| 0012629 | VTK | (No Category) | public | 2011-10-05 09:35 | 2013-12-16 12:45 | ||||
| Reporter | Takuya OSHIMA | ||||||||
| Assigned To | Dave DeMarle | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 5.8.0 | ||||||||
| Target Version | 5.8.1 | Fixed in Version | |||||||
| Summary | 0012629: Incorrect polyhedron insertion in vtkAppendFilter | ||||||||
| Description | There is an incorrect insertion of polyhedral cell in vtkAppendFilter which causes crash. I attached patch to fix the problem. I'll attach a test case later if permission is granted by the original reporter. | ||||||||
| Project | Kitware | ||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0027541) Takuya OSHIMA (reporter) 2011-10-05 11:05 |
Attached a test case. To replicate the problem with ParaView, unpack zone.Mesh.tar.gz2 and 1.Open case.foam 2.Set Case Type to Decomposed Case 3.Check Read Zones at the bottom of the reader panel 4.Apply and ParaView hangs. |
(0031270) Dave DeMarle (administrator) 2013-07-22 20:03 |
moving all "tabled" bugs into "backlog" category since "tabled" is no longer used. |
(0031485) David Thompson (reporter) 2013-08-19 11:57 |
This may be fixed by recent commits. See ParaView bug 14188. |
| Notes |
| Issue History | |||
| 2011-10-05 09:35 | Takuya OSHIMA | New Issue | |
| 2011-10-05 09:35 | Takuya OSHIMA | File Added: 0001-Fix-polyhedron-handling-in-vtkAppendFilter.patch | |
| 2011-10-05 09:37 | David Partyka | Assigned To | => David Partyka |
| 2011-10-05 09:37 | David Partyka | Status | backlog => tabled |
| 2011-10-05 09:37 | David Partyka | Target Version | => 5.8.1 |
| 2011-10-05 11:05 | Takuya OSHIMA | File Added: zone.Mesh.tar.bz2 | |
| 2011-10-05 11:05 | Takuya OSHIMA | Note Added: 0027541 | |
| 2013-07-22 20:03 | Dave DeMarle | Status | tabled => backlog |
| 2013-07-22 20:03 | Dave DeMarle | Note Added: 0031270 | |
| 2013-07-22 20:31 | Dave DeMarle | Assigned To | David Partyka => Dave DeMarle |
| 2013-07-22 20:31 | Dave DeMarle | Status | backlog => tabled |
| 2013-07-22 20:43 | Dave DeMarle | Status | tabled => backlog |
| 2013-08-19 11:57 | David Thompson | Note Added: 0031485 | |
| 2013-12-16 12:45 | Dave DeMarle | Status | backlog => closed |
| 2013-12-16 12:45 | Dave DeMarle | Resolution | open => fixed |
| Issue History |
