0012741 | ParaView | (No Category) | public | 2011-11-21 16:26 | 2013-03-04 10:24 | ||||
Reporter | David Partyka | ||||||||
Product Version | 3.12 | ||||||||
Summary | 0012741: installation of vtk python shared libraries is broken | ||||||||
Description | libvtk*Python.so fails to install on linux builds. | ||||||||
Project | Kitware | ||||||||
Topic Name | 12741-fix-installing-vtk-python-shared-libraries | ||||||||
(0027797) Orion Poplawski (reporter) 2011-12-12 12:59 |
Tried installing libvtk*Python.so by hand, but that ended up producing the following unmet dependencies: paraview-3.12.0-2.fc17.i686 requires libvtkmyUnsortedPythonD.so paraview-3.12.0-2.fc17.i686 requires libvtkmyUnsorted.so paraview-3.12.0-2.fc17.i686 requires libvtkmyImagingPythonD.so paraview-3.12.0-2.fc17.i686 requires libvtkmyImaging.so paraview-3.12.0-2.fc17.i686 requires libvtkmyCommonPythonD.so paraview-3.12.0-2.fc17.i686 requires libvtkmyCommon.so paraview-3.12.0-2.fc17.i686 requires libvtkLocalPythonD.so paraview-3.12.0-2.fc17.i686 requires libvtkLocal.so This approach seems like a bit of a rabbit hole. Any progress? |
(0027898) Orion Poplawski (reporter) 2012-01-03 16:13 |
Actually, it is the vtk*Python.so libraries that fail to install, not libvtk*Python.so. Also needed to put vtkPV*Python.so into site-packages/paraview and the rest in site-packages/paraview/vtk. Confusing. Would very much like to see this fixed by the next release. |
2011-11-21 16:26 | David Partyka | New Issue | |
2011-11-21 16:26 | David Partyka | Assigned To | => David Partyka |
2011-11-21 16:39 | David Partyka | Description Updated | |
2011-11-27 20:15 | David Partyka | Status | backlog => todo |
2011-11-27 20:15 | David Partyka | Status | todo => active development |
2011-12-12 12:59 | Orion Poplawski | Note Added: 0027797 | |
2011-12-30 13:24 | Utkarsh Ayachit | Topic Name | => 12741-fix-installing-vtk-python-shared-libraries |
2012-01-03 16:13 | Orion Poplawski | Note Added: 0027898 | |
2013-03-04 10:24 | Utkarsh Ayachit | Status | active development => todo |
2013-03-04 10:24 | Utkarsh Ayachit | Status | todo => closed |
2013-03-04 10:24 | Utkarsh Ayachit | Resolution | open => fixed |
