0012632 | ParaView | (No Category) | public | 2011-10-07 13:14 | 2016-08-12 09:58 | ||||
Reporter | Sebastien Jourdain | ||||||||
Summary | 0012632: Some Dashboard machine do not run pvcrs.FindDataDialog.Flow | ||||||||
Description | On top of that we are not properly detecting failure on pvcrs.FindDataDialog.Flow when it run on Windows. The trace say server exit with code 1. But the test pass. | ||||||||
Project | TBD | ||||||||
(0027545) Sebastien Jourdain (manager) 2011-10-07 13:26 |
A quick fix for that bug: Need to validate that with Sankhesh ========================= diff --git a/ParaViewCore/VTKExtensions/vtkPVGlyphFilter.cxx b/ParaViewCore/VTKExtensions/vtkPVGlyphFilter.cxx index 494ad12..508da4b 100644 --- a/ParaViewCore/VTKExtensions/vtkPVGlyphFilter.cxx +++ b/ParaViewCore/VTKExtensions/vtkPVGlyphFilter.cxx @@ -477,7 +477,7 @@ void vtkPVGlyphFilter::CalculatePtsToGlyph(double PtsNotBlanked) // Identify the first point to glyph. - if(this->RandomMode) + if(this->RandomMode && this->RandomPtsInDataset.size() > 0) { this->BlockNextPoint = this->RandomPtsInDataset[0]; } |
(0038079) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-10-07 13:14 | Sebastien Jourdain | New Issue | |
2011-10-07 13:14 | Sebastien Jourdain | Assigned To | => David Partyka |
2011-10-07 13:26 | Sebastien Jourdain | Note Added: 0027545 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038079 | |
