| 0012849 | ParaView | (No Category) | public | 2012-01-07 17:37 | 2012-02-08 17:21 | ||||
| Reporter | td123 | ||||||||
| Assigned To | Robert Maynard | ||||||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 3.14 | |||||||
| Summary | 0012849: Paraview 3.12.0 fails to build when configured with PARAVIEW_USE_VISITBRIDGE ON | ||||||||
| Description | I can successfully build paraview 3.12.0, but once I add -DPARAVIEW_USE_VISITBRIDGE:BOOL=ON to the cmake flags, it fails with the following error: [ 47%] Building CXX object Utilities/VisItBridge/visit_vtk/full/CMakeFiles/visit_vtk.dir/vtkVolumeFromVolume.C.o Linking CXX shared library ../../../../bin/libvisit_vtk.so /usr/bin/ld: cannot find -lvtktiff collect2: ld returned 1 exit status make[2]: *** [bin/libvisit_vtk.so] Error 1 make[1]: *** [Utilities/VisItBridge/visit_vtk/full/CMakeFiles/visit_vtk.dir/all] Error 2 make: *** [all] Error 2 I have attached the full output as the attachment "output.paraview.txt" | ||||||||
| Project | TBD | ||||||||
| Topic Name | 12849-VisItBrige-external-tiff-support | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0027921) td123 (reporter) 2012-01-07 17:39 |
I have also attached PKGBUILD.txt which is the script used to build paraview. Without the -DPARAVIEW_USE_VISITBRIDGE:BOOL=ON flag, everything builds fine. With the flag, it fails as described above. |
(0027922) Robert Maynard (developer) 2012-01-09 09:47 |
I expect the problem is caused by the fact we didn't handle an external tiff library being used. |
(0027979) Robert Maynard (developer) 2012-01-25 12:01 |
Really is a ParaView bug. ParaView branch name is: 12849-VisItBrige-external-tiff-support |
(0027990) Utkarsh Ayachit (administrator) 2012-01-27 14:25 |
merged in master (wherever applicable) |
(0028086) Alan Scott (manager) 2012-02-07 21:51 |
I am not using the superbuild, but I get a good build (client and server side) with PARAVIEW_USE_VISITBRIDGE ON. If you still have an issue with this build, please reopen. Tested remote server, Linux, master. |
| Notes |
| Issue History | |||
| 2012-01-07 17:37 | td123 | New Issue | |
| 2012-01-07 17:37 | td123 | File Added: output.paraview.txt | |
| 2012-01-07 17:38 | td123 | File Added: PKGBUILD.txt | |
| 2012-01-07 17:39 | td123 | Note Added: 0027921 | |
| 2012-01-09 09:47 | Robert Maynard | Note Added: 0027922 | |
| 2012-01-09 10:12 | Robert Maynard | Assigned To | => Robert Maynard |
| 2012-01-09 10:12 | Robert Maynard | Status | backlog => tabled |
| 2012-01-09 10:13 | Robert Maynard | Status | tabled => active development |
| 2012-01-09 10:13 | Robert Maynard | Resolution | open => fixed |
| 2012-01-25 12:01 | Robert Maynard | Note Added: 0027979 | |
| 2012-01-25 12:01 | Robert Maynard | Status | active development => gatekeeper review |
| 2012-01-25 13:56 | Utkarsh Ayachit | Project | VTK => ParaView |
| 2012-01-27 14:06 | Utkarsh Ayachit | Topic Name | => 12849-VisItBrige-external-tiff-support |
| 2012-01-27 14:06 | Utkarsh Ayachit | Product Version | 5.8.0 => |
| 2012-01-27 14:25 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-01-27 14:25 | Utkarsh Ayachit | Note Added: 0027990 | |
| 2012-01-27 14:26 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-02-07 21:51 | Alan Scott | Note Added: 0028086 | |
| 2012-02-07 21:51 | Alan Scott | Status | customer review => closed |
| 2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
| Issue History |
