| 0012714 | ParaView | (No Category) | public | 2011-11-09 07:37 | 2016-08-12 09:59 | ||||
| Reporter | Jean M. Favre | ||||||||
| Assigned To | Kitware Robot | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 3.12 | ||||||||
| Summary | 0012714: D3 crashes with option "duplicate cells" | ||||||||
| Description | Using more then 8 pvservers (our standard is 12 processes), D3 will crash when executing with the Exodus file which you can find at ftp://ftp.cscs.ch/out/jfavre/bones.ex2.gz [^] 1) Load the data, without the cell or point data (to be faster). 2) Add D3 with "duplicate cells" 3) Hit play button (or crash also immediately) 4) crash the same file was verified to run correctly with 3.10.1 Jean | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0038097) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2011-11-09 07:37 | Jean M. Favre | New Issue | |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038097 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
