0012689 | ParaView | (No Category) | public | 2011-10-31 10:06 | 2013-09-03 20:39 | ||||
Reporter | len0 | ||||||||
Assigned To | Alan Scott | ||||||||
Product Version | 3.10.1 | ||||||||
Summary | 0012689: Segmentation fault when clipping Polyhedra | ||||||||
Description | Clipping an unstructured grid containing more than one polyhedron (cell type 42) in Paraview 3.10.1 64-bit and 3.12.0-RC2 64-bit yields a segmentation fault. A minimal example containing two tetrahedra is attached as .vtu file. Plane-clipping the grid with a Z-Normal should reproduce the seg. fault. The crash could also be reproduced with ParaView git/master as follows: * Load file * Filters - Clip Clip Type: Plane Origin: 0.3, 0.5, 0.5 Normal: 1, 0, 0 Tick "Inside Out" checkbox Apply (One may need to toggle the checkbox a couple of times and pressing Apply each time after toggling until the segfault gets triggered.) => 0x00007fffdf00166a in vtkDataSetSurfaceFilter::InsertPolygonInHash (this=0x2a09270, ids=0x2bd7cb0, numPts=0, sourceId=0) at /opt/ParaView3.git/VTK/Graphics/vtkDataSetSurfaceFilter.cxx:1797 1797 quad = *end; (gdb) list 1794 1789 vtkIdType* tab = new vtkIdType[numPts]; 1790 for(int i=0; i<numPts; i++) 1791 { 1792 tab[i] = ids[(offset+i)%numPts]; 1793 } 1794 1795 // Look for existing hex in the hash; 1796 end = this->QuadHash + tab[0]; 1797 quad = *end; (gdb) print numPts $1 = 0 (gdb) print tab[0] $1 = -614752568 The segfault is triggered by the variable 'numPts' being zero which causes the for-loop in line 1790 being skipped such that the array 'tab' is not initialized, but still queried at position 0 in line 1796. So, 'end' points to some random location in memory and dereferencing it in line 1797 causes the segfault. | ||||||||
Project | Release | ||||||||
Type | crash | ||||||||
Attached Files | ![]() | ||||||||
Relationships | ||||||
(0031486) David Thompson (developer) 2013-08-19 11:58 |
This may be fixed by recent commits. See ParaView bug 14188. |
(0031488) len0 (reporter) 2013-08-20 10:39 |
I confirm that clipping polyhedra now works with git-master on all data sets I have tried (including the above). Thanks! |
(0031525) Alan Scott (manager) 2013-09-03 20:39 |
Fixed. See bug 14166 for details. Tested local server, master, Linux. |
2011-10-31 10:06 | len0 | New Issue | |
2011-10-31 10:06 | len0 | File Added: polyh_min.vtu | |
2013-08-19 11:58 | David Thompson | Note Added: 0031486 | |
2013-08-19 11:58 | David Thompson | Relationship added | related to 0014188 |
2013-08-20 10:39 | len0 | Note Added: 0031488 | |
2013-09-03 20:39 | Alan Scott | Note Added: 0031525 | |
2013-09-03 20:39 | Alan Scott | Status | backlog => closed |
2013-09-03 20:39 | Alan Scott | Assigned To | => Alan Scott |
2013-09-03 20:39 | Alan Scott | Resolution | open => fixed |
