0012842 | ParaView | (No Category) | public | 2012-01-05 19:48 | 2012-02-08 17:24 | ||||
Reporter | Burlen | ||||||||
Assigned To | Bob O'Bara | ||||||||
Product Version | 3.12 | ||||||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012842: segfault in vtkVolumeRayCastSpaceLeapingImageFilter | ||||||||
Description | Hi, In 3.12 when volume rendering on image data I'm experiencing segfaults in vtkVolumeRayCastSpaceLeapingImageFilter in vtkVolumeRayCastSpaceLeapingImageFilterMinMaxExecute. The issue seems to be that vtkImageData::ComputeIncrements relies on active scalars being set. However, for use with ParaView I don't think this can be guaranteed. for instance how would an object that produces multiple arrays, eg a reader, correctly set active scalars? A quick fix is below, the real fix probably is quite a bit more involved. --- ParaView-3.12.0-base/VTK/VolumeRendering/vtkVolumeRayCastSpaceLeapingImageFilter.cxx 2011-11-08 12:56:45.000000000 -0800 +++ ParaView-3.12.0/VTK/VolumeRendering/vtkVolumeRayCastSpaceLeapingImageFilter.cxx 2012-01-05 16:34:06.217415840 -0800 @@ -801,6 +801,10 @@ return; } + // FIXME --- this keeps things running smoothly when active scalars + // are not set but modifies the input + inData[0][0]->GetPointData()->SetScalars(this->GetCurrentScalars()) + const int components = this->GetCurrentScalars()->GetNumberOfComponents(); const unsigned int nComponents = (this->GetIndependentComponents()) ? components : 1; | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0027934) Utkarsh Ayachit (administrator) 2012-01-13 09:51 |
I believe this issue has already been fixed in git-master. Please reopen if you're still running into problems. |
(0027953) Utkarsh Ayachit (administrator) 2012-01-20 14:20 |
merged in master (whenever applicable) |
(0028119) Utkarsh Ayachit (administrator) 2012-02-08 17:24 |
Closing bugs sitting in "customer review" for a long time. |
2012-01-05 19:48 | Burlen | New Issue | |
2012-01-13 09:51 | Utkarsh Ayachit | Note Added: 0027934 | |
2012-01-13 09:51 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-01-13 09:51 | Utkarsh Ayachit | Fixed in Version | => git-master |
2012-01-13 09:51 | Utkarsh Ayachit | Resolution | open => no change required |
2012-01-13 09:51 | Utkarsh Ayachit | Assigned To | => Bob O'Bara |
2012-01-20 14:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-01-20 14:20 | Utkarsh Ayachit | Note Added: 0027953 | |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028119 |
