| 0012607 | ParaView | (No Category) | public | 2011-09-20 15:14 | 2011-11-28 14:45 | ||||
| Reporter | Andy Bauer | ||||||||
| Assigned To | Andy Bauer | ||||||||
| Product Version | git-master | ||||||||
| Target Version | 3.12 | Fixed in Version | 3.12 | ||||||
| Summary | 0012607: problem with coprocessing plugin when exporting an image from a bar chart view | ||||||||
| Description | Charge the army cfd phase II enhancement project. Steps to reproduce: 1. load the coprocessing plugin 2. create a Mandelbrot source 3. create a histogram filter 4. close the 2d/3d view to leave only the bar chart view 5. export the coprocessing script and check "output rendering components i.e. view" 6. save the python script Now when viewing the script the Histogram1 filter is referenced in GetDisplayProperties() before it is created. Attached is my script showing the error. | ||||||||
| Project | TBD | ||||||||
| Topic Name | 12607-python-trace-fixes | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0027511) Andy Bauer (developer) 2011-09-21 10:26 |
There's also a problem with creating images from 2d views. I'm attaching cp.tgz which can be used to demonstrate the problem. Run with "pvpython pkfdriver.py cp2dview.py 3". The cp2dview.py script was generated from the coprocessing plugin. The error message when running is: acbauer@yavin:/media/ssddrive/BUILDS/ParaView/debug$ bin/pvpython pkfdriver.py cp2dview.py 3 getting appended Traceback (most recent call last): File "pkfdriver.py", line 58, in <module> coProcess(imageData, time, step, sys.argv[1]) File "pkfdriver.py", line 37, in coProcess cpscript.DoCoProcessing(datadescription) File "/media/ssddrive/BUILDS/ParaView/debug/cp2dview.py", line 53, in DoCoProcessing a2DRenderView2.AxesVisibility = 0 File "/media/ssddrive/BUILDS/ParaView/debug/Utilities/VTKPythonWrapping/site-packages/paraview/servermanager.py", line 209, in __setattr__ "to add this attribute.") AttributeError: Attribute AxesVisibility does not exist. This class does not allow addition of new attributes to avoid mistakes due to typos. Use add_attribute() if you really want to add this attribute. |
(0027512) Andy Bauer (developer) 2011-09-21 10:49 |
Going through the views I'm also having problems with the line plot view. I attached cplineplotview.py which can be run with "pvpython cplineplotview.py 3". This gives the following error: acbauer@yavin:/media/ssddrive/BUILDS/ParaView/debug$ bin/pvpython pkfdriver.py cplineplotview.py 3 getting appended Traceback (most recent call last): File "pkfdriver.py", line 58, in <module> coProcess(imageData, time, step, sys.argv[1]) File "pkfdriver.py", line 37, in coProcess cpscript.DoCoProcessing(datadescription) File "/media/ssddrive/BUILDS/ParaView/debug/cplineplotview.py", line 29, in DoCoProcessing DataRepresentation4 = GetDisplayProperties(PlotOverLine1) UnboundLocalError: local variable 'PlotOverLine1' referenced before assignment |
(0027513) Andy Bauer (developer) 2011-09-21 10:57 |
Same problems with parallel coordinates view. I attached cpparallelcoordsview.py coprocessing script. Run as "pvpython pkfdriver.py cpparallelcoordsview.py 3". The output is: acbauer@yavin:/media/ssddrive/BUILDS/ParaView/debug$ bin/pvpython pkfdriver.py cpparallelcoordsview.py 3 getting appended Traceback (most recent call last): File "pkfdriver.py", line 58, in <module> coProcess(imageData, time, step, sys.argv[1]) File "pkfdriver.py", line 37, in coProcess cpscript.DoCoProcessing(datadescription) File "/media/ssddrive/BUILDS/ParaView/debug/cpparallelcoordsview.py", line 29, in DoCoProcessing DataRepresentation13 = GetDisplayProperties(Histogram1) UnboundLocalError: local variable 'Histogram1' referenced before assignment |
(0027542) Andy Bauer (developer) 2011-10-05 11:40 |
Note when generating the python script through the plugin to name the source as "input". |
(0027553) David Partyka (developer) 2011-10-07 20:45 |
Merged into master |
(0027739) Andy Bauer (developer) 2011-11-28 14:45 |
Confirmed with the line plot view and the barchart view. |
| Notes |
| Issue History | |||
| 2011-09-20 15:14 | Andy Bauer | New Issue | |
| 2011-09-20 15:14 | Andy Bauer | Assigned To | => Pat Marion |
| 2011-09-20 15:14 | Andy Bauer | File Added: histo.py | |
| 2011-09-21 10:26 | Andy Bauer | Note Added: 0027511 | |
| 2011-09-21 10:26 | Andy Bauer | File Added: cp.tgz | |
| 2011-09-21 10:49 | Andy Bauer | Note Added: 0027512 | |
| 2011-09-21 10:50 | Andy Bauer | File Added: cplineplotview.py | |
| 2011-09-21 10:56 | Andy Bauer | File Added: cpparallelcoordsview.py | |
| 2011-09-21 10:57 | Andy Bauer | Note Added: 0027513 | |
| 2011-10-05 11:40 | Andy Bauer | Note Added: 0027542 | |
| 2011-10-05 14:31 | Andy Bauer | Target Version | => 3.12 |
| 2011-10-07 10:26 | Andy Bauer | Assigned To | Pat Marion => Andy Bauer |
| 2011-10-07 10:26 | Andy Bauer | Topic Name | => 12607-python-trace-fixes |
| 2011-10-07 10:26 | Andy Bauer | Status | backlog => gatekeeper review |
| 2011-10-07 10:26 | Andy Bauer | Resolution | open => fixed |
| 2011-10-07 20:45 | David Partyka | Note Added: 0027553 | |
| 2011-10-07 20:45 | David Partyka | Status | gatekeeper review => customer review |
| 2011-11-11 17:08 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
| 2011-11-28 14:45 | Andy Bauer | Note Added: 0027739 | |
| 2011-11-28 14:45 | Andy Bauer | Status | customer review => closed |
| Issue History |
