0012388 | ParaView | (No Category) | public | 2011-07-21 14:01 | 2011-08-08 14:55 | ||||
Reporter | Andy Bauer | ||||||||
Summary | 0012388: submodules' git url protocol should follow the main paraview git url protocol type | ||||||||
Description | ParaView's submodules are always set up to use the git protocol url. For users that can't use the git url protocol to clone paraview, they use a different url protocol to get paraview but when they try to checkout the submodules it still uses the git url protocol to clone the repos. This causes problems/confusion. Instead it should be that that submodules use the same url protocol as the main paraview clone. | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
(0027041) Andy Bauer (developer) 2011-07-21 15:01 |
I should add that people from ORNL and LANL hit this problem. |
(0027099) Utkarsh Ayachit (administrator) 2011-07-28 15:52 |
Dave, can you add comment on the way Brad suggested to address this issue and then close this bug please? Thanks |
(0027306) David Partyka (developer) 2011-08-08 14:55 |
A user can have git automatically switch to http instead of git by doing the following. git config url.http://paraview.org.insteadOf [^] git://paraview.org [^] git config url.http://vtk.org.insteadOf [^] git://vtk.org [^] This could be narrowed down further if git:// will never be able to be used via: git config url.http://.insteadOf [^] git:// |
2011-07-21 14:01 | Andy Bauer | New Issue | |
2011-07-21 15:01 | Andy Bauer | Note Added: 0027041 | |
2011-07-28 15:51 | Utkarsh Ayachit | Assigned To | => David Partyka |
2011-07-28 15:52 | Utkarsh Ayachit | Note Added: 0027099 | |
2011-07-28 15:52 | Utkarsh Ayachit | Status | backlog => todo |
2011-08-08 14:55 | David Partyka | Note Added: 0027306 | |
2011-08-08 14:55 | David Partyka | Status | todo => closed |
2011-08-08 14:55 | David Partyka | Resolution | open => fixed |
