc_length) Change coordinates of Point 2 to: 10, 0, 0 - Apply => ParaView 3.8.1 did update the x axis data range to [0,20] (arc_length); ParaView 3.10.0, 3.10.1 and git master branch as of now do not, x axis data range recalculation needs to be forced with these versions by toggling visibility of the chart | ||||||||
Project | TBD | ||||||||
(0026993) Kyle Lutz (viewer) 2011-07-12 11:41 |
Merge topic '12351-reset-display-on-data-change' into next fa5bc4b Call resetDisplay() in pqProxyPanel::dataUpdated() |
(0027015) Kyle Lutz (viewer) 2011-07-19 14:43 |
Won't fix. Re-zooming on the data after every apply will lose the user's focus if they have moved the camera at all. The current behavior for the charts matches the behavior of the other views (e.g. 3D) and should stay that way. |
(0027017) Sven Buijssen (reporter) 2011-07-19 14:59 |
Fair enough. Then what about the following use case: One would like to extract some point/cell/field data over time and plot it. As in: Sources - Time Source - Y Ampliture: 1 - Apply Filters - Programmable Filter Output Data Set Type: vtkPolyData Script: inp = self.GetInput() out = self.GetPolyDataOutput() newPoints = vtk.vtkPoints() newPoints.InsertNextPoint(0,0,0) newPoints.InsertNextPoint(1,0,0) out.SetPoints(newPoints) newCell = vtk.vtkCellArray() vertex1 = vtk.vtkVertex() vertex2 = vtk.vtkVertex() vertex1.GetPointIds().SetId(0,0) vertex2.GetPointIds().SetId(1,1) newCell.InsertNextCell(vertex1) newCell.InsertNextCell(vertex2) out.SetVerts(newCell) inPData = inp.GetPointData().GetArray("Point Y") newPData = vtk.vtkFloatArray() newPData.SetName("foo") newPData.SetNumberOfComponents(1) newPData.InsertNextValue(inPData.GetValue(0)) newPData.InsertNextValue(inPData.GetValue(1)) out.GetPointData().AddArray(newPData) Apply Filters - Plot Data - Apply View - Toolbars - VCR Controls Step through time steps => PV 3.10.1 and own build of git master as of now: the y axis of the chart is not updated such that for most time steps the chart is empty. As there is no "rescale to temporal range" (as in the color scale editor for 3D View) either, how is one supposed to get a meaningful chart for all time steps - if there is no auto-adjust? |
(0027035) Utkarsh Ayachit (administrator) 2011-07-20 15:40 |
Adding support for automatic "rescale to temporal range" might be a good feature request. Until then, you can always set the axis range explicitly from the "View Settings" dialog. |
(0027045) Utkarsh Ayachit (administrator) 2011-07-21 19:18 |
Scheduled for gatekeeper review on Jul 22, 2011 at 2 pm EDT. |
2011-07-11 09:53 | Sven Buijssen | New Issue | |
2011-07-11 12:49 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2011-07-11 17:41 | Kyle Lutz | Status | backlog => todo |
2011-07-11 17:41 | Kyle Lutz | Status | todo => active development |
2011-07-12 11:41 | Kyle Lutz | Topic Name | => 12351-reset-display-on-data-change |
2011-07-12 11:41 | Kyle Lutz | Note Added: 0026993 | |
2011-07-12 11:41 | Kyle Lutz | Status | active development => gatekeeper review |
2011-07-12 11:41 | Kyle Lutz | Fixed in Version | => 3.12 |
2011-07-12 11:41 | Kyle Lutz | Resolution | open => fixed |
2011-07-13 09:45 | Kyle Lutz | Status | gatekeeper review => todo |
2011-07-19 14:38 | Kyle Lutz | Status | todo => active development |
2011-07-19 14:43 | Kyle Lutz | Topic Name | 12351-reset-display-on-data-change => |
2011-07-19 14:43 | Kyle Lutz | Note Added: 0027015 | |
2011-07-19 14:43 | Kyle Lutz | Status | active development => gatekeeper review |
2011-07-19 14:43 | Kyle Lutz | Fixed in Version | 3.12 => |
2011-07-19 14:43 | Kyle Lutz | Resolution | fixed => won't fix |
2011-07-19 14:59 | Sven Buijssen | Note Added: 0027017 | |
2011-07-20 15:40 | Utkarsh Ayachit | Note Added: 0027035 | |
2011-07-21 19:18 | Utkarsh Ayachit | Note Added: 0027045 | |
2011-07-22 14:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-07-22 14:15 | Utkarsh Ayachit | Status | customer review => closed |
