0012589 | ParaView | (No Category) | public | 2011-09-13 07:55 | 2016-08-12 09:58 | ||||
Reporter | David Doria | ||||||||
Assigned To | Cory Quammen | ||||||||
Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0012589: Images displayed incorrectly | ||||||||
Description | I have a png file that is not opening correctly in ParaView. The same thing happens with an mha file, so it is not a problem with the PNGReader. You will find the png and mha here: http://daviddoria.com/Uploads/ParaView/ [^] You will also find a screenshot (bad.jpg) of what I see when I open them in ParaView. You will find a screenshot of what it looks like in a normal image editor in good.jpg. This seems like a major problem. | ||||||||
Project | TBD | ||||||||
Attached Files | Screenshot-1.png [^] (69,955 bytes) 2011-09-15 14:01
(0027472) David Doria (reporter) 2011-09-13 08:58 |
Note: I am using a very simple (onboard) video card: ~$ lspci | grep VGA 00:02.0 VGA compatible controller: Intel Corporation 82G33/G31 Express Integrated Graphics Controller (rev 10) |
(0027480) Kyle Lutz (viewer) 2011-09-15 14:00 |
I am not able to reproduce this issue using the current version of ParaView from git-master. I've attached a screen shot which matches your "good.jpg". Which version of ParaView are you running and on what platform? |
(0027481) David Doria (reporter) 2011-09-15 14:01 |
I am using git-master on Ubuntu 11.04. It works fine on a different machine, which I why I thought it might have something to do with the video driver? Everything else in ParaView works fine though, so I thought it was something that could be corrected rather than just a "my machine is broken". |
(0027482) Kyle Lutz (viewer) 2011-09-15 14:04 |
Ok, I'll try to get a hold of a computer with intel integrated graphics and see if I can reproduce the bug. |
(0036641) Cory Quammen (developer) 2016-07-28 10:22 |
Tested locally, built-in server, Mac OS Could not reproduce. Assuming video driver issue. |
(0038071) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-09-13 07:55 | David Doria | New Issue | |
2011-09-13 08:58 | David Doria | Note Added: 0027472 | |
2011-09-15 14:00 | Kyle Lutz | Note Added: 0027480 | |
2011-09-15 14:01 | Kyle Lutz | File Added: Screenshot-1.png | |
2011-09-15 14:01 | David Doria | Note Added: 0027481 | |
2011-09-15 14:04 | Kyle Lutz | Note Added: 0027482 | |
2016-07-28 10:22 | Cory Quammen | Note Added: 0036641 | |
2016-07-28 10:22 | Cory Quammen | Status | backlog => customer review |
2016-07-28 10:22 | Cory Quammen | Resolution | open => unable to reproduce |
2016-07-28 10:22 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038071 | |
2016-08-12 09:58 | Kitware Robot | Status | customer review => closed |
2016-08-12 09:58 | Kitware Robot | Resolution | unable to reproduce => moved |
