0012383 | ParaView | (No Category) | public | 2011-07-20 10:55 | 2016-08-12 09:58 | ||||
Reporter | George Zagaris | ||||||||
Assigned To | George Zagaris | ||||||||
Summary | 0012383: Caching of AMR blocks (geometry+data) on AMR reader | ||||||||
Description | The demand-driven AMR infrastructure, implemented in vtkAMRBaseReader, supports upstream requests from the pipeline that specify which blocks are to be loaded. However, when the user performs actions within the paraview user-interface that can trigger multiple such requests, it can lead to an overwhelming amount of I/O for multiple requests of the same data. One solution to minimize the I/O and avoid reading data that has already been read is to cache AMR blocks in a separate data-structure, e.g., a vtkAMRDataSetCache, that will be an ivar of the vtkAMRBaseReader. | ||||||||
Project | AMR Streaming | ||||||||
Type | usability | ||||||||
(0027575) George Zagaris (developer) 2011-10-14 11:50 |
This is done for Enzo and Flash. Needs more testing and cleanup so I am pushing this back in todo for now. |
(0038011) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-07-20 10:55 | George Zagaris | New Issue | |
2011-07-20 10:55 | George Zagaris | Assigned To | => George Zagaris |
2011-07-20 10:56 | George Zagaris | Status | backlog => todo |
2011-07-20 10:56 | George Zagaris | Status | todo => active development |
2011-10-14 11:50 | George Zagaris | Note Added: 0027575 | |
2011-10-14 11:50 | George Zagaris | Status | active development => todo |
2013-03-04 10:19 | Utkarsh Ayachit | Status | todo => backlog |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038011 | |
