0012619 | VTK | (No Category) | public | 2011-09-29 03:37 | 2013-07-22 19:45 | ||||
Reporter | Sven Buijssen | ||||||||
Product Version | 5.8.0 | ||||||||
Target Version | 5.8.1 | Fixed in Version | 5.10.0 | ||||||
Summary | 0012619: Null pointer dereference in class vtkPolyDataSilhouetteEdges | ||||||||
Description | Use the attached XML plugin to expose vtkPolyDataSilhouetteEdges as filter in ParaView (Tools - Manage Plugins - Load New...) Sources - Cone - Apply Filters - Silhouette Edges - Apply Uncheck "Enable Feature Angle" - Apply => Program received signal SIGSEGV, Segmentation fault. 0x00007fffe3337673 in vtkPolyDataSilhouette::RequestData (this=0x286cfe0, inputVector=0x2876290, outputVector=0x286f610) at /ParaView3.git/VTK/Hybrid/vtkPolyDataSilhouette.cxx:258 258 ( this->Camera->GetMTime() > output->GetMTime() ) || (gdb) print this->Camera $1 = (class vtkCamera *) 0x0 | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | ![]() ![]() | ||||||||
(0027532) Sven Buijssen (reporter) 2011-09-29 03:41 |
Suggested patch attached. |
(0027748) David Partyka (developer) 2011-11-30 11:46 |
Merged the vtk change into vtk master/release. The ParaView xml plugin will take a little extra work to battle with the new work flow. |
2011-09-29 03:37 | Sven Buijssen | New Issue | |
2011-09-29 03:37 | Sven Buijssen | File Added: vtkPolyDataSilhouette.xml | |
2011-09-29 03:41 | Sven Buijssen | File Added: 0001-BUG-Fix-for-BUG-12619.-vtkPolyDataSilhouette-segfaul.patch | |
2011-09-29 03:41 | Sven Buijssen | Note Added: 0027532 | |
2011-09-29 08:20 | David Partyka | Assigned To | => David Partyka |
2011-09-29 08:20 | David Partyka | Status | backlog => tabled |
2011-09-29 08:20 | David Partyka | Target Version | => 5.8.1 |
2011-11-30 11:45 | David Partyka | Status | tabled => todo |
2011-11-30 11:45 | David Partyka | Resolution | open => fixed |
2011-11-30 11:45 | David Partyka | Status | todo => active development |
2011-11-30 11:46 | David Partyka | Note Added: 0027748 | |
2011-11-30 11:46 | David Partyka | Status | active development => gatekeeper review |
2011-11-30 12:00 | David Partyka | Source_changeset_attached | => VTK master c5054715 |
2013-07-22 19:45 | Dave DeMarle | Status | gatekeeper review => closed |
2013-07-22 19:45 | Dave DeMarle | Fixed in Version | => 5.10.0 |
