0012424ParaView(No Category)public2011-07-28 15:562012-02-08 17:21
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version4.0Fixed in Version3.14
Summary0012424: Memory leak in pvbatch using --use-offscreen-rendering
DescriptionI have a user that is having problems with memory leaks in pvbatch, using --use-offscreen-rendering. Here is his excellent writeup:
Summary: ParaView pvbatch: memory leak using --use-offscreen-rendering
Notes: Create Date: 7/27/2011 6:24:05 PM I'm running into an error where the memory footprint of pvbatch keeps growing, despite the data set size remaining the same. This only occurs when using the "--use-offscreen-rendering" option in pvbatch. Unfortunately, I need that option to execute things on redsky, as the job hangs without it.
This bug is present in 3.10.0 and 3.10.1 (Linux 64-bit), but is not present in 3.8.0 or 3.8.1 (Linux 64-bit). I've run this locally and on redsky and got the same results.
My dataset is rather large, but I've reproduced the problem with the following simple script:
--- memory.py ---
from paraview.simple import *
view = CreateRenderView()
view.ViewSize = [700, 400]
source = Sphere(PhiResolution = 1024, ThetaResolution = 1024) display = Show(source)
Render()
loops=20
for i in range(loops):
    print "on iteration %d/%d" % (i, loops)
    source.PhiResolution = 512
    source.ThetaResolution = 512
    Render()
    source.PhiResolution = 1024
    source.ThetaResolution = 1024
    Render()
To replicate:
1) run "mpiexec -n 4 pvbatch --use-offscreen-rendering memory.py"
2) notice the memory footprint climbs to about 5 GB at the end of the script
To see desired behavior:
1) run "mpiexec -n 4 pvbatch memory.py"
2) notice memory footprint never grows larger than about 1 GB
If you change the number of loops to 100 or so, it'll eventually crash due to memory.
Thanks,
Tim
TagsNo tags attached.
ProjectSandia
Topic Name12424_fix_osmesa_leak
Typecrash
 Relationships
  Notes
(0027778)
2011-12-05 17:54
Problem is definitely related to display lists.
If we turn off display lists using the following Python script, the memory does not grow:
# turn off display lists
g = servermanager.misc.GlobalMapperProperties()
g.GlobalImmediateModeRendering = 1
(0027779)
2011-12-06 07:33
commit 0f9080648f1086b8abaecbc8bdfdbf9e58e66451
Date: Tue Dec 6 07:30:59 2011 -0500
    Fixed BUG 0012424. Display lists were not released correctly.
    Display lists were not release correctly when using vtkOSOpenGLRenderWindow.
    vtkOSOpenGLRenderWindow never sets Mapped to 1, consequently the display lists
    were not being cleared. Fixed the logic.
(0027788)
2011-12-09 14:20
merged in master (wherever applicable)
(0027973)
Alan Scott (manager)
2012-01-24 19:59
Not tested.
 Issue History
2011-07-28 15:56 Alan Scott New Issue
2011-08-29 18:00 Utkarsh Ayachit Product Version 4.0 =>
2011-08-29 18:00 Utkarsh Ayachit Target Version => 4.0
2011-12-05 17:54 Utkarsh Ayachit Note Added: 0027778
2011-12-06 07:33 Utkarsh Ayachit Topic Name => 12424_fix_osmesa_leak
2011-12-06 07:33 Utkarsh Ayachit Note Added: 0027779
2011-12-06 07:33 Utkarsh Ayachit Status backlog => gatekeeper review
2011-12-06 07:33 Utkarsh Ayachit Fixed in Version => git-next
2011-12-06 07:33 Utkarsh Ayachit Resolution open => fixed
2011-12-06 07:33 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2011-12-09 14:20 Utkarsh Ayachit Status gatekeeper review => customer review
2011-12-09 14:20 Utkarsh Ayachit Note Added: 0027788
2011-12-09 14:21 Utkarsh Ayachit Fixed in Version git-next => git-master
2011-12-09 15:00 Utkarsh Ayachit Source_changeset_attached => VTK master b292e29f
2011-12-09 15:00 Utkarsh Ayachit Source_changeset_attached => VTK master b6ba17e9
2011-12-09 15:00 Utkarsh Ayachit Source_changeset_attached => VTK master 0f908064
2012-01-24 19:59 Alan Scott Note Added: 0027973
2012-01-24 19:59 Alan Scott Status customer review => closed
2012-02-08 17:21 Utkarsh Ayachit Fixed in Version git-master => 3.14
