| 0012682 | ParaView | (No Category) | public | 2011-10-26 12:29 | 2012-02-08 17:21 | ||||
| Reporter | David Partyka | ||||||||
| Assigned To | Ken Moreland | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 3.10.1 | ||||||||
| Target Version | Fixed in Version | 3.14 | |||||||
| Summary | 0012682: IceT Fails to compile with MPI 1 | ||||||||
| Description | [ 44%] Building C object Utilities/IceT/src/communication/CMakeFiles/IceTMPI.dir/mpi.c.o cd /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2-build/Utilities/IceT/src/communication && /usr/local/bin/mpicc -DIceTMPI_EXPORTS -DVTK_PYTHON_BUILD -I/usr/global/tools/Kitware/Paraview/3.11/chaos_4_x86_64_ib/include -I/usr/gapps/visit/mili/1.10.0/linux-x86_64_gcc-4.1/include -I/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/include -g -fPIC -I/nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2-build -I/nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2-build/VTK/Utilities -I/usr/local/include/python2.6 -I/usr/local/tools/mvapich-gnu/include -I/nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/include -I/nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2-build/Utilities/IceT/src/include -ansi -Wall -Wno-long-long -Wcast-align -Wextra -Wformat-security -Wshadow -Wunused -Wreturn-type -Wpointer-arith -Wdeclaration-after-statement -o CMakeFiles/IceTMPI.dir/mpi.c.o -c /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c: In function 'Gather': /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c:327: error: 'MPI_IN_PLACE' undeclared (first use in this function) /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c:327: error: (Each undeclared identifier is reported only once /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c:327: error: for each function it appears in.) /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c: In function 'Gatherv': /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c:348: error: 'MPI_IN_PLACE' undeclared (first use in this function) /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c: In function 'Allgather': /nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2/Utilities/IceT/src/communication/mpi.c:366: error: 'MPI_IN_PLACE' undeclared (first use in this function) make[2]: *** [Utilities/IceT/src/communication/CMakeFiles/IceTMPI.dir/mpi.c.o] Error 1 make[2]: Leaving directory `/nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2-build' make[1]: *** [Utilities/IceT/src/communication/CMakeFiles/IceTMPI.dir/all] Error 2 make[1]: Leaving directory `/nfs/tmp2/rcook/ParaView/3.12/ParaView-3.12.0-RC2-build' make: *** [all] Error 2 | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0027611) David Partyka (developer) 2011-10-26 12:32 |
See this this started by Rich Cook for more details. http://markmail.org/thread/rggavx4lf4zdf3pt [^] |
(0027613) Ken Moreland (manager) 2011-10-26 15:31 |
The issue is that MPI_IN_PLACE is not supported before MPI 2. There needs to be a check for MPI 1 and use a different method in that case. |
(0027616) David Partyka (developer) 2011-10-27 16:24 |
Hey Ken, I setup a machine with mpich1 and can recreate the build failures, feel free to send patches to test my way. |
(0027628) Ken Moreland (manager) 2011-10-31 14:30 |
I think I have the problem fixed. I would appreciate it if someone (i.e. Dave P.) would verify that it compiles correctly with MPI 1 before I merge with next and move this bug to gatekeeper review. I've pushed the necessary ParaView changes to the staging area under branch 12682-icet-fails-mpi-1 (SHA 5b6e3fcec86b5b22d4409d111b6609a1f6124e9e). Don't forget to also update the submodules. Alternately, you could just apply the patch I've attached to this bug (to be applied to the Utilities/IceT subdirectory). |
(0027661) Takuya OSHIMA (reporter) 2011-11-05 05:49 |
I tested the attached patch with 3.12.0-RC3 on a supercluster that only has MPI-1.2 support and confirmed that IceT compiled correctly. Many thanks for the fix! |
(0027662) Ken Moreland (manager) 2011-11-06 17:10 |
Is it possible to confirm that the server also runs with remote rendering turned on? We know the change compiles, but we are having trouble confirming that it runs correctly. |
(0027664) Takuya OSHIMA (reporter) 2011-11-06 23:08 |
I needed another fix (0012711) in order to get everything compiled since our cluster is headless and thus needed OSMesa under user directory. With the fix applied, the server runs fine with remote rendering turned on (I see subsampled images during interaction). |
(0027771) Ken Moreland (manager) 2011-12-05 13:04 |
I believe this patch to be checked in and I am not aware of any further issues. |
(0027783) Utkarsh Ayachit (administrator) 2011-12-09 14:20 |
merged in master (wherever applicable) |
(0027972) Alan Scott (manager) 2012-01-24 19:56 |
Assuming fixed. |
| Notes |
| Issue History | |||
| 2011-10-26 12:29 | David Partyka | New Issue | |
| 2011-10-26 12:29 | David Partyka | Assigned To | => Ken Moreland |
| 2011-10-26 12:32 | David Partyka | Note Added: 0027611 | |
| 2011-10-26 15:31 | Ken Moreland | Note Added: 0027613 | |
| 2011-10-27 16:24 | David Partyka | Note Added: 0027616 | |
| 2011-10-31 14:18 | Ken Moreland | Status | backlog => todo |
| 2011-10-31 14:18 | Ken Moreland | Status | todo => active development |
| 2011-10-31 14:22 | Ken Moreland | File Added: 0001-Work-around-when-MPI_IN_PLACE-not-available.patch | |
| 2011-10-31 14:30 | Ken Moreland | Note Added: 0027628 | |
| 2011-11-05 05:49 | Takuya OSHIMA | Note Added: 0027661 | |
| 2011-11-06 17:10 | Ken Moreland | Note Added: 0027662 | |
| 2011-11-06 23:08 | Takuya OSHIMA | Note Added: 0027664 | |
| 2011-12-05 13:04 | Ken Moreland | Note Added: 0027771 | |
| 2011-12-05 13:04 | Ken Moreland | Status | active development => gatekeeper review |
| 2011-12-05 13:04 | Ken Moreland | Fixed in Version | => 3.12 |
| 2011-12-05 13:04 | Ken Moreland | Resolution | open => fixed |
| 2011-12-09 14:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2011-12-09 14:20 | Utkarsh Ayachit | Note Added: 0027783 | |
| 2011-12-09 14:21 | Utkarsh Ayachit | Fixed in Version | 3.12 => git-master |
| 2012-01-24 19:56 | Alan Scott | Note Added: 0027972 | |
| 2012-01-24 19:56 | Alan Scott | Status | customer review => closed |
| 2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
| Issue History |
