0012546 | ParaView | (No Category) | public | 2011-08-24 07:39 | 2012-02-08 17:27 | ||||
Reporter | Paul Edwards | ||||||||
Target Version | 3.12 | Fixed in Version | 3.12 | ||||||
Summary | 0012546: RequestData called twice in parallel | ||||||||
Description | Filters have their RequestData called twice when using a parallel server. This happens when the filter is first added - subsequent "Apply"s only called it once. To reproduce: First run a parallel server, attach a debugger and set a breakpoint in "vtkArrayCalculator::RequestData" Create a Box source Use calculator to add an array, e.g. "coordsX" Click Apply [ RequestData gets called twice ] Update arrat , e.g. "coordsX + 0" Click Apply [ RequestData only gets called once ] | ||||||||
Project | Kitware | ||||||||
Topic Name | 12546_fix_multiple_executes | ||||||||
Relationships | ||||||
(0027417) Utkarsh Ayachit (administrator) 2011-08-24 09:02 edited on: 2011-08-24 09:02 |
The fix for BUG 0011811 is what's causing this issue. |
(0027425) Utkarsh Ayachit (administrator) 2011-08-24 15:32 |
commit cb9bc043970d96dc5f36ca9b7e06c74d0b78eda6 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Aug 24 15:31:22 2011 -0400 Fixed BUG 0012546. RequestData was called twice in parallel. The issue was introduced by fix for BUG 0011811. We were now requesting ghost-cells in representations to use the ghost-cell information when available during rendering. However that meant that all the request changed since previous update on the pipeline, since the GUI would call UpdatePipeline() when creating the representation but without the extra ghost cells. Fixed this issue by making the GUI also ask for ghost-cells in a similar fashion to vtkGeometryRepresentation. This was done by updating vtkSISourceProxy::UpdatePipeline to request ghost cells using the logic in vtkGeometryRepresentation. vtkGeometryRepresentation was checking for data-type when deciding whether to ask for ghost cells. That meant that vtkSISourceProxy couldn't use it since the algorithm had not produced any data yet. Anyways, the datatype check was unnecessary since we were using the presence of WHOLE_EXTENT() key to exclude any structure data pipelines. So removed that type check. I verified that it doesn't lead to any wrong ghost cell requests when contouring, for example. |
(0028183) Utkarsh Ayachit (administrator) 2012-02-08 17:27 |
Closing bugs sitting in "customer review" for a long time. |
2011-08-24 07:39 | Paul Edwards | New Issue | |
2011-08-24 08:58 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-08-24 08:59 | Utkarsh Ayachit | Target Version | => 3.12 |
2011-08-24 09:02 | Utkarsh Ayachit | Relationship added | related to 0011811 |
2011-08-24 09:02 | Utkarsh Ayachit | Note Added: 0027417 | |
2011-08-24 09:02 | Utkarsh Ayachit | Note Edited: 0027417 | |
2011-08-24 15:32 | Utkarsh Ayachit | Topic Name | => 12546_fix_multiple_executes |
2011-08-24 15:32 | Utkarsh Ayachit | Note Added: 0027425 | |
2011-08-24 15:32 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2011-08-24 15:32 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2011-08-24 15:32 | Utkarsh Ayachit | Resolution | open => fixed |
2011-08-24 15:36 | Utkarsh Ayachit | Project | TBD => Kitware |
2011-08-26 15:57 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-02-08 17:27 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:27 | Utkarsh Ayachit | Note Added: 0028183 |
