0012831 | ParaView | (No Category) | public | 2011-12-30 13:46 | 2014-02-24 12:11 | ||||
Reporter | David Partyka | ||||||||
Summary | 0012831: 3.12 VisTrails plugin fails to compile | ||||||||
Description | 3.12 vistrails source fails to compile against paraview master after a recent api change. Source can be found here: http://paraview.org/files/misc/VisTrails-2.0.tar.gz [^] /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx:49:31: fatal error: pqServerResources.h: No such file or directory compilation terminated. make[2]: *** [Plugins/VisTrails/plugin/CMakeFiles/VisTrailsPlugin.dir/PluginMain.cxx.o] Error 1 make[1]: *** [Plugins/VisTrails/plugin/CMakeFiles/VisTrailsPlugin.dir/all] Error 2 /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx: In member function ‘void PluginMain::ConnectSignalsAndSlots()’: /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx:325:37: error: ‘class pqApplicationCore’ has no member named ‘serverResources’ /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx: In member function ‘void PluginMain::DisconnectSignalsAndSlots()’: /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx:376:37: error: ‘class pqApplicationCore’ has no member named ‘serverResources’ /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx: In member function ‘void PluginMain::ReplayActions(vt::VersionPath*, vt::VersionId)’: /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx:711:34: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx: In member function ‘void PluginMain::LoadState(const QString&, bool)’: /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx:814:36: error: ‘class pqApplicationCore’ has no member named ‘serverResources’ /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx:815:36: error: ‘class pqApplicationCore’ has no member named ‘serverResources’ /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx: In member function ‘void PluginMain::serverResourcesChanged()’: /home/partyd/Projects/ParaView/build/VisTrails/plugin/PluginMain.cxx:908:9: error: ‘class pqApplicationCore’ has no member named ‘serverResources’ make[2]: *** [Plugins/VisTrails/plugin/CMakeFiles/VisTrailsPlugin.dir/PluginMain.cxx.o] Error 1 make[1]: *** [Plugins/VisTrails/plugin/CMakeFiles/VisTrailsPlugin.dir/all] Error 2 | ||||||||
Project | Kitware | ||||||||
(0027890) David Partyka (developer) 2011-12-30 13:46 |
When this fixed remind David P. to re-enable VisTrails plugins on the dashboard. |
(0027899) David Partyka (developer) 2012-01-04 15:47 |
Imported the code to this kwsource repo. Commit changes here: http://kwsource.kitwarein.com/paraview/vistrails [^] |
(0032397) Utkarsh Ayachit (administrator) 2014-02-24 12:11 |
old bug. I am assuming this is now fixed. |
2011-12-30 13:46 | David Partyka | New Issue | |
2011-12-30 13:46 | David Partyka | Assigned To | => Utkarsh Ayachit |
2011-12-30 13:46 | David Partyka | Note Added: 0027890 | |
2012-01-04 15:47 | David Partyka | Note Added: 0027899 | |
2014-02-24 12:11 | Utkarsh Ayachit | Note Added: 0032397 | |
2014-02-24 12:11 | Utkarsh Ayachit | Status | backlog => closed |
2014-02-24 12:11 | Utkarsh Ayachit | Resolution | open => fixed |
